Boat Dock Stairs
Old 02-06-2012, 08:53 AM   #1
summithomeinc's Avatar
Trade: Painter/Handyman
Rewards Points: 2,422
Boat Dock Stairs
I have a customer that wants a set of stairs built to his dock. Part of the time the stairs will be underwater depending on the lake level. Has anyone built stairs like this? Do you have to do anything special to keep the stairs from "floating" when the water rises?
summithomeinc is offline
Old 02-06-2012, 09:17 AM   #2
Joe Wood's Avatar
Rewards Points: 522
Re: Boat Dock Stairs
Build them out of ipe as it doesn't float :-)
https://woodsshop.com/
Joe Wood is offline
Old 02-06-2012, 09:27 AM   #3
I'll check to see if ipe is in the budget. Really was wondering if I need extra comcrete or if it's even an issue to worry about.
I need more tools.
Old 02-06-2012, 09:40 AM   #4
jb4211's Avatar
Rewards Points: 2,306
You say built to his dock, but the stair will be underwater at times. So, I'm assuming that the dock will be underwater as well? The steps go from what to what exactly? This is where pictures really help.
Why not have them manufactured from aluminum?
Jon
jb4211 is offline
Old 02-06-2012, 09:50 AM   #5
Bob@efloor's Avatar
Trade: IPE, Massaranduba, Cumaru, Garapa Decking
Rewards Points: 25
I second this, unless you can source or create a hinge/floater setup on the stairs themselves come high tide so it purposely floats.
www.efloor.com
IPE Decking materials
Bob@efloor is offline
Old 02-06-2012, 10:00 AM   #6
jb4211's Avatar
FYI - regarding Ipe
Durability: Heartwood is very resistant to attack by decay fungi and termites, but not resistant to marine borers, it has the durability and strength of teak, for a lot less money.The US Department of Agriculture and Forestry rates Ipé as "Very resistant to attack by decay, fungi and termites."
Jon
jb4211 is offline
Old 02-06-2012, 12:27 PM   #7
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Rewards Points: 1,000
if its under water why not concrete?
Originally Posted by Greg Di View Post
Nothing you do as a professional should be for free. It's just a silly way of groveling for business if you think about it..
http://sacramentomillworks.com
Scribbles is offline
Old 02-06-2012, 01:32 PM   #8
I'm going to build off of this
I need more tools.
Old 02-06-2012, 01:33 PM   #9
This is what the customer wants
I need more tools.
Old 02-06-2012, 01:51 PM   #10
drywaller
Mudshark's Avatar
Trade: Drywall Finisher
Rewards Points: 75
Cool
Good point on "floating"
What about using steel for the structure for strength and weight and finish railings and steps with treated wood?
Just a thought - I assume this is fresh water and not salt water
Sorry to invade the Carpentry section but one of your senior posters booted me off the drywall section.
Mudshark is offline
Old 02-06-2012, 02:05 PM   #11
Dirtywhiteboy's Avatar
Rewards Points: 8,044
There are premade stainless steel stairs made just the purpose.
Dirtywhiteboy is offline
MALCO.New.York (02-06-2012)
Old 02-06-2012, 02:20 PM   #12
jb4211's Avatar
Attachment 65033
From the picture, that looks like p/t material.
Every project has a budget. What is your's? Did they specify a material?
FYI:
http://www.contractortalk.com/f4/how...ide-lake-4201/
Jon
jb4211 is offline
Old 02-06-2012, 02:53 PM   #13
mattsk8's Avatar
Trade: Building and remodeling
Rewards Points: 1,986
I was at a marina near Philly and the boat docks there all floated. The transition from the dock to land was attached using hinges on each end of a ramp. Super easy.
Just realized you wanted to fasten the steps permantly so I deleted half of my statement. The ramp worked well though. Some senior citizens at this marina and it didn't seem like anyone was struggling.
mattsk8 is offline
Old 02-06-2012, 03:10 PM   #14
Ok. The stairs will be made from pressure treated lumber. He wants what his neighbor has. (see pic) The dock had a floating ramp with wheels that will run up and down the stairs.The problem right now is the lake is so low his ramp is 15' from the normal shoreline. So he wants stairs to the lake bed to access the dock. I know how to build the stairs. I don't know if I need extra concrete around the posts or if I need some type of extra fastener to attatch the posts to the concrete to keep the steps in place. I plan on 1 80lb bag per post. It may not even be an issue. So the question is, Is there going to be an issue with the steps floating out of the ground when the water rises? And if it's an issue do I just need more concrete around the posts or what?
Old 02-06-2012, 05:12 PM   #15
It's a good suggestion to use steel. Unfortunately it's not in the budget and I don't weld so I can't build them. I can build with wood though.
Old 02-06-2012, 06:28 PM   #16
jb4211's Avatar
I think I'd definitely go over-kill here: much larger diameter holes and much deeper than normal, definitely more than 80 lbs.
I have more than 80 lbs holding each of my fence posts.
Jon
jb4211 is offline
Old 02-06-2012, 07:03 PM   #17
What would you recomend?
Old 02-06-2012, 07:10 PM   #18
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
16"x16"x48".
Also they have hydro cement that is made to stand up to being underwater and is non corrosive.
Probably isn't allowed by budget though.
I live on the water, but I just use a ladder!
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 02-06-2012, 07:11 PM   #19
robert c1's Avatar
Trade: remodeler/gc
Rewards Points: 288
It looks to me like the neighbors stairs haven't been asked the big question yet.....
robert c1 is offline
Old 02-06-2012, 07:25 PM   #20
jb4211's Avatar
Hard to say because I'm not familiar with the area, the environment, water table, soil conditions, etc.
I think it would be best to consult with contractors who specialize in dock building. I know I'd want to be as deep as possible - within reason. I'd "consider" 6x6 posts set in 16"-18" diameter holes about 50" deep and filled with concrete. I'd bolt the stringers to the 6x6 posts. All wood framing poly coated and at least .60 pcf for fresh water.
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
CanningCustom (02-06-2012)
2 Story Boat Dock Deck Restoration League City, Texas - Aqua Clean Pressure Wash PressureWashE Painting & Finish Work Picture Post 14 10-30-2016 08:00 AM
Dock Work - Helping client choose colors casey344 Carpentry 3 12-05-2011 05:54 PM
3 Doors At the top of the Stairs Docwhitley Framing 4 01-02-2011 08:36 PM
Boat Dock tigerpilot1995 General Discussion 1 05-28-2009 11:21 AM
Boat dock fettycan Decks & Fencing 6 06-01-2006 07:39 PM
