Trade: carpentry
Bifold Closet Door Bracket
How do you guys handle the bottom bifold door bracket, I'm talking new construction in a room to be carpeted. Install it before carpet, or after??? Most guys I know do it after, and most guys have had cases of the carpet catching the screw when installing, or cases of slight carpet buckle. Any tricks?????
Illusion of Perfection
Re: Bifold Closet Door Bracket
Most of them should have the ability to screw into the jamb in addition to the floor.
Do you mean "bi-pass"?
Yes, cut a small hardwood block, predrill and install it on top of the carpet, then attach the bracket to the block. G
I must be having brain fade.
The Johnson bi-fold brackets that I remember, mount on the jamb?
Yup, they have mounting holes both for the jam and the floor. i find when you just attach to the jam, over time the bracket settles, blocking up and securing to the block prevents that. G
The lighter weight tap in Johnson sets mount to the jamb. You can get a carpet riser for the Johnson bottom pivot bracket. The heavy weight Johnson sets mount to the floor and insert into pivot plates that are screwed onto the door, no tap in hole. And I also use a small block under them as Gene described.
Guess it's been a while since
I had any heavy ones.
KemoSabe
I always mount a 5/8" block to the floor, just slightly larger than the perimeter of the bracket. It gets mounted permanently and the carpet guys tack strip around it. Once completed, the block doesn't show and the bracket is solidly supported.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
Trade: general contractor
What he said
| The Following User Says Thank You to house bldr For This Useful Post: | Lubs (09-30-2009) |
| Venting a communications closet | flashheatingand | Low Voltage | 17 | 09-13-2009 09:37 PM |
| Bifold Door Hinges | orson | Finish Carpentry | 3 | 05-21-2009 06:06 PM |
| Closet door idea | jcalvin | Windows, Siding and Doors | 3 | 03-27-2009 11:32 PM |
| Need Help w/ a Bathroom, closet, and laundry layout in addition | TurnkeyConst | Remodeling | 8 | 12-16-2008 12:50 AM |
| Bifold door? | formulagamble | Finish Carpentry | 3 | 08-17-2008 07:40 PM |
