Best Way To Design This Roof Line....
Old 01-02-2009, 03:44 PM   #1
ruskent's Avatar
Trade: Outdoor D/B
Here is the deal. We are trying to design a masonry raised patio on the back of this house. We want the patio to be covered with a roof. The back of this house is alittle tricky and I know I need to figure out what is possible for the roof before I come up with any design for the patio.
We are looking to do around a 600 sq patio either square of rectangle and have it covered completly by the roof.
Client would rather have it off the back of the house on the right hand side. That room is a sunroom and has two sky lights that can not be covered up. The sunroom leads to the kitchen. That is why they would like the patio on that side of the house.
Do you guys have any idea on how to make this roof line work?
Best way to design this roof line....-backyard11q-002-p-.jpg   Best way to design this roof line....-backyard11q-006-p-.jpg
ruskent is offline
Old 01-02-2009, 03:50 PM   #2
Al Smith
A W Smith's Avatar
Re: Best Way To Design This Roof Line....
if your dropping the patio ceiling to just over the door and window heads you might just be able to squeeze a low pitch gable roof with the two valley's just missing the skylights. I would extend the shed onto the new lower roof so you don't have two pieces of gutter dieing into the roof as well
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-02-2009, 03:56 PM   #3
maceycon's Avatar
Could you just carry the shed roof on the sunroom out to the right and then have a matching roof going back toward the front making it a gable. I doubt I am explaining what I am thinking properly.
maceycon is offline
Old 01-02-2009, 04:02 PM   #4
Al Smith
A W Smith's Avatar
I think he means the patio is going to be where the steps are. Not on the right side, and why is that French door so much higher than the bottom of the band joist? looks almost like 20 inches. I sure hope by "Raised masonry patio" it doesn't mean above that T111 siding.
Al Smith
Old 01-02-2009, 04:03 PM   #5
genecarp's Avatar
Most roof applications will look like an add on, exactly what you dont want. It looks like you have about 12'' to the bottom of those windows on the 2nd floor, reduce that to 6'', reduce the shed roof pitch to a 3, and frame an entire new shed roof. The skylights will have to be reset, they will be higher. You may be able to accept 7' at the new roof end over the patio. The pitch and ht at the end of the rafter run will determine the width of the patio off the house. Keep the patio as low as possible, it will help the cause. G
genecarp is offline
Old 01-02-2009, 04:32 PM   #6
Burby's Avatar
Trade: Remodel / repairs / Certified Mold inspector, Remediator
Send a message via AIM to Burby
If you send me a pm so I don;t forget, early next week when I go to a sub division I have to do a service call in, I will take a pic of a similar house I did a large screen porch on, I will take a pic of the roof I designed & built and give you a real good idea of what to do, then you decide fro there. But had the same scenerio, limited space between 1st & 2nd floor windows for the size of the screen porch.
But anyhow, liek I said send me a message & if you can wait til wednesday morning I will send you a pic of what i did. I believe you can do the same or worst case scenerio build over that lil shed roof and just raise the tunnels of the skylight to the new roof line & leave them in place.
If you need it sooner, well dang, I could try & explain, but a pic sure is easier.
It looks great & does not look like an add on, which does take away from a home. Most I show the house to in order to offer ideas of what a roof will look like to other possible customers are surprised it was done 5 or 6 years after the house was built.
Proud to help make a house your Home
Never judge another by one's own intelligence
Burby is offline
Old 01-02-2009, 04:35 PM   #7
ruskent's Avatar
Trade: Outdoor D/B
Going over the shed roof and raising the sky lights seem to be the best option. I should be able to reuse the same skylights rights?
ruskent is offline
Old 01-02-2009, 04:37 PM   #8
genecarp's Avatar
Dont gaurantee using the same skylights, you wont know until you remove them.
genecarp is offline
Old 01-02-2009, 04:46 PM   #9
Al Smith
A W Smith's Avatar
They look like Velux FS model. you can salvage the skylight itself and replace the flashing kit for any pitch 3/12 or steeper. If it drops below that you will need a low pitch kit.
Al Smith
Old 01-02-2009, 04:58 PM   #10
ruskent's Avatar
Trade: Outdoor D/B
What would you recommend for the ceiling of the patio? What type of material? Would a flat ceiling or a vaulted ceiling make more sense?
ruskent is offline
Old 01-02-2009, 05:14 PM   #11
Aframe's Avatar
Trade: Carpenter/GC
Flat or vaulted will change the engineering on the roof, remember to keep that in mind when pitching the options.
Vaulted will give you more space for ceiling fans/ lighting options. T&G looks nice on porch ceilings.
Aframe is online now
Old 01-02-2009, 05:20 PM   #12
Al Smith
A W Smith's Avatar
whats in the budget? Azek edge and center bead? Vinyl beaded soffit? Vinyl max span? Pine edge and center? Sheet goods? Edge and center pine over exposed rough sawn rafters? Whats under the front entry porch now? or the soffits?
Al Smith
Old 01-02-2009, 05:33 PM   #13
ruskent's Avatar
Trade: Outdoor D/B
The front entry is getting replaced. I am thinking I'd like to do a pine bead board with a vaulted ceiling.
Just trying to figure out the basic design I want so the archiect can draw it up fast instead of giving me 4 different options.
ruskent is offline
Old 01-02-2009, 06:10 PM   #14
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extrordinaire
Something like this?
Andy.
ScipioAfricanus is offline
Old 01-02-2009, 06:45 PM   #15
ruskent's Avatar
Trade: Outdoor D/B
Andy.
Yea that is basically what we have to do.
ruskent is offline
Old 01-02-2009, 06:48 PM   #16
Professional Instigator
rbsremodeling's Avatar
I'd bang that out for a 120k for ya Rusk
rbsremodeling is offline
Old 01-02-2009, 07:05 PM   #17
ruskent's Avatar
Trade: Outdoor D/B
You think it should cost that much??
ruskent is offline
Old 01-02-2009, 07:13 PM   #18
Using only the finest materials of course
Old 01-02-2009, 07:38 PM   #19
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
I like Right Designs graphic.
One small thing to consider. Take a look at reducing the width of the new work so that corner on the left has better drainage.
Seems like an ice dam on the horizon.
Nice graphic though, pictures are worth a thousand words aren't they?
Gus Dering is offline
Old 01-02-2009, 09:45 PM   #20
Al Smith
A W Smith's Avatar
Andy.
Skylight wells will have to be closed up and moved as they were originally in the Vally's of this illustration, Or move them to the shed portion to simplify and shorten the skylight wells.
Al Smith
Ice Problems on a roof J-Peffer Roofing 4 10-01-2008 11:12 AM
question on flashing for a roof line 72chevy4x4 Roofing 8 05-17-2008 11:27 PM
Deck stairs with a roof?? workswithwood Decks & Fencing 5 05-13-2008 11:23 AM
A roof leak AbeBarker Roofing 8 02-18-2007 03:13 PM
Structurally Unstable Roof Pricing Question? APC Construction 14 02-01-2007 09:14 AM
