Trade: Builder, Additions, large remodels...Lately also small remodels.......
Best Way To Attach A Newel Post
What have you guys found to be the best way to attach a newel post at the foot of a strait flight of stairs?
We've tried several ways but I'm not too happy with most, they just don't feel all that strong. Every contractor I know just uses "L" brackets and calls it good but I'm not satisfied. One way we haven't used yet (because it's much more work than others) is heavy infloor framing with a piece of all thread up the inside. If I could find a good way with out having to go to this extreme I'd be happy. Tell my your secrets... |
General Contractor
Trade: General Contracting and Painting
Re: Best Way To Attach A Newel Post
We use this system http://www.westfiremfg.com/Suretite.gif
we dont buy the kits, found it eaiser to just buy the parts, from our local supplier. It works well very strong and we've never had a problem. Last edited by jensenconstruction; 04-02-2007 at 01:30 AM. |
#3 | |
Re: Best Way To Attach A Newel PostQuote:
i've also used the suretite hardware, I agree it's the best hardware option. Still though, no hardware option will ever be like having the newel post dropped into a joist bay. No hardware option will work well with larger kids or adults that like to use the railing to hold themselves up, the newel post simply has too much leverage over any possible hardware.
Professional
Trade: Finish Carpentry
http://crownheritage.com/main.cfm?pa...stall_hardware
http://www.ljsmith.com/lj-3008-10.html ![]() Use to mount newel posts on finished floor surfaces or Starting Steps. The Newel Mounting Kit is fully concealable. Use on finished floor surfaces, landings, and starting steps. ![]() The Keylock™ Newel Post Fastener is fully concealable. Use on finished floor surfaces, stairs, ceramic tile and concrete. ![]() Use to mount 3" to 3 1/2" newel posts on finished floor surfaces. Last edited by In_Mexifornia; 04-02-2007 at 09:43 PM. |
Ruler of the Universe
Trade: finish carpenter
A "J anchor kit" is stronger than any of the hardware pictured above. But since you asked about setting one at the foot of stairs, I recommend half notching the newel into the front of the riser. I use liquid nails and 3 inch screws. Drive one of the screws through the newel and into the front edge of the tread. This will be very strong.
If you must set the newel flush on a floor or on top of a tread, I use 4 rail bolts. This is much stronger than any of the hardware shown above and I have used them all many times, except the mounting plate one. |
Trade: Remodeling contractor
We always try to buy extra long posts & extend it into the floor framing. From underneath, you can cross frame & bolt the piss out of it. On a slab you have to use these Hardware gadgets. Lots of construction adhesive & glue never hurts either.
Back in Maine Dubbin' Around Doin' good stuff ...... |
Trade: drywall, painting, trim, finish and custom carpentry
agree that nothing beats going to the joists, but i have used a newel plate once (needs good framing/flooring!) and it blew me away. it was kind of tricky to get the post perfectly flush with the floor while still being perfectly lined up (because of a nearby post i had to tighten it by driving it perpendicular to the rail) sure was stiff though, but could be my memory chips are failing. spiral stair, if that matters.
