Best Trick You Learned From An Old Schooler
Old 05-10-2010, 09:04 PM   #81
Brett Ashworth
FrehouseRemdlin's Avatar
Trade: Remodeling, Additions, Repairs
Rewards Points: 75
Re: Best Trick You Learned From An Old Schooler
One i use frequently when doing a remodel. WHen pulling the casing around doors and windows, use a old drywall knife butted against casing ontop of the drywall, 8" or so to pry against, It will help disperse the pressure and wont mar up the drywall.
FrehouseRemdlin is offline
Old 05-10-2010, 09:09 PM   #82
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
when putting up soffit i use to cut one piece the length needed then put it on top of the full lenght scribe the length, cut it, mark cut repeat,
then an elder showed me to simply cut the first length put it on the length mark it, slip the pattern forward 1/8" scribe, repeat, so instead of spending 15 minutes cutting 10 pieces of soffit it only takes 3 minutes.
mind you ive switched from cutting it with snips to a slider with the blade backwards. we almost always use hidden perforated soffit which is alot harder to cut than the stuff which is a borderline strainer
woodworkbykirk is offline
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Brian Peters (07-12-2012)
Old 05-10-2010, 09:18 PM   #83
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,124
Originally Posted by Willie T View Post
Keep a sewing needle in your wallet. Heat it with a match and use it to painlessly (well almost) melt a tiny hole in a smashed finger nail to relieve the blood pressure.
Originally Posted by Gough View Post
We always use a really small drill bit and just twist it between thumb and forefinger of the other hand to drain the blood under a smashed finger.
I learned to do that with a red-hot paper clip, from a doctor when I was a kid. He had a "drill" designed just for that, but it was dull.
I was very pleased when he gave up on that and scorched me instead.
Tinstaafl is online now
Old 05-10-2010, 09:21 PM   #84
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Rewards Points: 1,000
Double the second number in a fraction to half it.
1/2=1/4
1/4=1/8
3/8=3/16
5/16=5/32 and so on.
Originally Posted by Greg Di View Post
Nothing you do as a professional should be for free. It's just a silly way of groveling for business if you think about it..
http://sacramentomillworks.com
Scribbles is offline
The Following 9 Users Say Thank You to Scribbles For This Useful Post:
csnell (08-03-2010), Custom Builder (04-19-2014), dnconstruction (05-12-2010), grayman74 (05-21-2010), McGyver911 (05-16-2017), RiverBG (03-08-2015), rpwild (07-24-2014), SamM (06-07-2010), T&S contracting (10-04-2010)
Old 05-10-2010, 09:24 PM   #85
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
Send a message via AIM to ApgarNJ
i had to use the hot paper clip a few weeks ago. but not from me smashing my finger but because it got smashed between the coil gun i had in my had and the one that fell out of the cabinet in the dark, loading my truck up one morning. that really hurt. but i never lost the nail.
ApgarNJ is offline
Old 05-10-2010, 10:05 PM   #86
galla35's Avatar
Rewards Points: 250
i still dont understand the carpenters knot thing
In the 80's we had Reagan in office, Bob Hope, and Johnny Cash. Now, we have President Obama, no hope and no cash
galla35 is offline
Old 05-10-2010, 10:25 PM   #87
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
Say you want to pull a string tight from where it is fastened 50' away to a board in front of you.
The first thing you do is drive a 6d or 8d nail in the board at an angle slanting away from the starting location of the string.
Secondly, you double over the string you have in your hand, making a simple loop.
Third, still holding the string in the hand closest to the start 50' away, you take your index finger of the other hand and stick it through the loop.
You twirl your index finger around about a half dozen times, twisting the base of the loop till it looks sort of like a hangman's noose.
Now you slip that twisted loop off your finger onto the nail.
Next, with one hand, you pull the long 50' line tight... toward the nail... while at the same time you pull the loose end of the sting coming from the loop in the opposite direction... TOWARD the start and away from the nail........ Both hands are moving in opposite directions at the same time, taking up all the slack and tightening the long line.
When the long line is as tight as you need it, and your other hand has pulled all the slack out of the twisted loop, you QUICKLY jerk the hand holding the loose end back right past the side of the nail.
This causes all the twists to slip over each other and bundle up against the slanted nail, locking the loop in place.
This holds just fine.
When you want it loose, you grasp the slack end, and snap it back toward the tightened part of the line. The loops un-bundle, and as you let the line slip through your hand, the tension releases, and you can lift the loop right off the nail.
The string has now returned to normal.
Only 3 things to remember....
The nail has to be slanted with the head angling away from the fastened end of the string. 15 - 20 degrees is OK.
One hand has to be taking up the slack through the loop at the very same time, and in coordination with the other hand pulling the long part of the string tight from where it is fastened way down there. (kind of like tightening your necktie on your neck... one hand pulls up on the knot while the other hand pulls down on the small part of the tie) Think of your neck as being the nail in the board.
The SNAP back has to be QUICK and FIRM... and you MUST snap back PAST the nail, keeping the line tight in your hand. This movement creates the LOCK.
I tried my best to find a video of this knot. But I guess because it is such a simple, simple, simple thing to do in a couple of seconds, no one has bothered to make a video of it.
Nothing to it at all. Twist the loop, and pull then snap.
Done, walk away.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
The Following 3 Users Say Thank You to Willie T For This Useful Post:
bhock (05-10-2010), C.M.J. (05-10-2010), wallmaxx (05-11-2010)
Old 05-10-2010, 11:25 PM   #88
Cjeff's Avatar
Trade: Renovations
Big one if you are recklessly working on a plywood roof with no teather......................
Sharpen the claws of your ripping hammer. This "Safety Brake System" has saved the life of almost everyone I know at one time or another (including me). And it also comes in handy to reach down and snag the side of a heavy beam.
Sure, ya gotta repair the hole in the plywood.... but you're alive!
Yep this works!!!!!! Had to use it once. Straight claw hammers are the best
Also never trust a nail put in a roof jack by someone else, it is your life on it!!!!!! Learnt that when had to do the above as the board let go under me.
When wanting to snap a chalk line on an angle the hook will not stay in place. Make a small knife cut on the edge and put the string in it.
Cjeff is offline
Old 05-11-2010, 12:08 AM   #89
boman47k's Avatar
Rewards Points: 2,006
Miss a stud with a dw screw, and it does not want to back out? I use my 5-n-1 under the head and slightly pull backward as I reverse my screw gun.
boman47k is offline
Old 05-11-2010, 09:56 AM   #90
How can I help you?
SAH's Avatar
Trade: General contracting, Toronto Canada
Rewards Points: 150
Lots of good tips, many I use currently. I'll try and remember if theres any that have been missed here while I'm working.
Oh ya, leave the cell in the truck unless your wife or g/f is expecting any day now. Theres no phone call that cant wait 2 or 3 hours until break time.
SAH is offline
Old 05-11-2010, 10:03 AM   #91
boman47k's Avatar
What if both ar expecting anytime??
boman47k is offline
The Following 2 Users Say Thank You to boman47k For This Useful Post:
dnconstruction (05-12-2010), willdurant (08-09-2010)
Old 05-11-2010, 10:11 AM   #92
galla35's Avatar
Rewards Points: 250
Some one needs to make a video of the Knot :P im a visual learner..
galla35 is offline
The Following User Says Thank You to galla35 For This Useful Post:
boman47k (05-11-2010)
Old 05-11-2010, 10:18 AM   #93
General Contractor
Willie T's Avatar
Rewards Points: 12
Don't have a nail set handy? Don't try to set that nail with the point of a bigger nail; you'll slip off nine times out of ten.
Instead, solidly grip a headed nail by the shaft, placing the edge of the head over your flush finish nail head, and tap on the other side of the big nail head. The hole will be kind of rectangular, so align it with the grain if you can, and it will be much less noticeable.
Willie T is offline
The Following User Says Thank You to Willie T For This Useful Post:
waterman1971 (03-04-2011)
Old 05-11-2010, 10:21 AM   #94
General Contractor
Willie T's Avatar
Rewards Points: 12
I have a video feature on my camera, but I've never used it... and I would have no idea how to get it on this forum.
Willie T is offline
Old 05-11-2010, 10:26 AM   #95
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
Best tip from the first carpenter I worked for " Don't hit your thumb"
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 05-11-2010, 10:35 AM   #96
boman47k's Avatar
Or don't hit the wrong nail!
boman47k is offline
Old 05-11-2010, 10:46 AM   #97
General Contractor
Willie T's Avatar
Rewards Points: 12
Need to cut an arch for a door way or an opening, but the radius point would end up somewhere out in the front yard?
Simply stand a sheet of plywood on edge (might have to tack it to a stud), and mark your width on the top edge.
Hang a string line sagging down from the two marks. Feed string out, or take it in till you get the look you want. Then just follow the string with pencil marks.
The arch will end up balanced and smooth for most shallow arches. Of course you can't let the string loop hang too far down or it will really look strange.
Bending 1/2" PVC pipe will do an acceptable job on larger arches, too.
Willie T is offline
Old 05-11-2010, 01:31 PM   #98
How can I help you?
SAH's Avatar
Rewards Points: 150
I'd call you courageous as I know I couldnt handle that LOL
SAH is offline
Old 05-11-2010, 01:32 PM   #99
How can I help you?
SAH's Avatar
Rewards Points: 150
upload the video to one of those free hosting websites like youtube. then post the link to it here.
SAH is offline
The Following User Says Thank You to SAH For This Useful Post:
Reg (01-12-2014)
Old 05-11-2010, 01:55 PM   #100
Bird Killer
displacedtexan's Avatar
Trade: Custom Trim/Remodel
Rewards Points: 150
Always put tools where they belong at the end of the day (Seems simple, but so many don't do it, 15 min at the end of the day saves an hour the next day.)
Keep stair gauges on the framing square. (Saves looking for them.)
displacedtexan is offline
Tags
tricks of the trade
Simple Old Trick for Finding Centers... basswood Finish Carpentry 9 10-03-2010 07:58 PM
trick lookin drip system wopachop Landscaping 1 09-29-2010 02:08 AM
Beware of this trick cleveman Off Topic (Non Trade) 3 04-17-2009 10:16 AM
Learned to post pics SAcarpenter Carpentry Picture Post 2 10-16-2008 08:28 PM
Learned A New Trick Today CJKarl Masonry 8 06-28-2008 07:33 AM
