Best Trick You Learned From An Old Schooler
Old 05-10-2010, 01:54 PM   #41
Birch's Avatar
Rewards Points: 1,050
Re: Best Trick You Learned From An Old Schooler
I heard an old timer call this trick a “Dutchman’s Corner”. It is used to join two “close, but not equal” width boards at a 90 with 45 deg miters. Just flush the short points and trim the long point to match the outer 90. There is an old German Café locally that has many antique dining tables that feature these miters. They can also be used to make up for minor mistakes in fascia joints and other common miters by sliding the miters and trimming. Useful on painted interior trim and works for other angled miters too.
Birch is offline
The Following User Says Thank You to Birch For This Useful Post:
Jaws (01-02-2014)
Old 05-10-2010, 02:24 PM   #42
Rewards Points: 2,000
Originally Posted by Willie T View Post
A thousand things. But right now here are just three pertaining to string:
1. Get another person to push down on the center of a long chalk line.
2. Use two 'offset' blocks and a guage block of the same size when stringing a fascia.
3. Lock your lines to nials with the '5 or 6 twist method', and they will come right off in a half second when you need them to... and not before.
Originally Posted by TBFGhost View Post
Share Please...no one ever taught me anything about that...
I know that as the Engineer's Hitch.
Picked it up doing site layout as a way
to hold string line on the engineer's tacks.
Loop around your finger, hold both the
standing and running ends with the other hand,
and twist 3 or 4 times.
Drop the loop over the tack (or nail or stake),
pull tight on the running end, then jerk it back
toward the tack til it bites, and loop it back around
toward the standing end.
I could show you in 2 seconds......
neolitic is offline
Old 05-10-2010, 03:12 PM   #43
Finish carp.
Old Grumpy's Avatar
Trade: Finish carpentry
Rewards Points: 79
Lipstick. Old ugly lipstick your wife, girlfriend, daughter, etc. bought, tried and abandoned forever. Use it on the end of latches and deadbolts to get an exact location for the recieving hardware. Bright clean crisp mark when you learn how little to put on. Particularly useful when retro fitting a deadbolt to an existing door.
Only trick I know. I thought everything else was just how you did things. Probably means I've been doing this too long.
Ignorance is cureable, stupidity is forever.
Old Grumpy is offline
Old 05-10-2010, 03:28 PM   #44
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Work 40 hrs per week.
Get rid of the 28 oz hammer.
griz is offline
wallmaxx (05-10-2010)
Old 05-10-2010, 03:38 PM   #45
Finishing Carpenter
Mrmac204's Avatar
Trade: finishing Carpenter
Rewards Points: 720
Birch, can you elaborate? I can't seem to quite get my head around this technique.
thanks!
Laurie.
Mrmac204 is offline
Old 05-10-2010, 04:11 PM   #46
DN Construction
dnconstruction's Avatar
Trade: Construction
Rewards Points: 150
Would love to try it but I will not carry any lipstick on me or in my trailer because of the harassment I would receive. I just get a lot of pencil graphite on it and that seems to work ok for me!!
Saw dust runs everywhere
dnconstruction is offline
Old 05-10-2010, 04:13 PM   #47
DN Construction
Trade: Construction
Rewards Points: 150
I really think the radius with a string line and a nail in the center, with the other end wrapped around your pencil was a nice trick. Specially looks nice when you can bang out a radius in 30 seconds and some math
Old 05-10-2010, 04:28 PM   #48
boman47k's Avatar
Rewards Points: 2,006
Originally Posted by Scribbles View Post
#1 Burn an inch
#2 how to lay out a perfect oval.
Both from the best carpenter I ever knew, and have the lumps on the back of my head to prove it.
Care to elaborate?
boman47k is offline
Old 05-10-2010, 05:00 PM   #49
user38755's Avatar
Rewards Points: 250
I keep both ends of my pencil sharpened so I never have the wrong end.
user38755 is offline
The Following 4 Users Say Thank You to user38755 For This Useful Post:
Cadgal (05-17-2010), Metro M & L (05-14-2010), Tom Struble (05-15-2010), wallmaxx (05-10-2010)
Old 05-10-2010, 05:25 PM   #50
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
How could I have forgotten about burning an inch. It's almost second nature to me.
The oval with the nails and string?
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
Old 05-10-2010, 05:28 PM   #51
General Contractor
Willie T's Avatar
Rewards Points: 12
Don't forget about keeping a bar of soap in your pouch to scrape the threads of your screws against when installing windows.
Willie T is offline
Old 05-10-2010, 05:31 PM   #52
boman47k's Avatar
The burn one inch thing has me scratching my head now.
boman47k is offline
Old 05-10-2010, 05:34 PM   #53
I use bee's wax.
Pour it into cupcake papers, and
a bit in a 1/4" hole drilled into the
end of my hammer handle.
neolitic is offline
Old 05-10-2010, 05:36 PM   #54
For me it is "cut a foot."
neolitic is offline
Old 05-10-2010, 05:39 PM   #55
General Contractor
Willie T's Avatar
Rewards Points: 12
It means that for exact measuring, you begin with the 1 inch mark on the START line, and measure from there.... then subtract 1 inch.
EXAMPLE start at 1 inch and measure out 11 inches for an exact 10 inches.
Willie T is offline
Old 05-10-2010, 05:46 PM   #56
General Contractor
Willie T's Avatar
Rewards Points: 12
Keep a sewing needle in your wallet. Heat it with a match and use it to painlessly (well almost) melt a tiny hole in a smashed finger nail to relieve the blood pressure. It usually keeps you from losing the nail. Keeps it from getting all black and ugly too.
Also, a spent match (cooled off) will attract dust and trash from the surface of your eyeball. Just touch the offending foreign matter with the head of the match.
Keep an eye-washing cup in the truck glove box.
Willie T is offline
The Following 3 Users Say Thank You to Willie T For This Useful Post:
neolitic (05-10-2010), oktex56 (06-12-2012), Reg (01-12-2014)
Old 05-10-2010, 05:50 PM   #57
General Contractor
Willie T's Avatar
Rewards Points: 12
I think I've shown this one before.
Best trick you learned from an old schooler-straighten-studs-1.jpg   Best trick you learned from an old schooler-straighten-studs-2.png
Willie T is offline
The Following 2 Users Say Thank You to Willie T For This Useful Post:
builder2345 (08-25-2012)
Old 05-10-2010, 05:57 PM   #58
General Contractor
Willie T's Avatar
Rewards Points: 12
Because of their 'tear drop' shape you can use your chalk box for a makeshift plumb bob.
Willie T is offline
Old 05-10-2010, 05:58 PM   #59
boman47k's Avatar
Hahaha, I feel a little ignorant now. I do that if I want a more accurate measurement. I was thinking of some reason why someone would char the end of a board or something.
I have been known to hang on to a tape ruler when I know the tip may not be quite right.
boman47k is offline
Old 05-10-2010, 05:59 PM   #60
General Contractor
Willie T's Avatar
Rewards Points: 12
Always reverse your level to check the bubble both ways if you are not perfectly certain you're using a good level.
And a 4' level on a stack of concrete blocks makes a pretty accurate "dumpy" builder's level when nothing else is available... sight down it like a rifle.
Also, learn to make a water level... one day it may just become the most valuable tool on the site when the batteries go south on the laser. (I carry one in my truck at all times. Yes I use it every now and then.)
Willie T is offline
JustaFramer (05-15-2010), wallmaxx (05-11-2010)
Tags
tricks of the trade
Simple Old Trick for Finding Centers... basswood Finish Carpentry 9 10-03-2010 07:58 PM
trick lookin drip system wopachop Landscaping 1 09-29-2010 02:08 AM
Beware of this trick cleveman Off Topic (Non Trade) 3 04-17-2009 10:16 AM
Learned to post pics SAcarpenter Carpentry Picture Post 2 10-16-2008 08:28 PM
Learned A New Trick Today CJKarl Masonry 8 06-28-2008 07:33 AM
