Best Trick You Learned From An Old Schooler
Old 05-09-2010, 10:44 PM   #21
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Re: Best Trick You Learned From An Old Schooler
Originally Posted by gdwoodbutcher View Post
I learned that the mark you leave on wood with your hammer is called a donkey track, because only an *** would do it!!!
I just learned that now...and I like it
TBFGhost is offline
Old 05-09-2010, 10:52 PM   #22
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,254
I wish I would have paid attention when they said be a lawyer.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
J M J (06-21-2012), Tom Struble (05-15-2010)
Old 05-09-2010, 11:00 PM   #23
jchomes's Avatar
Trade: residental contractor
Rewards Points: 75
we call the 16 penny nail trick to hold some thing the 20 k year it will make up for a labor and doesnt talk back great trick marking sheating to rip rough or dry wall hold your tape with thumb on # and pensil on end let er fly, hammer drill 1/4 hole slam two galvy 16 same time to hold plates to concrete. any trick helps production goes in the vault
jchomes is offline
Old 05-09-2010, 11:03 PM   #24
gdwoodbutcher's Avatar
Trade: carpenter cont.
When fastening 1x or 2x w/adhesive to block or concrete, if you don't have shot or anchors, drill 3/16 hole thru wood into concrete. Nail with either two 8 penny or one 16 penny w/pc tie wire . Holds tight untill adhesive sets. Today, with treated lumber, I suppose chemical would eat nails, but I never had a problem. Only used it interior. I don't think it's a big secret, but, whenever I do it around younger guys, they look stunned. Guess I'm gettin' old.
gdwoodbutcher is offline
Old 05-09-2010, 11:11 PM   #25
jeffatsquan's Avatar
Trade: builder/renovator,Squam Lake NH
Rewards Points: 250
Around here they are called PECKER TRACKS.
Their is a local guy named Dick Prince.
So now his nick name is (pecker tracks)
Get it dick prints same as pecker tracks
jeffatsquan is offline
The Following User Says Thank You to jeffatsquan For This Useful Post:
Seahawk (03-23-2015)
Old 05-09-2010, 11:18 PM   #26
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
Find a woman that loves to cook
Do your serious drinking at home
Don't put off your oil change
Swing hard in case you hit it
Gus Dering is offline
The Following 11 Users Say Thank You to Gus Dering For This Useful Post:
CScalf (05-06-2013), Grant9454 (09-11-2013), Jaws (01-02-2014), jb4211 (08-14-2012), MAD Renovations (05-09-2010), otislilly (06-02-2012), rpwild (07-23-2014), SK Remodeling (06-21-2010), tcholdren (05-10-2010), TNM (05-15-2013), willdurant (08-09-2010)
Old 05-09-2010, 11:26 PM   #27
Carpenter/Finisher
john5mt's Avatar
Rewards Points: 1,382
if you dont have a tapcon but need to attach something to concrete drill a hole in the concrete then take a wedge of wood and slam it in there with your hammer till the hole is full of wood. Then you can screw somthing to it with a wood screw.
it will hold quite a bit for quite a long time.
1st Gen tradesman
My summer job in college became my profession
john5mt is offline
Old 05-10-2010, 12:25 AM   #28
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Rewards Points: 1,000
#1 Burn an inch
#2 how to lay out a perfect oval.
Both from the best carpenter I ever knew, and have the lumps on the back of my head to prove it.
Originally Posted by Greg Di View Post
Nothing you do as a professional should be for free. It's just a silly way of groveling for business if you think about it..
http://sacramentomillworks.com
Scribbles is offline
The Following User Says Thank You to Scribbles For This Useful Post:
dnconstruction (05-10-2010)
Old 05-10-2010, 01:19 AM   #29
send_it_all's Avatar
Never trust a fart.
Never waste a boner.
send_it_all is offline
Old 05-10-2010, 02:19 AM   #30
LEVELBEST's Avatar
Trade: Contractor, Trim Dude, and Custom Cabinet Maker
Rewards Points: 250
Making a mistake is inevitable.......being able to fix the mistake is skill. If you learn early on that you can fix most of your mistakes you will be a much better carpenter.
That is not to say go with that attitude that you can screw up and worry about it later.......but rather to not be scared to trust yourself and what you think might be a good idea.(Again, not necessarily meaning a good idea to cut corners)
LEVELBEST is offline
The Following 3 Users Say Thank You to LEVELBEST For This Useful Post:
Bradyn (05-12-2014), Reg (01-12-2014), Willy1959 (01-05-2014)
Old 05-10-2010, 07:36 AM   #31
D.Foster's Avatar
Trade: Carpentry & Remodeling
The simple act of making a story stick.
The simple task of making a perfect scribe.
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
The Following 2 Users Say Thank You to D.Foster For This Useful Post:
Sir Mixalot (05-13-2010), Willie T (05-10-2010)
Old 05-10-2010, 07:51 AM   #32
Working
Cole82's Avatar
Rewards Points: 2,276
Send a message via AIM to Cole82
When a tapcon strips outand doesn't hold. Take a short piece of solid copper wire anything from 14-10gauge. Slide it in the hole then screw the tapcon back in. Holds tighter than you have ever seen.
Cole
The boss of awesome
Cole82 is offline
The Following 12 Users Say Thank You to Cole82 For This Useful Post:
ApgarNJ (05-10-2010), App-ironworks (05-15-2011), dkillianjr (05-11-2010), Grogan14 (02-20-2015), JackP23 (01-02-2013), jb4211 (08-14-2012), joe dirt (06-23-2010), MAD Renovations (05-10-2010), mnjconstruction (05-10-2010), Remodelor (11-18-2010), TheDoorGuy (01-22-2011), TIGHTER MITER (07-30-2012)
Old 05-10-2010, 08:53 AM   #33
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
A thousand things. But right now here are just three pertaining to string:
1. Get another person to push down on the center of a long chalk line.
2. Use two 'offset' blocks and a guage block of the same size when stringing a fascia.
3. Lock your lines to nials with the '5 or 6 twist method', and they will come right off in a half second when you need them to... and not before.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
The Following 2 Users Say Thank You to Willie T For This Useful Post:
oktex56 (06-12-2012), pinwheel (05-10-2010)
Old 05-10-2010, 08:59 AM   #34
Cjeff's Avatar
Trade: Renovations
Keep your tools organized, easier to spend 5 mins putting them away then 30 looking for them.
Cjeff is offline
The Following 7 Users Say Thank You to Cjeff For This Useful Post:
CarrPainting (12-27-2010), InsideandOut (01-18-2011), jslusher (08-22-2012), KEPC (01-27-2011), rock-it man (06-21-2010), SAH (05-11-2010), wallmaxx (05-10-2010)
Old 05-10-2010, 09:58 AM   #35
Gough's Avatar
Trade: painting
Some of them have become second nature, so it's hard to remember. I think I learned to mark with a carat, instead of a line, from my first employer some 40+ years ago.
1. Using mason's line blocks, rather than nails, to string siding courses.
2. Story poles.
3. Coping trim with a disc grinder.
Gough is offline
Old 05-10-2010, 10:20 AM   #36
Finish Carpenter
TBFGhost's Avatar
Share Please...no one ever taught me anything about that...
TBFGhost is offline
Old 05-10-2010, 10:51 AM   #37
Finishing Carpenter
Mrmac204's Avatar
Trade: finishing Carpenter
Rewards Points: 720
yup, i twist 6-7 times, then pull it onto itself. Comes off in a second I'll let Willie s'plain it to ya, he's better at that than me.
We've sorta done a tricks/methods blog before, but it's always fun and sometimes new stuff shows up.
stripped out holes in a door jamb from a hinge- drill it a little big bigger, then lightly hammer a wood golf tee in. cut it off, and you are good to go.
when measuring corners with a digital measurer- figure out beforehand where your machine is set at. Is it "0" folded up? or "0" out flat? it makes a difference in the number displayed.
Mrmac204 is offline
Old 05-10-2010, 11:11 AM   #38
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,702
Originally Posted by woodworkbykirk View Post
when toenailing the floor ribbon to the mudsil with a gun, flush up your lumber with the outside edge then drive your cats paw into the sil flush with the ribbon then nail, this will keep the riboon from being drawn in which you would otherwise have to beat back into place
I always just hold it out a little , shoot it . then hit with the hammer til it is flush.
knucklehead is offline
Old 05-10-2010, 12:18 PM   #39
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Rewards Points: 538
"if you want something done right then do it yourself."
"you don't need help, you've got a deadman."
go against the grain in life, but not with wood.
yeah, "doctors and lawyers and such"
Guilford, CT Remodeler and Carpenter Web-site Twitter@CraftsmanJay
Facebook
The great use of life is to spend it for something that will outlast it.
William James is offline
Old 05-10-2010, 01:04 PM   #40
Champion Thread Derailer
Jeff G's Avatar
Trade: Home Renovations
Rewards Points: 380
I took heed in what an "old timer" once told me - "There's not a single problem in the whole wide world.... that a good, stiff drink.... can't make worse!"
Seriously, there are so many tips I've picked up throughout the years, but I believe some of the best tips I ever got were; Try and always keep in mind to figure out ways (or pick them up along the way) to work smarter, not harder in everything we do. And never fail to ask questions if you don't fully understand something.
And never pass the buck when it comes to safety, because it isn't a one person job. Each of us should be responsible for the next person who uses the tools, materials, or equipment we've prepared or used.
Jeff G is offline
Tags
tricks of the trade
Simple Old Trick for Finding Centers... basswood Finish Carpentry 9 10-03-2010 07:58 PM
trick lookin drip system wopachop Landscaping 1 09-29-2010 02:08 AM
Beware of this trick cleveman Off Topic (Non Trade) 3 04-17-2009 10:16 AM
Learned to post pics SAcarpenter Carpentry Picture Post 2 10-16-2008 08:28 PM
Learned A New Trick Today CJKarl Masonry 8 06-28-2008 07:33 AM
