Best Trick You Learned From An Old Schooler
Old 05-09-2010, 04:24 PM   #1
DN Construction
dnconstruction's Avatar
Trade: Construction
Rewards Points: 150
The other day I was building a set of temp stairs for a contractor to get his C O. In Jersey you have to build a set going from the garage to the house and out the back from the house to grade level (in this case no deck was built yet). While doing this I was flipping over my 10 galv finish nails dulling the point then driving it in to prevent splitting of the 5/4 decking on the ends. I thought how I learned this a few years back from an old school guy and it was probably one of the most important tricks of the trade I have learned. I am a youngin so don't laugh on me for learning it only a few years back. My down fall is that I opened my own bus 5 years ago so I rarely get to learn any other tricks like this, but I thought it would be a great thread on here. So, what tricks have you learned from an old schooler that you can't live without?
Saw dust runs everywhere
dnconstruction is offline
Old 05-09-2010, 04:34 PM   #2
Hardly Working's Avatar
Rewards Points: 808
Re: Best Trick You Learned From An Old Schooler
Back when I was just a kid my grandfather use to run his finish nails through his hair to grease them up to drive smoother through hard woods. He use to use VO5 from back in the day when greased back hair was the thing.
Who remebers the DA and I don't mean like Dual Action sander.
What did term DA refer to anybody?
Hardly Working is offline
Old 05-09-2010, 04:38 PM   #3
Rewards Points: 2,000
Your Grandpa wore a duck's ass.
We woulda called him a greaser.
neolitic is offline
Old 05-09-2010, 04:43 PM   #4
Full Service Renovations
MAD Renovations's Avatar
I was taught that I must continue to learn......
MAD Renovations is offline
The Following User Says Thank You to MAD Renovations For This Useful Post:
GrasshopperPete (05-10-2010)
Old 05-09-2010, 04:45 PM   #5
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
Another trick is you can turn the nail so the chiseled end is going perpendicular to the grain instead of parallel, less likely to split then. I pre-drill holes in ends of decking though.
One trick I liked from an old timer is the doubler. Hand drive two 16d nails so that they cross eachother when driven in. It holds and sucks everything in way better than just a single nail.
kenparsonscontracting.com
KennMacMoragh is offline
Old 05-09-2010, 04:54 PM   #6
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,471
When trying to drive a nail into a hanger in a tight spot, push the nail through a piece of paper or cardboard, hold the cardboard with your fingers and pound the nail in. Saved many a finger.
Easy Gibson
Warren is online now
The Following 19 Users Say Thank You to Warren For This Useful Post:
ajabbott88 (11-27-2013), algernon (05-15-2010), ArtisanRemod (01-06-2013), Bradyn (05-12-2014), conductor (10-27-2017), CScalf (05-06-2013), davy crockett (08-18-2010), HomeFrame (05-05-2015), Jaws (11-10-2011), Jeremiah2911 (09-03-2014), jslusher (08-22-2012), Metro M & L (05-13-2010), n8creative (09-07-2012), oktex56 (06-12-2012), RiverBG (03-08-2015), rolfeman02 (05-30-2010), ROVACON (06-30-2010), SamM (06-07-2010), wncbuilder (11-20-2010)
Old 05-09-2010, 04:57 PM   #7
mdshunk's Avatar
Rewards Points: 2,002
I do that sometimes with a shim shingle.
One that I use nearly every day, and would not know unless someone taught me, is to draw a little "V" when marking measurements on a board instead of a little line. Much more accurate.
mdshunk is offline
The Following 3 Users Say Thank You to mdshunk For This Useful Post:
fshrmn (08-23-2012), oktex56 (06-12-2012), SK Remodeling (06-21-2010)
Old 05-09-2010, 05:00 PM   #8
Geometrist
Warren's Avatar
We call that a "crows foot"
Easy Gibson
The Following 2 Users Say Thank You to Warren For This Useful Post:
IrishAsh (05-08-2013), JSM_CC (08-09-2012)
Old 05-09-2010, 05:09 PM   #9
needle nose pliers work
The Following User Says Thank You to KennMacMoragh For This Useful Post:
Old 05-09-2010, 05:46 PM   #10
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
I learned the whole dull the nail trick in 6th grade woodshop...never understood why it worked
TBFGhost is offline
Old 05-09-2010, 05:58 PM   #11
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
when toenailing the floor ribbon to the mudsil with a gun, flush up your lumber with the outside edge then drive your cats paw into the sil flush with the ribbon then nail, this will keep the riboon from being drawn in which you would otherwise have to beat back into place
woodworkbykirk is offline
Old 05-09-2010, 06:08 PM   #12
Because you're pushing the wood fibers down to the bottom of the hole. If the nail is sharp, you're spreading the wood apart, making it likely to split.
The Following 4 Users Say Thank You to KennMacMoragh For This Useful Post:
cowboysdad (01-04-2014), dagumol (01-06-2011), dreamhomenj (08-26-2014), FGCC (01-05-2014)
Old 05-09-2010, 06:14 PM   #13
DeCloud's Avatar
Trade: Trim and Finish Carpenter
I am a trim finish carpenter ome pretty useful trick I learned was if a raw piece of finish grade piece of material has an imperfection such as a hammer mark or other indention, is to rub your saliva on it. Within about a half hour the wood will swell and can be lightly sanded afterward leaving no scarring.
DeCloud is offline
The Following 4 Users Say Thank You to DeCloud For This Useful Post:
music9704 (03-03-2014), oktex56 (06-12-2012), rdr8887 (07-17-2012), Reg (01-12-2014)
Old 05-09-2010, 07:03 PM   #14
LRG WoodCrafting
Leo G's Avatar
Trade: Woodworker Extraordinaire
Rewards Points: 10,145
If you have an air nail that doesn't set you can take the nails out of the gun and center the gun on top of the nail and fire again. It'll push it below the surface.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 28 Users Say Thank You to Leo G For This Useful Post:
ApgarNJ (05-10-2010), ArtisanRemod (01-06-2013), bbgcarpentry (05-11-2010), Cjeff (05-10-2010), Conquer671 (07-01-2010), cowboysdad (01-04-2014), CScalf (05-06-2013), D.Foster (05-10-2010), datrder (09-20-2012), davy crockett (08-18-2010), dreamhomenj (08-26-2014), IrishAsh (05-08-2013), J M J (06-21-2012), JackP23 (01-02-2013), Jaws (11-10-2011), Jeremiah2911 (09-03-2014), john5mt (05-09-2010), jslusher (08-22-2012), Jspence (05-11-2013), Mrmac204 (05-10-2010), neolitic (05-09-2010), openhearth (05-06-2013), RCT (08-17-2010), rdr8887 (07-17-2012), sosaobed (12-25-2016), TNM (05-07-2013), Tom Struble (05-15-2010), Willy1959 (01-05-2014)
Old 05-09-2010, 07:37 PM   #15
DN Construction
Trade: Construction
Rewards Points: 150
great so far keep lets keep em coming, I am going to try that wood and the spit tomorrow for sure
Old 05-09-2010, 07:39 PM   #16
Finish Carpenter
TBFGhost's Avatar
yeah I learned that from my Micro pinner...great trick, wish I had known that sooner..
TBFGhost is offline
Old 05-09-2010, 07:46 PM   #17
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
When I was about 15, working with my father, we scraped a 100+ year old tin roof that had been painted several times and then coated with tar several more, with 2" putty knives in August. It was probably 4-5 hundred square feet. Took it down to bare metal, patched the rust-throughs and recoated with black roof coating.
I learned from that experience, that I never wanted to do that again.
loneframer is offline
The Following 5 Users Say Thank You to loneframer For This Useful Post:
A-1 Interiors (07-28-2012), dagumol (01-06-2011), MAD Renovations (05-09-2010), SK Remodeling (06-21-2010), TempestV (06-26-2010)
Old 05-09-2010, 07:51 PM   #18
oldfrt's Avatar
Rewards Points: 94
A little trick when working alone and
hanging joists in an open span is to drive
a #8 or #10 nail about 1/2" in from one end and bend it parallel to the joist.
This will hold that end up while you nail the other end.
oldfrt is offline
The Following User Says Thank You to oldfrt For This Useful Post:
Old 05-09-2010, 09:37 PM   #19
gdwoodbutcher's Avatar
Trade: carpenter cont.
I learned that the mark you leave on wood with your hammer is called a donkey track, because only an *** would do it!!!
gdwoodbutcher is offline
The Following 2 Users Say Thank You to gdwoodbutcher For This Useful Post:
sosaobed (12-25-2016), WilsonRMDL (05-15-2010)
Old 05-09-2010, 09:39 PM   #20
LRG WoodCrafting
Leo G's Avatar
Elephant prints.
Carpenter by day.
http://lrgwood.com
Leo G is online now
stevethepirate (06-03-2012)
Tags
tricks of the trade
Simple Old Trick for Finding Centers... basswood Finish Carpentry 9 10-03-2010 06:58 PM
trick lookin drip system wopachop Landscaping 1 09-29-2010 01:08 AM
Beware of this trick cleveman Off Topic (Non Trade) 3 04-17-2009 09:16 AM
Learned to post pics SAcarpenter Carpentry Picture Post 2 10-16-2008 07:28 PM
Learned A New Trick Today CJKarl Masonry 8 06-28-2008 06:33 AM
