Trade: Carpentry General Home Improvements
Best Method To Replace A Window With Vinyl Siding
A customer wants to replace thier current windows that are old and cracking up with new vinyl replacements. The current windows are builders grade new construction vinyl windows with the nailing flange and built in channel.
I would think that the best method would be to remove the whole window, peel back the siding and replace it with the same size window, with a nailing flange with either the built in channel or j it out. This however will create a lot of exterior work with 16 windows weaving all the siding back in and all. Any suggestions since there is no wood frames with the blind stops like you would replace an old wooden window? I usually stick to doing cabinets and countertops but this is a good customer that wants this done. |
Restoration Crazy
Re: Best Method To Replace A Window With Vinyl Siding
Can you identify the model and get replacement sashes or is the whole thing trashed? Or are you looking forward to the interior trim job that comes with it?!
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
If the old builders grade andersen windows, a new replacement will fit inside if you remove the sashes and tracks. Other wise a new construction window is best. You need to REMOVE the siding, not just loosen it up. other wise its not gonna look good when you "weave" it all back together.
#4 | |
Al Smith
Re: Best Method To Replace A Window With Vinyl SidingQuote:
| estimating guide for windows? | Grumpy | Windows, Siding and Doors | 20 | 11-26-2010 08:18 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Windows, Siding and Doors | 21 | 03-30-2010 08:02 PM |
| removing egg from vinyl siding | Zeebo | Painting & Finish Work | 14 | 03-23-2010 11:19 AM |
| Vinyl Siding Price | joyh23 | Windows, Siding and Doors | 28 | 09-04-2009 07:54 PM |
| Fypon Window Crossheads and Vinyl Dentil | Amar | Windows, Siding and Doors | 2 | 03-09-2008 09:30 PM |
