Best Lumber For Trellis
Old 02-08-2010, 07:16 AM   #1
Project Manager
LaurieC's Avatar
Trade: Custom Home Builder
Rewards Points: 150
Hello all,
I'm about to install a rather large trellis at a client's home. He has requested "S-dry" lumber be used (he read an article by the US Forestry Service about moisture content of lumber and the recommended uses). All of the lumber yards I've called will sale me kiln dried (they all say "s-dry" is in the kiln dried family), but tell me it's not worth the additional cost. Their argument is that once the dried lumber is installed outside it will change the moisture content, and within 3 yrs will look just like green lumber. The homeowners concern is that the green lumber will twist, check and crack.
Any suggestions as to the best lumber to use, or personal experience with such would be greatly appreciated.
LaurieC is offline
Old 02-08-2010, 07:19 AM   #2
genecarp's Avatar
Rewards Points: 2,000
Re: Best Lumber For Trellis
If the trellis must be all wood, around here the most available and my first choice would be Cedar. GMOD
genecarp is offline
Old 02-08-2010, 07:27 AM   #3
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
I think Redwood since it's native to your territory.
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 02-08-2010, 07:46 AM   #4
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,182
My 2 choices have already been named, so I'll just echo them.
pinwheel is online now
Old 02-08-2010, 07:52 AM   #5
Project Manager
LaurieC's Avatar
Rewards Points: 150
Let me be a little more clear. He wants rough sawn Douglas Fir. My question is about moisture content. I can get the DF in kiln dried, but it's double the cost. Is it worth the cost to get the K-dried? My homeowner believes it will help with twisting, cracking and checking. What do you think about kiln dried, is it worth the extra cost? Lumber yard said it will make no difference after a few years.
LaurieC is offline
Old 02-08-2010, 07:54 AM   #6
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
edit.... I's a slow typer
Rough sawn Cedar...
-Steve
TimelessQuality is offline
Old 02-08-2010, 08:19 AM   #7
Ron Thompson's Avatar
Trade: Contractor-New construction, remodel & woodworking
Hello,
I built one for a high end builder that used to frame for in the Boise area, and we used green rough sawn DF. The logs had been cut for some time, but the mill did not have a kiln. The GC had his painter stain and seal them. I think that once kiln dried lumber is left out it will change the moisture content and you will see the lumber move. All the material we used was at least a full 2" x 4", these were for the lattice on top of the pergola. All other lumber was full dimension as well 4" x 6", 6" x 10" and 10" x 10"s. I did alot of the rough sawn stuff down there and it was all non kiln dried lumber. Hope this helps.
Ron Thompson is offline
Old 02-08-2010, 08:27 AM   #8
genecarp's Avatar
I would advice against using DF for an exterior application as you describe, he is creating a maintenance nightmare, GMOD
genecarp is offline
The Following User Says Thank You to genecarp For This Useful Post:
pinwheel (02-08-2010)
Old 02-08-2010, 08:32 AM   #9
pinwheel's Avatar
The warping & twisting is going to happen with certain woods, whether they're kiln dried, or air dried when exposed to the elements over time. If you can get quarter sawn materials, you'll have a better time of them remaining straight.
Old 02-08-2010, 09:07 AM   #10
Steve
BACKWOODS's Avatar
Trade: Remodeling and Custom Cabinets
Rewards Points: 256
How about Cypress, I use it for exterior shutters all the time.
BACKWOODS is offline
Old 02-08-2010, 02:58 PM   #11
Dave R's Avatar
Trade: Home renovation and repair
Rewards Points: 150
I've used kiln dried DF and it didn't twist ,crack or split, even after 2 years in the weather. Like you said, it is expensive but it looks good.
Dave R is offline
Old 02-08-2010, 03:42 PM   #12
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
It doesn't rain very much in So Cal. But it does rain and it will present problems eventually.
One thing to keep in mind with df is the pitch pockets. Nothing worse than a nice bleeder right over the table.
KD will still have some but not as bad as green stock. The KD will be more stable than green too. You will have to decide if it is worth the money, or should I say the owner will after you educate them about the pros and cons.
Gus Dering is offline
Old 02-08-2010, 04:50 PM   #13
jeffatsquan's Avatar
Trade: builder/renovator,Squam Lake NH
Rewards Points: 250
S-DRY Means surfaced dry
Rough-sawn means not surfaced, someone is confused
jeffatsquan is offline
Old 02-08-2010, 05:41 PM   #14
deckman22's Avatar
Trade: Deck Builder
Rewards Points: 5,578
Wood is going to do what wood wants to do when it's outside be kiln dried or air dried. IMO it's a waste of money to get the kd.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 02-08-2010, 10:38 PM   #15
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
Metal caps over the beam/rafter tops will prolong the life, no matter the wood.Kicking it out a 1/4" off both sides will help prevent drip stains.
My opinions regarding your OP would be cedar or redwood as 'best' lumber and k-dried is not necessary for an outdoor setting.
Mac
BuiltByMAC is offline
Old 02-08-2010, 11:18 PM   #16
Noob
custrel's Avatar
Trade: Commercial Interior Finish
Rewards Points: 250
Originally Posted by Ron Thompson View Post
Hello,
Yes. Wood is hygroscopic so the higher the relative humidity, the more water the wood will retain.
Here's a link to a good book about the differences of kiln dried, air dried, green etc.
Kiln dried wood is not 'more dimensionally stable' than air dried or green wood.
The suggestion (forgot the poster) to use quartersawn lumber is probably your best bet if you are worried about minimizing the movement of the lumber.
As for the species, we've got buildings with exposed DF in the northwest that have held up for over twenty years. Of course that is usually with old growth heartwood, I have no idea how resilient today's DF is.
But then I've read that today's cedar and redwood lumber are mostly sapwood as well so who knows how much better they really are.
custrel is offline
Old 02-08-2010, 11:26 PM   #17
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
Send a message via MSN to KennMacMoragh
I think it will make a difference, this article explains it pretty good http://www.globalwood.org/tech/tech_moisture.htm. Saying that the wood will absorb moisture anyway isn't really correct. Wood outside stabilizes at around 12% to 18%, the non-dry, or green lumber will be in the upper 20%.
Around here, most everything outside is cedar. It will shrink and twist a lot after it is installed and dries, but that's something we account for in the design. You can minimize checks, splits, and bows by gluing and screwing your joints together, and giving the wood room to shrink.
In California, I repaired a deck once that had douglas fir for the railing cap. I guess they figure since it doesn't rain much, no need to spend the money on redwood. But it did rot, which is why I was fixing it, so be sure to prime and paint everything good. I'd say if he wants S-Dry then go ahead and give it to him, but compare the prices for him first.
KennMacMoragh is offline
Old 02-09-2010, 02:59 AM   #18
Noob
custrel's Avatar
Rewards Points: 250
The kiln dried wood WOULD absorb moisture since it would start off with a lower moisture content than the relative humidity outside.
That's why I think it's a waste of money to use kiln dried wood for an outdoor project.
Of course, depending on the part of California he's in, the relative humidity might be lower than 12%.
custrel is offline
Old 02-09-2010, 06:30 AM   #19
AustinDB's Avatar
Rewards Points: 590
I'll try to answer your question-if starting w/ drier lumber and sealing it very well, it should hold up, but the ends may eventually fail and allow the moisture in (metal caps may be used). Your best hedge against twisting will be to methodically pick through the lumber and choose what looks to be the best cuts of wood.
As for the question of extra cost-I would consider it not to be advantageous but if the customer wants to make that decision, then so be it. In my area, if I'm after a non-stocked piece of lumber I have to order it by the pallet and possibly pay freight....that get's expensive!
AustinDB is offline
Old 02-09-2010, 09:22 AM   #20
Can't say I've done this, but if you walked around California with a moisture meter and poked some decks, then went to the lumber yard and poked some S-Dry lumber, I bet it would be pretty close to being the same. Enough to where absorption would be negligible. The article I posted says S-Dry has a moisture content of 19% or less, and moisture content outdoors will stabilize at 12% to 18%. If that's true, there wouldn't be any or very little absorption.
PT Lumber variants wallmaxx Framing 7 10-04-2009 09:47 AM
Sticker will ID engineered lumber for firefighters JonM General Discussion 15 08-02-2009 09:03 PM
Anybody using composite lumber? PoodleHeadMikey Decks & Fencing 9 06-04-2009 12:03 AM
Pinting treated lumber gbryant1 Painting & Finish Work Picture Post 7 04-04-2009 05:15 PM
lumber distortion Scott Young Decks & Fencing 2 04-09-2006 10:32 AM
