Trade: Energy Auditor, Insulation, Contractor
Bending Azek?
Anyone have any tips how to bend Azek to trim an oval window? My building rep said a heat gun would work. He also said they make a heating blanket.
#2 | |
Re: Bending Azek?Quote:
You can get heating blankets that would work for what you want to do from an electrical supply house, same as we use for bending conduit.
#3 | |
Are you using 'traditional' or 'frontier' Azek??
http://www.tr-built.com |
miterclamp.com
Trade: interior trim/cabinets
Re: Bending Azek?
I'm with Tom. I'd cut the flat of the casing out of MDF, use the window jamb as a template for a router with a rabbeting bit to get the reveal, and rout the inside detail. Unless it's an exterior you're doing.
If you want a bead for the inside detail, rout it on a board of duraflex then rip it to width. Same with the backband. Otherwise, get a mill shop that specializes in curved molding to do it for you. That last suggestion has always been my own first choice, by the way. I see you're from Danvbury,CT. The best radius crown and casing man in the country is not far from you - Jerry Terranova- over 60 years experience doing nothing but radius work. Down near White Plains. The second best is even closer - Carmel area- Jerry Terranova, Jr. regards, jimc Last edited by clampman; 04-07-2006 at 10:14 AM. |
Re: Bending Azek?
there are other ways... I do not know if the Azek can do a circle but I am trying the sono tube oven method in a few weeks for an upcoming job. I do it so infrequently that the blankets are not worth the money....
Trade: general contractor
Re: Bending Azek?
According to their website, Azek comes in 4' x 8' sheets. If so, make sure you make a template out of cardboard first. Measure twice and cut once. ak
#7 | |
Re: Bending Azek?
Have you seen the size of the Greenlee heat blankets? They are designed for bending conduit. I wonder how many bends it would take to achieve your radius and I wonder what the finished product would look like. Good Luck. ak
#9 | |
This is a better 'heat blanket' to bend Azek. I have never tried either and am going to just use the sono-tube oven method in a few weeks. Heat the whole piece, pull it out and wrap it around my template. I am only looking for a moderate radius and not trying for a circle. I'll post some photos of how it goes when I do it. |
Trade: Trim/Finish Carpentry, Woodworking, if its wood we do it!
Re: Bending Azek?
IMHO, forget about heating or curving flexible moulding like azek.
Order up some pre-made radius trim, such as the ones from sunwindows.com thats only one option, there, for there are lots of different mill companies that manufacture radius trim, using wood, mdf, or pvc materials. |
Re: Bending Azek?
I agree - but ordering that type of stuff up here is usually more trouble than worth and expensive. I am actually looking forward to messing around with bending this stuff.
#12 | |
Re: Bending Azek?
The AZEK rep came to my site with his heating blanket and put on a show for me and my framers. Using the blanket the process was very easy. I just can't see spending $800 for the tool. Thanks for everyone's input.
| Azek butt joints holding up? | LeonardDB | Finish Carpentry | 39 | 11-28-2009 08:30 PM |
| Tacoma Board or Azek | Woodcrafter74 | Finish Carpentry | 5 | 09-28-2006 02:22 PM |
| Bending 4 in. PVC | Teetorbilt | General Discussion | 5 | 05-15-2006 03:43 PM |
| Help With Azek | joeburke | General Discussion | 1 | 03-20-2006 07:07 PM |
