Bath Vanity Base Filler Strip - Carpentry - Contractor Talk
Old 03-02-2018, 02:02 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 2,170
Vanity goes in a tight corner of a bath. There is only about 1/2" clearance between the basin counter edge to the outer door casing, which is a little tight. The base unit is made of a plywood wall and the filler strip looks something like laminate poplar or near this. Rough plumbed out of wall...
Cabinet has a smooth painted, fine finish on the outside that continues to the hinge side framing.
-> Could either size/rip the filler and predrill and screw from the inside I guess, or try to size it up and do the same from the concealed/wall side (but without a way to re-adjust in the future, after the cab is permanent). Of course if it's glued it's done 'acceptance style'.
Is there an easier way to do this?
-> Mount the cab and counter with an open gap, and then push in the filler from the outside ? Not too far! (how to bring it back?)
-> Mount the cab alone, then the filler, then the counter? Is this the common sense approach? (noting there is only about 3/8" counter extension - not much to screw through for the filler.)
artinall is offline
Old 03-02-2018, 02:56 PM   #2
tjbnwi's Avatar
Rewards Points: 4,906
Re: Bath Vanity Base Filler Strip
Add a piece to the box, scribe to wall.
Scribe strip.
tjbnwi is online now
artinall (03-02-2018), Tinstaafl (03-02-2018)
Old 03-02-2018, 05:13 PM   #3
artinall's Avatar
Scribe strip.
I love economy in writing. Just need to practice more of it myself...
You'd think I know this, just got done scribing the flooring!
Now wondering whether to fool with the kickplate - don't want to put on a vinyl base since the corner cut would show and it wouldn't look that great in a full wrap.
artinall is offline
Paper Strip Framing nailers? valleypro Tools & Equipment 5 02-16-2016 12:30 AM
ISIS Captures Air Base & 300 Marines Trapped? Lugnut1968 Off Topic (Non Trade) 0 02-12-2015 07:17 PM
Repairing a failure - building up base on linear drains sbcontracting Kitchens & Baths 3 12-09-2014 12:40 AM
Poll - Do you give free Estimates? metroconstruct General Discussion 39 06-12-2013 11:18 PM
Charging for Estimates? When should you and how much is reasonable? doby General Discussion 16 06-09-2013 07:04 AM
