Bastard Hip
Old 01-03-2012, 03:42 AM   #1
jslusher's Avatar
Trade: Apprentice
Rewards Points: 25
Bastard Hip
Need a little help on this one. Walls have already been built, the angled walls are 76" and the middle wall is 60". If you are wondering why they aren't equal sizes ask the home designer. I don't have much experience with this so maybe this is normal?
Took a shot at modelling the framing in sketchup. Thought about bringing each hip rafter up to the ridge, but i was worried about the overhangs not being on the same plane so this is the best i could come up with.
I gotta frame this thing tomorrow. Any ideas???
jslusher is offline
Old 01-03-2012, 05:51 AM   #2
Kent Whitten's Avatar
Rewards Points: 2,040
Re: Bastard Hip
Yes, you need to bring the hips up from the corner points. You fascia level WILL be the same, but your overhang will most definitely change.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 01-03-2012, 06:16 AM   #3
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
Re: Bastard Hip
You can keep the fascia height and overhang the same, by manipulating the pitch and heel height or HAP.
The easiest way to do this is to snap the plan view out in full scale on the floor, complete with overhangs, sub fascias, ridge lines and walls.
This allows you to measure hip and rafter runs accurately. You'll also notice that the hips will be offset from the corners of the walls. This can be compensated for by adjusting the rafter dimensions to give the illusion that the hips land on the corners on the inside, if necessary for a vaulted ceiling.
Here's a few pics of the last one I framed with your conditions, although much more exaggerated.
Bastard Hip-001.jpg   Bastard Hip-050.jpg   Bastard Hip-027.jpg   Bastard Hip-015.jpg   Bastard Hip-040.jpg
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
jslusher (01-04-2012)
Old 01-03-2012, 06:19 AM   #4
KemoSabe
loneframer's Avatar
Re: Bastard Hip
In your renderings, the ridge is too long. It would have to cut back to a point from the front wall that is equal to half of the wide span of the wing walls, or common run of the main roof.
To give you an idea, extend the center rafter of the wing walls to the ridge, where the ridge and wing wall commons converge.
CanningCustom (01-03-2012)
Old 01-03-2012, 09:57 AM   #5
Birch's Avatar
Rewards Points: 1,050
Re: Bastard Hip
My thoughts on it are that is not a very well thought out room/roof design. Not something I’d expect from anexperienced designer. (Looks wrong to me.)
It can be built as drawn, but the little gable will (or should) have zero overhang. The overhangs should be equal on all sides. The little gable should be nixed.
Birch is offline
Old 01-03-2012, 10:53 AM   #6
jslusher's Avatar
Trade: Apprentice
Rewards Points: 25
Re: Bastard Hip
Thanks for the comments guys. I agree after sleeping on it the little gable should be nixed. I'll try another version as you described Lone. Thanks.
jslusher is offline
Old 01-03-2012, 11:19 AM   #7
Life Apprentice
mehtwo's Avatar
Trade: Plumbing & Carpentry
Rewards Points: 558
Re: Bastard Hip
Lone, what kind of siding is that?
mehtwo is offline
Old 01-03-2012, 11:24 AM   #8
Life Apprentice
mehtwo's Avatar
Rewards Points: 558
Re: Bastard Hip
I live 150 miles from you. Hi neighbor!
Don't make excuses, make it happen!!!!
mehtwo is offline
Old 01-03-2012, 12:29 PM   #9
General Contractor
greg24k's Avatar
Rewards Points: 7,024
Re: Bastard Hip
Can try something like this:
greg24k is online now
The Following 4 Users Say Thank You to greg24k For This Useful Post:
bluebird5 (01-12-2012), Joasis (01-05-2012), jslusher (01-04-2012), WildWill (01-05-2012)
Old 01-03-2012, 01:52 PM   #10
Re: Bastard Hip
Actually, Lone is correct. You can get level fascia and even soffits by adjusting the HAP.
Old 01-03-2012, 06:33 PM   #11
KemoSabe
loneframer's Avatar
Re: Bastard Hip
Originally Posted by mehtwo View Post
Attachment 62287
I believe that is Certainteed Cedar Impressions double 7, straight edge perfections.
http://www.certainteed.com/products/...siding/310282#
Old 01-03-2012, 07:57 PM   #12
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,702
Re: Bastard Hip
Do you have any pictures of that?
knucklehead is offline
Old 01-03-2012, 08:23 PM   #13
KemoSabe
loneframer's Avatar
Re: Bastard Hip
Might have a couple floating around...
Bastard Hip-003-11.jpg   Bastard Hip-010-2.jpg   Bastard Hip-020-1.jpg   Bastard Hip-018-1.jpg   Bastard Hip-093.jpg
Old 01-04-2012, 10:17 PM   #14
jslusher's Avatar
Trade: Apprentice
Rewards Points: 25
Re: Bastard Hip
Update: Won't be framing the hips until friday. About to start modeling and see what happens. I'll post pics when i'm done.
Not sure i understand what you mean. I understand about the hips being offset from the corners, but not the part about adjusting the rafter dimensions.
jslusher is offline
Old 01-04-2012, 10:24 PM   #15
jslusher's Avatar
Trade: Apprentice
Rewards Points: 25
Re: Bastard Hip
Hey neighbor! Are you anywhere near the Oregon mountains?
jslusher is offline
Old 01-04-2012, 10:39 PM   #16
KemoSabe
loneframer's Avatar
Re: Bastard Hip
It boils down to this. On the underside of the rafters, if you were to install drywall as is, your finished joint would land somewhere off the corner of the wall, just as the framing does. By manipulating the rafter dimension on one or more roof planes, you can get the drywall corner joint to match the joint on the ceiling, giving the illusion that the hip sits perfectly on the corner.
This is an advanced framing technique and not easy to pull off if you've never done it before. I've seen drywall guys double rock the offending plane to bring the joints in line before, which is what triggered my mind as to how it could be done in the framing stage.
In extreme cases, blocking may need to be added for sufficient nailing because manipulating the rafter dimensions will push the joint past the hip entirely.
Old 01-05-2012, 04:49 PM   #17
Life Apprentice
mehtwo's Avatar
Rewards Points: 558
Re: Bastard Hip
I live between Alamogordo and Tularosa.
mehtwo is offline
Old 01-05-2012, 04:57 PM   #18
Life Apprentice
mehtwo's Avatar
Rewards Points: 558
Re: Bastard Hip
One thing that I learned from a framer is that you should think about the other trades as you are framing. It makes you a better framer and you get more respected.
mehtwo is offline
The Following 2 Users Say Thank You to mehtwo For This Useful Post:
CanningCustom (01-05-2012), jslusher (01-06-2012)
Old 01-05-2012, 05:43 PM   #19
KemoSabe
loneframer's Avatar
Re: Bastard Hip
I got into a bit of a spat with the owner of a plumbing company one time, because he was giving me a blast of crap about framers in general. That we're all inconsiderate POSs that don't think of anybody else.
I asked him at that point, if he would prefer that I stop laying out joists for tubs, toilets, showers, etc. Also, would he prefer I stop stacking the nails in the double plates so his guys wouldn't ruin auger after auger on nails.
He called me a liar, because nobody does that, at which point I asked the three plumber guys on the job if they ever hit nails in my frames.
Let's just say he found new respect for at least one lone framer.
Old 01-05-2012, 05:58 PM   #20
JustaFramer's Avatar
Trade: Exiled For Life
Rewards Points: 2,000
Re: Bastard Hip
I remember way back in the day when I spun a thread. It was probably juvenile on my part. But to have a guy with a name that rhymes with Snikey bring it up years later. Tells my it struck a chord with him.
I may not be a framer anymore but I still have the heart.
JustaFramer is offline
hip question Spek Framing 121 08-30-2011 12:24 AM
some bastard stole my makita impact driver with battery ApgarNJ General Discussion 28 01-19-2011 08:44 AM
hips and valleys FRAMERBEN Framing 118 05-04-2010 05:32 PM
bastard roof? WNYcarpenter Framing 112 08-21-2007 12:08 PM
