Attaching 2x4 To Steel Girder
Old 12-24-2008, 02:04 PM   #1
Philly Dude's Avatar
I have a horizontal steel I beam that I need to attach a 2x4 to in the webbing area of the beam. I have a Hilti DX400 .27 caliber powder actuated gun. I have Hilti 1 7/8" nails that say on the package : for attaching 2x4 to steel up to 1/2" thick. I tried about 12 nails. Most of them just completely bounce off of the steel and bend in half a full 90 degrees. A few stuck in the steel a few millimeters but were easily pulled out by hand. They also bent in half. I tried useing medium charges and heavy charges. I think that maybe the steel is thicker then 1/2". The webbing is about 8" wide on this I beam. I have no access to the other side of the I beam, so I can't just drill thru and run some bolt thru the wood and the beam.
I need to attach wood to this I beam so I have something for my subflooring to catch onto in this one 2' long spot. I can't put any additional framing in this area because there is a waste line running parallel to the beam about 18" away from it.
Philly Dude is offline
Old 12-24-2008, 02:24 PM   #2
joasis's Avatar
Re: Attaching 2x4 To Steel Girder
Look for these or similar...if you have a place in your area that repairs flatbed trailers, they will have torx drive screws just made for this stuff.
http://www.screw-products.com/reamer.htm
It has been my experience that power fasteners just don't get it in a lot of applications...and this is one.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 12-24-2008, 02:39 PM   #3
mickeyco's Avatar
Trade: Squirrel Handler
Drill and tap.
Weld
2 x4 to hold up floor?
How about just "resting" the 2 x 4 (or larger) on the beam ledge and using the nails or screws in the sub-flooring to hold it in place. T it at the end to prevent twisting if needed.
Pictures would help.
mickeyco is offline
Old 12-24-2008, 03:16 PM   #4
Professional Remodeler
firemike's Avatar
I have the exact same Hilti gun as you, usually use it for the same purpose, one thing you have to watch, the nails/gun have to be almost perfectly square to the steel or you will get ones that bend and bounce. I have found that if I stand on a ladder where I can get my weight and shoulder into holding the gun it works better that trying to do it holding it with one hand. You might also have a harder-than-usual I-beam, ran into that a couple times.
I also use the self-drilling type of screws Joasis is talking about, but with webs that thick I have found it easier to predrill the hole with a regular drill bit, faster than letting the screw drill the hole.
If it's only a 2 foot spot, you might do as Mickey suggested, buy a tap with matching drill at the hardware of big box, drill and tap for a a couple bolts, put some construction adhesive on it and bolt it to the beam.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 12-24-2008, 05:41 PM   #5
K2's Avatar
drill it and put a carriage bolt thru it. i've drilled many and it goes fast with a couple of new bits. It was common here to just glue the wood plate to the steel and bend a couple of nails over to hold it and get some weight on it. I've never heard of any problems with just glue but I always liked thru bolts
K2 is offline
Old 12-24-2008, 05:43 PM   #6
mickeyco's Avatar
mickeyco is offline
Old 12-24-2008, 05:45 PM   #7
K2's Avatar
And check your hilti to see if the driver is angled or misformed/ worn. I had a bad one once and it couldn't drive anything..
K2 is offline
Old 12-24-2008, 05:52 PM   #8
K2's Avatar
Originally Posted by mickeyco View Post
Yeah , Yeah. I know we're supposed to read the whole post. Now that I know someone is watching I will..
K2 is offline
Old 12-24-2008, 05:57 PM   #9
Motorboatin' son of a ...
BKFranks's Avatar
Have your steel guy weld some bolts on there. Easy.
BKFranks is offline
Old 12-24-2008, 06:03 PM   #10
SNC's Avatar
Trade: SE Carpenter
Just rent a magnetic drill cost a lot less than a welder. They work great.
If you use a hilti the only possability is if you use the purple shots.
SNC is offline
Old 12-24-2008, 06:06 PM   #11
K2's Avatar
How about ripping it to lay on the flange and drilling and lagging from the bottom.
K2 is offline
Old 12-24-2008, 06:12 PM   #12
rustyjames's Avatar
If it's an 8" beam I doubt the web is going to be more than 1/2" thick, more than likely 1/4-3/8". Those self driller's are also available in hex-head which might make it easier if you go that route. When shooting with a gun you have to be dead nut perpendicular with the gun otherwise what's happening to you often occurs. Personally, unless the welding machine and weldor were already at the job, I would stay away from that; especially if the building has a lot of wood in it.
rustyjames is offline
Old 12-24-2008, 06:15 PM   #13
kapena's Avatar
Trade: General Building Contractor
Firemike is right about you having to aim square to keep the pin from bending.
You might want to try pre-drilling the wood and some of the steel with a bit that is smaller diameter than the pin. You don't have to drill all the way thru the steel either; just enough to keep the pin from bending.
kapena is offline
Old 12-24-2008, 06:34 PM   #14
Thanks for all the quick replies. I have a feeling that the nails are bending because of the gun not being perfectly perpendicular to the steel. It is a real tight spot I'm trying to shot in and this is probably the case. Also I never shot into steel before so I did not know you had to be perfectly square.
I'll definitely post some pics on Friday night.
Thanks again for all the quick replies.
Merry Christmas to all !
Old 12-24-2008, 07:20 PM   #15
Bodger's Avatar
I just had this exact same condition to work through and the fasteners in the link above worked beautifully. Even though they are "self drilling", I found that an appropriate sized pilot hole helped a lot, and I have a Drill Doctor to keep up with the dulls.
I got there the same way, my Hilti powder actuated just wasn't cutting it.
Bodger is offline
Old 12-24-2008, 07:25 PM   #16
Michael_Tanner's Avatar
Trade: Project Mgt, Finish
I never had success with the long pins into steel.
You may try shooting some 20g. metal track into the steel with short pins. This track is 3 5/8" wide, and should hold well. The 2x4 slips into the track nicely, and can be attached from the sides w/ screws.
M.
Michael_Tanner is offline
Old 12-24-2008, 07:25 PM   #17
... Alternately, I believe that Unistrut makes a beam clamp that would work for you.
Old 12-24-2008, 09:56 PM   #18
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Simpson too makes a TB (Truck Bed) screw that works for this application, pretty much the same as the screws Joasis recommends only with a Robertson drive.
Just an option see which is quicker to get.
Chris
Chris Johnson is offline
Old 12-26-2008, 09:47 AM   #19
canuck's Avatar
Trade: General Commercial Construction
I've had people tell me the same basic problem shooting into steel. They had the depth setting turned to 1. If you haven't tried it already use a red shot with the gun set at 3.5. It just might work.
Otherwise I'd just use the above suggested screws.
canuck is offline
Old 12-29-2008, 11:29 AM   #20
Thanks again for all the good responses. A few of you mentioned drilling and tapping holes in the girder. The steel is just too thick and/or hard. I tried a brand new bit and I'd of been there for an hour trying to get thru that sucker.
Solution: I cut a piece of wood to rest on the bottom shelf of the webbing. I cut it with a bevel on the bottom so it would rest perfectly flat. Then I used construction glue to hold it to the beam, as well as some wood blocking to lock it in place.
Here are 3 pics of the problem:
Attaching 2x4 to steel girder-dec8-002-large-.jpg   Attaching 2x4 to steel girder-dec8-003-large-.jpg   Attaching 2x4 to steel girder-dec8-004-large-.jpg
Advice on putting in a steel knock down door kbspeed General Discussion 1 12-02-2008 09:48 PM
Spanning Steel question y0ud Construction 3 10-31-2008 11:38 AM
Hollow metal welded frames welded into structual steel detroit687 Commercial Construction 1 09-11-2008 11:18 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 04:46 AM
Attaching 2x4 to 4x4 steel post plazaman General Discussion 6 10-15-2006 09:38 PM
