Carpenter
Askin' For Your Ideas??
I just got me a hot tub, about 6' x 7'. I'm putting it about 4' away & 14" higher than my above ground swimming pool. Kinda stuck as to what kinda design I want to incorporate into the deck surrounding it & as to what kinda roof system I'm gonna use?
I was thinking about an A frame with a ceiling & some black lights. Then have some of them Bamboo roll up shades for the sides & privacy. Really tho, I want some of your ideas as to how y'all would do it, if y'all don't mind? Yes, it's treated. Last edited by woodbutchr; 01-05-2008 at 07:48 PM. |
Trade: General Contracting
Re: Askin' For Your Ideas??
Very nice!
I would definetly keep the decks the same hight so your hot tub is sunken. Looks funny at first but is very functional, especially for those who cannot step over a hot tub side. It is also very nice if you can wrap your deck all the way around; you may not want certain people stepping over you to get in, especially when clothing is optional! Enjoy! |
Trade: Custom deck builder
I would be more worried about what is holding it up rather than what goes around it.
Deck Designer/Builder
Aside from making sure your structure can support the weight, like Robert suggested here is a photo of a deck I did this spring that has some louvered privacy screens. IMO, they look a lot better than those bamboo things.
Carpenter/fencing
A-frame ,ahh go for broke, here's an easy roof and hot tub area with a few buddys it should only take a few hours to construct.
Learning without thought is labor lost; thought without learning is perilous. |
Charitable animal
Trade: decks
I'd put me one of them swedish saunas on that baby too
Carpenter
I aint at all worried about the support, it's plenty enough to handle the weight!
Louvered panels, that's a great idea! |
Carpenter
Re: Askin' For Your Ideas?? |
#9 | |
Charitable animal
Trade: decks
Re: Askin' For Your Ideas??Quote:
da da da, da da da, DA DA DA I don't listen to her cause my head is like a seive da da da, da da da, DA DA DA |
Trade: Consultant
Charitable animal
Trade: decks
looking at that pic of the tub and the (2) 2' scraps of post in the wheelbarrow, the clamshell, and the (1) 60# bag of quickrete, and the very tidy area around each post, I envision an image of a rickety mortise and tennon bar stool in a large puddle with a very obese man standing on it holding a cable with 240v
Carpenter
80# of concrete on each post, post's are notched for bands, 2" x 8" @12" with 2" x 4" @12" across the top. Lags bolts & corner bracing yet to do. It's alot better than where it had been sitting for the past 6 years.
Charitable animal
Trade: decks
assuming you "set your post it crete" (btw sakrete is a 3k or 5k# yeild) and your structure holds, I hope your soil bearing capacity is at least 6000psf, you may want to alert your sparky to allow enough slack for a possible and sudden 18-20" drop
Custom Decks & Carpentry LLC. Chester County Custom Decks Custom Deckbuilder Mainline Philadelphia Deck Builder Custom Decks & Carpentry on Facebook Last edited by Bone Saw; 12-04-2007 at 04:00 PM. |
#14 | |
Trade: Squirrel Handler
![]() ![]() ![]() ![]() ![]() ![]() Smiley Pyramid-Patent Pending .
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
#15 | |
Carpenter
Oh yeah, yield is spelled "ie" instead of "ei". Last edited by woodbutchr; 12-04-2007 at 11:00 PM. |
Soil bearing is very important! If I was holding up a hot tub on 4 footings they would be a minimum of 18" DIA all the way past the frost line. Plus the hot tub does not ONLY load to the 4 corners. It distrubutes fairly evenly accross the entire thing.
The deck you have built there is probably not even rated for 60 PSF and you need a lot more than that.
Charitable animal
Trade: decks
I didn't doubt you, in fact I was making sure I was understanding you correctly, but that went way over your head professor. setting post in crete and on footers are are not the same thing, and since you will be supporting 5000+ pounds of tub + a roof structure with blackligkting overhead on less than a square foot of bearing surface, I thought you'd might want to take measures to keep from electrocuting yourself as your tub "settles"
Custom Decks & Carpentry LLC. Chester County Custom Decks Custom Deckbuilder Mainline Philadelphia Deck Builder Custom Decks & Carpentry on Facebook Last edited by Bone Saw; 12-05-2007 at 12:14 PM. |
#18 | |
Carpenter
Now just how did you know I was a professor?
#19 | |
Trade: Consultant
Now, that little scolding aside, you've got approximately 6,000# that you're spreading over 4 footings, so each footing is taking +/- 1,500# of load assuming everything is equally distributed. Assuming you've got a 12" diameter footing and that your post has at least 6" or so of concrete below it (rather than the post sitting on the soil and the concrete being poured around it), you're imparting a load of approximately 2,000 #/SF to the soil. Unless you've got poorly compacted soil under the footings, you should be fine- and the footing would never fail- it'd be punched through the soil below far before that would ever happen. I'd be more concerned about the load transfers from joists to girders or girders to posts, but I'm not about to figure all of that out for you |
#20 |
Carpenter/fencing
Mr woodbutcher don't make me send the deck police over and give you a sitation for that last step thats about 12" high
| Trailer: Customizing ideas needed. Long | Robie | Vehicles | 195 | 11-06-2011 11:32 AM |
| Productivity Ideas | mbenike | Construction | 17 | 12-03-2007 08:39 PM |
| Improvement ideas for remodeler website? | DerrickVWS | Technology | 17 | 05-22-2007 11:38 PM |
| Any Ideas? | SevenKitty | Marketing & Sales | 17 | 04-18-2007 08:04 PM |
| Need ideas for personal project | Kristina | Landscaping Picture Post | 10 | 05-11-2006 12:13 AM |
