Arrgh, Nice Footing Placement, Eh?
Old 09-10-2007, 03:36 AM   #1
BuiltByMAC's Avatar
Trade: Construction
Normally I don't get into ripping on other people's work but this defect stares at me every time I drive up into the subdivision I'm working in.
I'm not sure if the inspector's been back out to the house for framing final but as you can see, they haven't slowed down in building the house. I just hope that it doesn't get covered by backfill/bark-o-mulch before final inspection happens.
Not much of a point to this thread other than commiserating with fellow pros about some of the hacks out there...and this is on a $600K house in an upscale neighborhood.
It's just a little more noteworthy than the 6 footings on a double decker deck up the road half a mile - 6x6 posts sitting on 8" diameter sonotubes on 2x2x8" pads sitting on top of 4' of backfill.
I just gotta shake my head sometimes at what people will build and inspectors will pass - meanwhile he(inspector) jumps me because my graspable handrail didn't extend beyond the first riser, merely started at it. I don't mind making the change and will continue to build future handrails to code but damn, let's catch the problems that will kill people, shall we?
Mac
Arrgh, nice footing placement, eh?-img_3000-01.jpg   Arrgh, nice footing placement, eh?-img_3001-01.jpg
BuiltByMAC is offline
Old 09-10-2007, 07:32 AM   #2
painterman's Avatar
Trade: Historic Restorations
Re: Arrgh, Nice Footing Placement, Eh?
Love that stone work
painterman is offline
Old 09-10-2007, 08:29 AM   #3
RobertCDF's Avatar
Trade: Custom deck builder
No they dont like to complain about the truly dangerous ones... But if you screw up the handrail you are a HACK!.
BTW everyone I have done a deck for prefers a FLAT 2x6 as apposed to the vertical 2x6 with the groove or the rounded that I install to pass inspection.
RobertCDF is offline
Old 09-10-2007, 08:57 AM   #4
finehomes's Avatar
Trade: Builder/Developer
Mac,
I have one that looks like that right in my back yard. Big covered roof over a concrete patio. Builder is a neighbor of mine three doors down....so not only do I get to look at that ugly post every day....but I get to socialize with the guy that does that kind of work all the time. I've poured footings like that before and then realized they were in the wrong place......BUT.... if you care about your reputation....you yank them about and redo it. I don't mind if the post is slightly off center....but DAMN!!!!!! Have these people never heard of pithagerus????
Sam
finehomes is offline
Old 09-10-2007, 09:03 AM   #5
Mod / ArchiBuilder
Cole's Avatar
I could not agree more, yank that damn thing out and redo.
Cole is online now
Old 09-10-2007, 09:30 AM   #6
Professional Remodeler
firemike's Avatar
Sad part is, the other one is not that close to center either... How bad do you have to be to be that far off on only two piers?
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 09-10-2007, 09:41 AM   #7
Charitable animal
Bone Saw's Avatar
Trade: decks
love the HUCQ's at the post/beam conections
Bone Saw is offline
Old 09-10-2007, 09:52 AM   #8
extreme birdhouse builder
cranbrook2's Avatar
Trade: framing ,trim ,roofing,fences and decks .
That mess should of never been passed.
An easy fix would be to put a new beam in underneath then move the post over 6"
The post should be under the beam not butting into it.
cranbrook2 is offline
Old 09-10-2007, 10:02 AM   #9
Chris G's Avatar
Trade: Porch and Deck Builder
If your vision is that bad, you should be using larger sonotubes, like maybe 48" or so. Then you can dig like a drunk, and you should land pretty close.
Chris G is offline
Old 09-10-2007, 10:17 AM   #10
Joe Carola's Avatar
Trade: Framing Contractor
We all make mistakes that have to be fixed. This obviously has to be fixed and ripped out.The guy who framed this should have never put the post base and post in. He should have sat the deck on a temporary post and whoever the builder is has to rip out the footing and put a new one in. If this passes inspection, then we all know what that says about the inspector.
Joe Carola
Joe Carola is offline
Old 09-10-2007, 10:25 AM   #11
BuiltByMAC's Avatar
Trade: Construction
I've actually done that before - what I think they did was run the posts up to support the roof beams, by hanging the beam between the posts you eliminate a potential pivot point. B U T, I make damn sure the footings' in the right spot to support the loads!
That just kills me - it's a huge sonotube too! Plenty o' concrete for the load if only the load weren't just waiting to chip off the edge!
Yup, I saw that too. I mean really, pull your measurements off the stem walls (they poured footings right at rough framing), square up and pour the things!
Mac
Old 09-10-2007, 10:59 AM   #12
theworx's Avatar
As Maxwell Smart would say "missed by that much"!!! Guy must have one of those new rubber tape measures (my boss has one and his measurements are never accurate)!!! So, this actually passed inspection???
theworx is offline
Old 09-10-2007, 11:09 AM   #13
Joe Carola's Avatar
I just noticed that those 6x6's go from the footing all the way up to the girder that supports the rafters and the small girder in between the two posts are on hangers. That's probably why they put the posts in. Still, the footing has to be changed, and if it did pass inspection....time to question the inspector....
Joe Carola
Old 09-10-2007, 12:43 PM   #14
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
big deal all the the form carps have to do is dig down to the base epoxy dowel and add on.
JustaFramer is offline
Old 09-10-2007, 04:18 PM   #15
RYANINMICHIGAN's Avatar
Trade: builder of stuff, real nice stuff
Thats not the point. The point is my 2 yeart old son could come then closer then that. Why such a big tube also?
RYANINMICHIGAN is offline
Old 09-10-2007, 04:48 PM   #16
mickeyco's Avatar
Trade: Squirrel Handler
I just want to know why you're taking pictures of my work.
mickeyco is offline
Old 09-10-2007, 08:35 PM   #17
KentWhitten's Avatar
that's what I've seen too is pin the sides, pour around it....even though it's hack, it's by no means the only one I've seen. I ran into these all the time framing. My old boss was nuts about the post being directly in the middle. He said if it wasn't then the pad would eventually tilt, which is prolly true.
Taking it out would be the correct way, but I doubt that will be done.
Salmon Falls Cabinetry
KentWhitten is online now
Old 09-10-2007, 09:07 PM   #18
reveivl's Avatar
Trade: Renovations
I guess that it's such a big sono because there is going to be some matching masonry to the walls wrapped/set whatever on it? Otherwise, why the big tube? If I'm correct on that, man is it ever going to look worse later...
reveivl is offline
Old 09-10-2007, 10:58 PM   #19
BuiltByMAC's Avatar
Trade: Construction
It's not a big deal IF it gets fixed. That post has been sitting on that footing for the past couple of months - no one's in a hurry to fix it.
My original post wasn't "OMG, there's no way this can be fixed!"
I don't know which inspection that would fall under (structural framing, final inspection) so I don't know if it's passed yet. Obviously footings/foundation has passed but that might have been before the post was installed on the footing.
I'm assuming they're rocking the posts (tar paper covering the left one) but don't know about the footing. The sonotube might have been spec'ed that large because it was supporting both porch and roof loads, which still begs the question, "why did the framers think that post was fine hanging off the edge?"
Mac
Old 09-11-2007, 02:22 AM   #20
blackdoggie's Avatar
Trade: Screw up repair man
It really looks like the cops need to be setting up DUI and drug screen checkpoints at construction sites. I mean how the hell could you be off that much??? The guy measuring must be either A.Blind B. Drunk/on drugs or C. Just plain stupid.
blackdoggie is offline
footing drain question chrisk Construction 5 09-02-2007 07:08 PM
footing depths WNYcarpenter General Discussion 18 07-14-2007 10:47 PM
Nice People? DEAD MAN Off Topic (Non Trade) 17 02-27-2007 04:13 PM
Footing Drains jjtt Excavation & Site Work 27 07-17-2006 10:28 PM
