Anchor Size For Concrete Block.
Old 12-05-2006, 05:02 PM   #1
Chris G's Avatar
Trade: Porch and Deck Builder
What length of expanding sleeve anchor do you use for hollow block? I'll probably use a 1/2" dia. It's pretty low load, like 30 pounds per, so shear weight isn't really a big issue.
Chris G is offline
Old 12-05-2006, 05:22 PM   #2
ch0mpie's Avatar
Trade: Geotechnical PE
Re: Anchor Size For Concrete Block.
I don't remeber exactly what I've used, but manufactures ussually give pretty clear recommendations about this kind of stuff. Check the website of the brand you intend to use
ch0mpie is offline
Old 12-05-2006, 05:41 PM   #3
Chris G's Avatar
You're right. I should have thought of that. After googling for a couple of minutes, I came here. It never occurred to me to go to their site.
Chris G is offline
Old 12-06-2006, 04:42 AM   #4
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
I use 1-3/4" plus the thickness if whatever material I am fastening. I noticed you mentioned sleeve anchor, that is the right fastener, just avoid using wedge anchors for hollow cinder block, and don't overtighten.
Pearce Services is offline
Cinder Block walls, block filler and a leak...question SeanATL Painting & Finish Work 9 03-09-2009 04:33 PM
Block Walls DaHammer Masonry 29 03-06-2009 07:11 PM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Just boguth a new short block for race car:) IHI Off Topic (Non Trade) 4 09-21-2006 09:25 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
