Acoustical Caulking Question
Old 08-22-2015, 11:09 PM   #1
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,248
Excuse my ignorance if I've missed something obvious. But WHY is acoustical caulking required on double framing members? I see guys caulking every double stud and all around the window and door headers, etc. and then cover it all with poly and seal the edges. I thought the poly was the air barrier and the caulking was to seal the joints and edges. What good does it do to smear this stuff in the crack between 2 studs? I've never done it or been called on it though I've been lead to believe its code. Clue me in.....
Anthill is offline
Old 08-22-2015, 11:20 PM   #2
FrankSmith's Avatar
Rewards Points: 4,670
Re: Acoustical Caulking Question
If 0 degree air blows between studs, and makes it to the back of the drywall the system has failed. Even if it can't enter a stud bay, if it is to the back of the drywall it is to far.
FrankSmith is offline
Old 08-23-2015, 09:14 AM   #3
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
so the idea is for that 1/32 of caulking to provide enough insulation to keep cold from reaching the poly/drywall?
Anthill is offline
Old 08-23-2015, 11:01 AM   #4
Box Builder
Morning Wood's Avatar
Rewards Points: 8,996
I'm not familiar with putting acoustical sealant between a king and jack stud (I think that's what you're talking about). If you are trying to air seal at that point in the building envelope you are too late.
But acoustical sealant is used to prevent air leakage not provide insulation.
Morning Wood is offline
The Following 2 Users Say Thank You to Morning Wood For This Useful Post:
overanalyze (08-23-2015), Philament (09-05-2017)
Old 08-23-2015, 08:24 PM   #5
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
that's what I always thought. I might have to dig into it a little more and see if I can find a reason for it.
Anthill is offline
Old 09-03-2015, 08:49 PM   #6
saynever's Avatar
Trade: electrical
Rewards Points: 229
Depends on what the wall system is using for an air barrier. Air tight drywall? Membrane behind finished wall? Interior plywood/osb with service cavity? Exterior sheathing as air barrier?
Normally acoustical sealant or neoprene gaskets are used for air tight drywall. Caulking the stud joints of an interior parition wall where it meets an exterior wall is one example. You don't want air drafting around or between that stud into your interior parition wall cavities.
saynever is offline
Old 09-05-2017, 01:59 PM   #7
edflamingo's Avatar
Rewards Points: 4
When i do it, i always assume its acting as a more direct air barrier, reducing any changes of currents happening between the poly and framing members if the drywall doesn't sit flat enough to seal them. this is especially true when framing members aren't perfectly flush, possibly allowing convection currents to happen and therefore drawing more air in through gaps, like in between the king stud and trimmer.
edflamingo is offline
Insulating attic question power Insulation 19 03-10-2013 07:55 PM
Vinyl Flooring Adhesive Question josephdan General Discussion 1 03-05-2013 04:36 PM
Code Question on Lamp wiring question ABLE1 NEC Discussion 8 06-16-2010 07:48 AM
Acoustical ceilings ;question Wensdy General Discussion 0 09-16-2008 02:45 PM
