3-Form Panels
Old 11-19-2007, 06:13 PM   #1
General Contractor
JohnV's Avatar
3-Form Panels
Does anyone have experience with 3-form panel installations?
It calls for a channel in the flooring which needs to be 1/4" away from the baseboards. I cant fit a router so tightly against the wall. What are my options? The channel needs to be 3/8"x1/2" and about 8' in length.
I considered a toe kick saw, but my fear is it will not cut cleanly enough.
JohnV is offline
Old 11-20-2007, 12:39 AM   #2
MASSJK's Avatar
Trade: Remodeling contractor
Re: 3-Form Panels
Hello,
Not sure about your exact instalation but we often use u channel.
MASSJK is offline
Old 11-20-2007, 12:50 AM   #3
General Contractor
JohnV's Avatar
Re: 3-Form Panels
Yes. It calls for U channel in the flooring. The problem is routing out for the u channel so close to the wall. It has to be 1/4" away from the baseboard.
JohnV is offline
Old 11-20-2007, 12:50 PM   #4
Bob Kovacs's Avatar
Trade: Consultant
Re: 3-Form Panels
Sounds like something that should have been installed prior to the flooring and/or baseboard. If this is a retrofit, you've got two choices- either mount a u-channel on the flooring as noted above, or do whatever is necessary to create enough room to make a channel in the flooring- remove baseboard, tear out flooring, or whatever.
Or, when the architect tells you that the uchannel is unacceptable, ask him to use his magical powers to "will" a channel in the floor for you.....lol.
Bob Kovacs is offline
Keeping panels from sticking. Rich Turley Masonry 5 10-24-2007 01:16 AM
Share your techniques for access panels in finished ceilings and walls Dustball Carpentry 9 07-14-2007 08:27 PM
A form to fill out for financing.. ultimatetouch Business 11 04-15-2007 11:46 PM
Solar Panels clueless in CT Electrical 1 11-23-2006 09:41 AM
How many Breaker Panels can I have robertc65 Electrical 6 02-10-2006 05:13 PM
