Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry
Old 05-06-2009, 03:34 PM   #1
24" exterior doors - where to buy?
I need to replace a set of double (48" wide) shed doors on the side of a 80 y/o home. Each door is 24" x 72" (clearly non-standard). The set I'm replacing were interior foam-core doors that someone cut down to size and which have badly weathered.
The local HD only has 24" solid pine panel interior doors - which I hesitate to use because the glue the mfr used was probably only for interior application & won't survive our extremes of heat, humidity & cold + ice. The local discount supply store has cheap steel doors - which I don't want to mess with - because the doors have to be cut down to size. This is for a good customer (whose given me several leads) - but who also doesn't want to spend a great deal on this eyesore.
Anyone know of a good place to get inexpensive solid core wood or pvc doors that I can use in this application?
Scott (the ex-grunt-tanker-jarhead guy)
Panzer5 is offline   Reply With Quote
Old 05-06-2009, 03:44 PM   #2
Lowes can special order solid core interior doors in 24"-they're 6-8, so you'll have to cut 8" off. I'm willing to bet if you double exterior prime and 2 coat exterior enamel, they'll hold up for many years...but I won't bet too much :-) I just bought a 26" solid for around $74-so the price is right. If you put a good piece of flashing at the top and have it stick out a little more than usual, it should help. On the other hand, if it's facing the direction of the prevailing winter wind, all bets are off.
include your location with your signature-it helps when advising.
72chevy4x4 is online now   Reply With Quote
Old 05-06-2009, 04:13 PM   #3
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Isn't there a real lumber yard or millwork shop by you?
I wouldn't buy stuff like that from a big box store.
silvertree is offline   Reply With Quote
Old 05-06-2009, 07:55 PM   #4
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
Have someone make them?!?
That would be too easy.
WarnerConstInc. is offline   Reply With Quote
Old 05-06-2009, 08:23 PM   #5
mmike032's Avatar
Trade: trim carpentry
where does you lumber yard get their doors from? have them special order some for you.
this company serves the south, go to their vendor page and find one close to you.
they have a shop here and make doors to whatever specs I need
http://www.tuckerdoor.com/Home/tabid/37/Default.aspx
mmike032 is offline   Reply With Quote
Old 05-06-2009, 09:12 PM   #6
LRG WoodCrafting
Leo G's Avatar
Trade: Professional Sawdust Producer
But who could possible make a door such as that?
Measure Twice Cut Once -- It's a lot easier to cut more off then it is to cut MORON.
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline   Reply With Quote
Old 05-06-2009, 10:00 PM   #7
Who ever that guy was, we better track him down.
Old 05-06-2009, 10:04 PM   #8
Yeah, just order 'em from Leo,
or maybe Gus could have Asimo
build 'em.
neolitic is offline   Reply With Quote
Old 05-06-2009, 10:06 PM   #9
Neo you got a thing for Asimo?
Old 05-06-2009, 10:08 PM   #10
No gus is the robot guy.
Asimo is the only one
I know by name.
Old 05-06-2009, 10:19 PM   #11
Teetorbilt's Avatar
Those doors are a piece of cake Leo. Two weeks at best IF the scrollwork on the lower panels have to be hand carved inside and out.
Panzer, a local millwork would have no problem with the doors. Inexpensive is difficult, have you priced quality wood lately?
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 05-07-2009, 07:43 AM   #12
LRG WoodCrafting
Leo G's Avatar
Took me about a month to make the whole entryway and the doors. Doors took 3-4 days.
Carpenter by day.
http://lrgwood.com
24" oc ? John1 Drywall 29 07-06-2009 06:19 PM
pulldown stairs and roof trusses 24" oc ezj62 Roofing 14 01-30-2009 09:23 AM
12" versus 24" bucket Driftwood Excavation & Site Work 14 04-26-2007 08:42 AM
