Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC > HVAC Picture Post
Old 05-23-2008, 02:12 PM   #1
Trade: Roofing
Rheem
I am looking into getting a 5.0 ton Rheem 13 seer central system for my 1800 sq. foot 1986 double wide trailer. Can any of you tell me a little something about this unit, and will it fit inside? Thanks in advance
bhinterl is offline   Reply With Quote
Old 05-25-2008, 06:08 PM   #2
Trade: hvac
Where are you located that you think you need a 5T for your application?
playsinmud is offline   Reply With Quote
Old 05-26-2008, 09:05 AM   #3
Trade: HVAC Contractor
I agree with playsinmud. Unless you are going to be using your mobile home for a large server room or a pottery kiln then 5 tons is probably way too much.
Mobile homes from the 80's were actually insulated pretty well.
westernhvac is offline   Reply With Quote
Old 06-01-2008, 08:41 AM   #4
coolmen's Avatar
Trade: hvac
5 tons what are you jokeing. get a load calculation done. something that big will cost a lot to run and your trailer will feel cold and clammy(damp). depending on insulation and window, probally more like 2.5 to 3.5 tons
load calculation,load calculation,,,,,,,,,,,,,,,,,
coolmen is offline   Reply With Quote
Old 06-18-2008, 04:52 AM   #5
acefurnacefxr's Avatar
Trade: HVAC
Maybe he wants to hang sides of beef in there?
Our 44 th is the best one yet..........
acefurnacefxr is offline   Reply With Quote
Old 07-09-2008, 07:38 PM   #6
HVAC Tech, NATE certified
Trade: Hvac technician. Economy Heating, Pittsbur
in pittsburgh pa, the average 2 story house, plus basement. 3 bedroom with black shingle roof uses a 3 or 3.5 ton
Verbal is offline   Reply With Quote
Old 02-17-2009, 02:00 AM   #7
Trade: hvac
I agree 5tons is way too much you'll have problems with mold very soon!
lawrencew is offline   Reply With Quote
Old 02-21-2009, 01:26 AM   #8
Trade: Mechanical Contractor
I would also verify the furnace is applicable for mobile home use.
Texahoma is offline   Reply With Quote
Old 04-14-2009, 11:14 PM   #9
unless i am mistaken... more cooling = more dehumidification? i mean unless below dew point ?
honest question i just dont see how this would make things moldy.
boot83 is offline   Reply With Quote
Old 04-27-2009, 07:44 AM   #10
NICKTECH
NickTech's Avatar
Trade:
Send a message via AIM to NickTech Send a message via MSN to NickTech
more cooling = less dehumidification. the greater the capacity, the faster the system will pull down the temp. and satisfy the tstat shutting down the system. the unit wont run long enoughto properly remove the humidity leaving a cold but clammy feeling in the air, like a cave. the moisture will now condense on what ever is the coolest in the home like interior walls, fixtures etc. the moisture builds up and seeps into nooks and crannies and...yadda...yadda...yadda, mold.
NickTech is offline   Reply With Quote
Rheem FVIR power vent water heaters Sewerologist Plumbing 11 02-19-2009 01:24 PM
Rheem Marathon NickTex Plumbing 8 06-05-2008 05:15 PM
problems with Rheem tankless hot water heater configuration? KesslerDweller Plumbing 22 05-13-2008 11:35 PM
Rheem Furnace SparkyInCanadaE HVAC 2 10-03-2007 12:58 AM
rheem rudd heatpumps wiring diag help airtech HVAC 1 11-25-2005 09:14 PM
