Painting Hvac That Got Sprayed By Pva Texturing?
Old 09-12-2009, 05:47 PM   #1
hvacgirl's Avatar
Trade: hvac
We are trying to paint new commercial ductwork but it has been sprayed w/ pva by the drywaller. Can we paint over this or does it need to be removed? Will the pva act as a primer or might we be in danger of the painted pva chipping off later?
hvacgirl is offline
Old 09-13-2009, 01:57 AM   #2
Metro M & L's Avatar
Trade: Painting & Flooring
Re: Painting Hvac That Got Sprayed By Pva Texturing?
http://www.duspec.com/DuSpec2/produc...Type=datasheet
I did some research and but I didn't find anything directly relevant. PVA is essentially glue. The msds for ICI pva indicates that on old work deglossing of shiny surfaces is recommended. I'd go with the finger nail test; if you can easily peel it off with a fingernail it should be removed. I suspect the galvanized hvac is sufficiently porous to allow for a relatively good bond by the pva. I would reprime with a metal primer and then paint.
"Yeah... It's worthy of a sig quote."
Metro M & L is offline
Painting business start-up questions oneelwayfan_com Painting & Finish Work 56 02-02-2010 01:55 AM
HVAC License vs Bond? Brian82 Contractor Licensing 2 08-20-2009 05:04 PM
Painting and handyman, should I simplify? englishdave Business 9 04-14-2009 07:19 PM
painting over enamel stripes mfrancis Painting & Finish Work 2 11-17-2008 10:30 AM
HVAC Licensing question kdan General Discussion 2 08-25-2008 09:17 AM
