Trade: Mechanical contractor
Heil 2.5 Tons Heat Pump Air Handler
Drain line no water come out.Water suck back to the coilc.Negative pressur.I check a fan diretion is corect.
What wrong???Please HELP |
#2 | |
Trade: H.V.A.C Contractor
Re: Heil 2.5 Tons Heat Pump Air HandlerQuote:
Did you take the knockouts out? Is the drain line blocked? Whats in the drain pan? Is the coil level or leaning backwards?
"Air conditioners are like eggs they are cheaper in the country." |
Negative pressure on the drain line can often mean that you don't have a trap or a trap of the proper weir dimension on the drain line. Veturi effect.
#4 | |
Knock_out OUT. Drain line is clear. Coils level ( down hill/not leaning backwards.) Water run douwn between the fins,into the pan,at near end of drain line and the pan water pullup out of the pan. If opened the panel cover,water run down to the drain line. Can some one Help me out.Thank |
Dear Hvacmangod.
I do not think you need to known a real problem.All of a mechanical contractors they known their trade. Just try open more supply line also try open one more drain line. I hope your systerm will work well. |
Trade: HVAC tech-installer
adjust the fan speed on air handler. you only need 400cfm per ton.
I'm just eaves dropping on your conversation, but am curious about the 400cfm/ton comment. If the fan speed is too great, will that cause the negative pressure in the AHU? And also, how would that effect the cooling system in general (i.e. outlet temp would be higher but greater quantity-so does it still take longer to cool home)?
WTF is up with all the new users with only like 2 or 3 posts, not making any sense, and with just about the same names....
Electro-Mech. Contr.
Trade: Mechanical Contractor
If the drain is properly trapped then you are hurting for air (not enough return) my improper english using friend. Whats with the alter ego answer? Stevie wonder could see that relationship.
"Injustice anywhere is a threat to justice everywhere" mlk 100% Union and Proud of It Last edited by MechanicalDVR; 07-26-2008 at 08:44 PM. |
And where are the pictures?
| Run a Heat Pump on solar power | SR Martin | HVAC | 173 | 11-20-2010 12:38 PM |
| Heil #10 heat pump thermostat | craigww | HVAC | 3 | 08-28-2007 06:19 PM |
| Tricks to sizing a heat pump | Danno6102 | HVAC | 1 | 06-28-2007 06:05 PM |
| heat pump help!?!!! | maxkd | HVAC | 1 | 11-10-2006 08:57 PM |
| Heat Exchanger Inspection Methods | MechAcc | HVAC | 3 | 04-14-2005 04:38 PM |
