Sunny Southern California
Rough Plumbing
Pics of new bathroom
Re: Rough Plumbing
Looking good!!! :Thumbs:
#3 | |
Plumber
Trade: Plumbing
Re: Rough PlumbingQuote:
Re: Rough Plumbing
Plumbing is looking good! Don't forget the insulation and I'm not a fan of OSB, but everyone knows this already.
Re: Rough Plumbing
And your question was what?
Re: Rough Plumbing
I went ahead and slapped up a couple of nail plates for you, so that the inspector wouldn't hollar.
| The Following User Says Thank You to mdshunk For This Useful Post: | FramingPro (10-01-2011) |
Plumber
Trade: Plumbing
Re: Rough Plumbing
Now try and get pex piping to look that good . .
| The Following User Says Thank You to tzzzz216 For This Useful Post: | plummen (01-01-2012) |
#8 | |
Mod / ArchiBuilder
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
| The Following User Says Thank You to Cole For This Useful Post: | plummen (01-01-2012) |
Electro-Mech. Contr.
Trade: Mechanical Contractor
Re: Rough Plumbing
It looks ok but, I would add 3/4"air chambers to the 1/2" risers especially on the shower valve. Single levers are notorious for water hammer.
"Injustice anywhere is a threat to justice everywhere" mlk 100% Union and Proud of It |
The Grand Wazoo
Re: Rough Plumbing
Every outlet has to have an airchamber here, and you have to provide 24" airchambers at the top of all risers.
Re: Rough Plumbing
It isn't code here but, it should be. I always believe in adding them. I have seen way too many houses around here that are plumbed in only 1/2" copper, you close a faucet and the echo sounds like thunder.
Trade: Plumber
Re: Rough Plumbing
We have to add 'em on shower valves & laundries - 3/4", 18" long.
Trade: PLUMBING CONTRACTOR
Re: Rough Plumbing
wow no copper down here in fla, in residential homes, moreless cast for cast
Trade: plumbing/heating
Re: Rough Plumbing
Air chambers will fill with water within 2 months! Waste of time/material!
With city water {100# or so}, install a pressure reducer. Set at 50-60#. Codes say 80# is MAX, for just that reason. 60# is PLENTY. Another tidbit... noise is also caused by the burr left by cutting copper pipe! Water swirls inside pipe and w/over 80#, sounds like a train passing thru the house. |
#15 | |
Trade: Plumber
Where do you live? |
Trade: industrial plumber
Re: Rough Plumbing
Not squaring up those holdrites would get you doughed up on my job.
| The Following User Says Thank You to 422 plumber For This Useful Post: | Sharkbiter (04-28-2011) |
#17 | |
Trade: Plumbing and Electrical, Building
| under-slab plumbing / DIY | ruger9 | Plumbing | 28 | 03-09-2009 01:31 PM |
| plumbing codes question for new construction?? | national | Plumbing | 19 | 07-12-2007 05:54 AM |
| Residential Rough in Estimate Central Florida | Surface Tension | Plumbing | 7 | 06-17-2007 12:23 AM |
| Locating plumbing in an outside wall | Mike Finley | Plumbing | 15 | 09-09-2006 07:49 AM |
| New construction rough plumbing layout | kafanslr | Plumbing | 6 | 04-01-2005 12:01 PM |
