#61 |
Re: Reasons Not To...
Thanks guys.
I was just hoping for a nice fat quote to smack the guy with. "By sticking your condensate in the trap, you violated 307.2-29, the Legionella section!"
#62 | ||
Capra aegagrus
Re: Reasons Not To...Quote:
Gotta make some calls. Carry on. |
#63 |
Pro Plumber
Trade: Plumber
Did you know a plumbing inspector has the power in this state to put a violator under arrest for repeat violation.
#64 | |
![]() Just what I was looking for. I knew it was wrong, but didn't know how to phrase it for him. ![]() ![]()
#65 |
Pro Plumber
Trade: Plumber
Wow that took 63 post to get you the answer you wanted.
#66 |
The Grand Wazoo
Probably because I was to stupid to grasp what Neo was trying to get to in the first place.
#67 |
Pro Plumber
Trade: Plumber
Re: Reasons Not To... |
#68 | |
to talk to a plumber if I can't wave my arms, draw pictures, and cuss! ![]() ![]() Thanks guys. ![]() ![]() I always learn something.
#69 |
Worth every penny.
#70 |
Moderator
OK Neo, quick plumberspeak lesson for you.
Standpipe, basically a pipe sticking up in the air to receive the discharge (usually from a washing machine) with a trap at the bottom of it. Air gap, Is is simple what it sounds like. It is a gap of air, between the outlet of the fixture (think tub spout or faucet spout) and the level at which the fixture (think sink) would flood. In other words, the highest point the sink can hold water, before it runs over. An air gap is needed to prevent dirty water from getting back into the spout. In this case, its to prevent the HVAC A Coil from getting a bad case of the nastys from the sewer. An air gap can also be a mechanical device that holds the outlet of a fixture (like the water softener) above the flood rim of a "fixture"... in this case, the "stand pipe". It would bolt on or glue onto the 2 or 3 inch pipe, and have a "bowl" built into it, with a hole for the water to go out, and a thingy to hold that hose tightly over that "bowl". I also question the fixture unit sizing of that 2" drain. I think its right at being overloaded. If you figure a kitchen sink with disposer, and dishwasher, then add the washing machine, the HVAC condensate, and the water softener... It should have failed 5 years ago. Also, I'm under the IPC here... 2006 with Arkansas revisions I think. We require a trap primer on all traps that receive condensate, as this is a seasonal use of the trap. It needs water in it at all times to do its job. In the winter, it will dry out and allow sewer gases into the house. Also... we might require an interceptor to neutralize any acidic or high PH water before it can be allowed into the sewer. So. That thing ain't right no matter how you slice it. My suggestion, have her call the HVAC folks and have them come look at it. They have violated the mechanical code I guarantee it. The mechanical code will cite the plumbing code for proper condensate discharge requirements. That ain't proper. So, they hosed the UPC plumbing and the mechanical. It also ain't "workman like" in manner. Altering a fitting by cutting the side of it ain't workman like. If they don't want to fix it, have her call a local plumber and get their words on what it will take to fix it, then call the mechanical code inspector and the plumbing inspector in the area and complain. I bet the HVAC folks will be out there in a jiffy with a licensed plumber to make it right. Oh, and while you're there... if that is a gas furnace, check to see if they are penetrating the sheet metal surround of the furnace with the gas entrance with a gas flex or hard steel. Here you have to have hard steel or protect the flex against abrasion. I bet they overlooked that as well.
#71 | |
little 3X5 paper things that say Kodak on the back. ![]() Pictures of the rough-in show my memory ain't what it was. Kitchen goes to the main stack, and there was a funny looking piece of plastic on top of that 2" that looks kind of like a dome with a window on the side? All I remembered was it was a lot taller than now. Can't tell what was happening with the old softener line. Apparently none of that was interesting enough to take good pix. ![]() I've got all the stuff that we poured concrete on or drywalled over though. Thanks for futhering my edumaction.
#72 |
Pro Plumber
Trade: Plumber
Did it look like this?
#73 |
Not that complicated, I think.
It just shows through the back wall of the shower. Like I said I wasn't really trying to record anything that wasn't being covered up. No idea that any of this would ever be an issue. I can tell that there is some kind of "window" or cut out in it. If I had to say,it might be kind of like a cap with legs? Really hard to see.
#74 |
Lack Of All Trades
Trade: Professional handyman services
Great how the guy notched out that drain pipe to accomodate the 3/4 " pipe. Musta took every bit of a half a day to do that..
#75 |
They are sending a super out
Tuesday P.M. to "assess" the problem. To be continued............
#76 |
Well,this is what the HVAC guy did.
I'm gonna guess it's not finished? ![]() The top of that pipe looks to be at least 8" above the sink rim. The plumber said he originally had a "stand pipe air gap." He'll give me another one tomorrow if he's got one in the shop. I'm guessing from the old pix that it was something like this one? ![]() If that is the case, I just wonder what would be the difference between that, and just drilling/ cutting a couple of holes in the pipe just above the flood level? Trying to learn something here, I'm sure it's flawed logic.
#77 |
After I mentioned the air gap
to the HO, she had them out again last week. This is what they left her with. ![]() It seems to perform the function, at least I don't know what to argue with. I put the black mark on at the level of the laundry sink rim.
#78 |
Builder/Remodeler
Looks half-assed.
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
#79 |
N/S?
![]() I do believe it's functional though. Other than esthetics, I'm not sure I can fault him. I'm sure ready to be over it, and she's happy the suds don't belch out on the floor.
#80 |
Trade: H.v.a.c.
Why wouldn't the hvac guy simply install a condensate pump ($35.00 wholesale) and plumb it into the washer drain? No need to mess with the plumbing, and all the potential headaches. Better yet, if the water softener pipe was already there, just pump to that pipe. Simple Simon no more issues.
| Reasons why HO's choose the low baller | john elliott | General Discussion | 7 | 04-26-2008 01:48 PM |
| 6 reasons not to mess with children | Contract | Off Topic (Non Trade) | 4 | 08-01-2007 07:53 PM |
| Reasons to offer a new percieved closing incentive | Ed the Roofer | Marketing & Sales | 15 | 05-01-2007 12:55 AM |
| List of reasons that people buy things | Paul Burns | Painting & Finish Work | 9 | 01-20-2006 12:40 AM |
| healthy home construction tech | rickatoid | General Discussion | 5 | 10-27-2005 12:10 PM |
