Reasons Not To...
This was a 28-30" stand pipe
when my plumber put it in. ![]() ![]() HVAC guy changed out the air handler and did this. (horizontal ¾" is condensate.) Up stream is the washer and utility sink. "Occasionally", as the stains attest, this thing over flows, though I can't make it happen. Would there be anything wrong with putting in a sanitary tee and running the condensate line into a bushing? Any more clever ideas? Ooops, vertical ¾" picks up softener drain.
Doofenshmirtz Evil Inc.
Re: Reasons Not To...
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber |
#3 | |
The Grand Wazoo
Re: Reasons Not To...Quote:
#4 | |
Is there no difference if it were, say 8" (pick a number) above the flow line of the trap outlet? That's why I'm asking. F**king tinner!
solar guy
Trade: solar contracting
This is a possible cross connect situation. the code says that you need to have a minimum of a 3" air gap above the flood level rim to drain condensate etc. This means that if you were draining the softener into the sink the drain outlet would have to be 3" above the rim of the sink to eliminate any backflow situation. In this case I would raise the standpipe to 24" again. Install a "Y" fitting with about about a 3" vertical section. From the straight section of the Y fitting I would extend the original drain up about about a foot. Terminate the condensate etc into the vertical section at least 3" above the terminus of the open ended Y section so there can be no backflow situation. This all assumes that there is a trap at the bottom of the standpipe and a proper vent. Does this make sense?
Not possible without a pump.
Tray on the A coil is about even with the rim of the sink. Drain line has to go down to miss the access door on the air handler.
Now that I think of it,
the idiot put the end of his line in the trap. I'll tell her to have him pay for or give her a pump. She'll love the Legionnaire's part. Thanks guys.
The Grand Wazoo
It would have to be 25 FEET above the trap to prevent a possible syphon, and trapping the condensate will not protect from the possibilty of sewer gas, as condensate traps are not vented. In Chicago you are required to provide a floor drain in a mechanical room for this very reason.
#9 | |
when they hand dug this basement in 1929. ![]() Get the PM?
Certified Remodeler
Trade: Kitchen bath remodeler
Install the stand pipe with drum trap a and pump the condensate into that.
Of course that's the wild *ss sh*t some carpenters do
Vote for Pedro Kitchen, bath, St Paul remodeling Minneapolis Remodel Blog 203K Loan Consultant Minnesota |
solar guy
ok pump for condensate works. raise standpipe create and air gap to prevent backflow. BTW how much iron is in the water. either that or someone is s
ing in the drain. how far away is the vent. do the owners run the washer at the same time the softener regererates? many possible causes. you really need to raise the standpipe to eliminate the overflow. make hvac guy put in a pump and restore to what it was.
Builder/Remodeler
Who did that work Neo..... so I can avoid them...
If you don't mind telling, send me a PM.
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
#14 | |
did other work in the basement. I will be finding out tomorrow, if he left a sticker I'll post.
#15 | |
Don't know what the stain is. More yellow than iron, and it's city water, usually just limey. If you saw how tight it is back there it would eliminate your suggestion.
Anyone who can give me a code cite?
We are UPC (1997 with amendments I believe.) HO is having the HVAC guy call me. I'd like to be prepared for B/S.
Pro Plumber
Trade: Plumber
According to UPC that Indirect waste needs an airgap. Location could be an issue here. I bet the bottom of that trap is less then six inches, but this trap by it's self is not for a laundry drain right?
#18 | |
are up stream from there (to the left in the first pic.) There was originally a 2" pipe on the trap that was above the sink rim. The softener and condensate just dumped into the open pipe. I'm probably wrong calling that a stand pipe. Any way the HVAC guy put the end of that ¾" line in the trap water. I want to give him the code that says that is a no-no. I'm guessing it's in 307.2 something? I'm going blind looking.... I hate your code books!
#19 |
Maybe this makes it clearer.
![]() All of the ¾" and the 2X3 adapter were done by the HVAC guy when he changed out the furnace. That is the softener drain coming in the top, and there is a piece of ¾ coming down below the tee that sticks into the trap water.
#20 |
Pro Plumber
Trade: Plumber
It need an air gap, period.
| Reasons why HO's choose the low baller | john elliott | General Discussion | 7 | 04-26-2008 01:48 PM |
| 6 reasons not to mess with children | Contract | Off Topic (Non Trade) | 4 | 08-01-2007 07:53 PM |
| Reasons to offer a new percieved closing incentive | Ed the Roofer | Marketing & Sales | 15 | 05-01-2007 12:55 AM |
| List of reasons that people buy things | Paul Burns | Painting & Finish Work | 9 | 01-20-2006 12:40 AM |
| healthy home construction tech | rickatoid | General Discussion | 5 | 10-27-2005 12:10 PM |
