Trade: building managing
Radiant HeatHelp! How can i locate a leak in a loop buried in concrete. The line was pressure tested and lost 10lbs of pressure over 12 hours. There is no surface water. There is a wooden floor over it,which was partially removed as it had bubbled up.
Its all ball bearings
Trade: Tile
Re: Radiant Heat
1) Why did you post this in the plumbing picture section?
2) Call a plumber. |
Trade: Sales/Distribution/Installation of low or line voltage radiant heating and snow melting systems
Re: Radiant Heat
If no one here can help, try the Radiant Panel Association forum.
Trade: Plumber gas fitter
Re: Radiant Heat
Hello. Do have have access to the concrete? there is an old trick. Mop the concrete over the pipes and let the infloor heat. you shoud see the heating lines clearly. If you see a spot appear there is your leak.
Trade: General contractor
Re: Radiant Heat
Call a leak detection company. We have used american leak detection. Bang on everytime.
#6 | |
Trade: HVAC and plumbing.
Re: Radiant HeatQuote:
Trade: Construction
Re: Radiant Heat
We went to a house once where a company had laid pipes in the concrete and put a vapour barrior over the pipes before screeding. They had a leak and we couldnt find it for crap. They had to jack hammer the whole screed up where the pipes were. Dumb asses didnt pressure test before laying concrete
. good luck
| Radiant Barrier Fact Sheet | Ed the Roofer | Roofing | 0 | 02-09-2008 08:57 PM |
| Radiant heat in ceiling | clkesmsh | Drywall | 6 | 02-05-2008 10:29 PM |
| Demo a foundation under a radiant heat slab without disturbing the slab...? | wackman | Remodeling | 18 | 04-02-2007 12:38 AM |
| Hardwood Floors over Radiant Heat | bigtick | Flooring | 10 | 12-08-2005 03:43 PM |
| Heat Exchanger Inspection Methods | MechAcc | HVAC | 3 | 04-14-2005 04:38 PM |
