Tuscan Leveling System
Old 06-17-2012, 07:04 AM   #221
If my PO asks,I set tile
Evan1968's Avatar
Trade: Commercial Tile Installs
Rewards Points: 1,160
Re: Tuscan Leveling System
Your right, I'm a commercial hack.......
Tuscan Leveling System-img_1589.jpg   Tuscan Leveling System-img_1557.jpg   Tuscan Leveling System-img_0016-1-.jpg
Craig
Tile Installations Unlimited
"If you can't wow them with knowledge,baffle them with bullcrap."
Evan1968 is offline
Old 06-17-2012, 10:59 AM   #222
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
All me. Construction. Setting. Floating Hearth. Mirror Install. Lighting.
All me. Carpentry. Tile. Sealing. Design. Build.
Action shot. All me.
Some how I managed to use shims and my thumb to build all these. Evan because I choose to not set all my projects does not mean I don't know how.
JW
JohnFRWhipple is offline
Old 06-17-2012, 11:09 AM   #223
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
And just because someone doesn't follow what you think to be a correct method doesn't make them wrong either. I'll be honest, I don't have to check my coverage. I can tell whether it's good or not when I'm setting.
Enough of the testosterone posting.
Angus
angus242 is offline
The Following 3 Users Say Thank You to angus242 For This Useful Post:
Evan1968 (06-17-2012), Groutface (06-17-2012), PrecisionFloors (06-18-2012)
Old 06-18-2012, 09:13 AM   #224
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Originally Posted by Groutface
Here's today's rls job 24 x 24, 200 sq ft......cost.........$22 for pillars......super flat
Just went to other supplier $13 for 100 clips,$21 for 100 wedges
Groutface is offline
Old 06-18-2012, 10:36 AM   #225
Angus sorry. You need to check your coverage. This is a step I see every Pro here in Vancouver do - I do it, they do it. And it's required by all tile bodies that it be done.
I doubt you can "Hear" the sound of proper coverage on every tile and every job. My guys nor I check every single tile but we still check. Most times it's after a fresh bucket of thin set or towards the end of the working time. But checking is the safe guard and takes no time at all.
The toy guns are silly - My opinion. Not checking for coverage rates is equally silly. Not using a straight edge - Sillier still.
What is a testosterone post?
JW
Old 06-18-2012, 06:48 PM   #226
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Opinions and a-holes.......everybody's got one :
Angus
angus242 is offline
The Following 4 Users Say Thank You to angus242 For This Useful Post:
Bud Cline (06-18-2012), Evan1968 (06-18-2012), I Mester (06-18-2012), PrecisionFloors (06-18-2012)
Old 06-18-2012, 07:59 PM   #227
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,282
JW
JDub,
I think Craig just likes to bust your chops now and again.. checking coverage is important but Craig installs 50 - 80k sf per year so we all know where he's coming from. In commercial, there is no time for that, ya just gotta know what you're doing
The only callbacks ever mentioned to me by Craig was a couple grout repairs however, most all commercial projects spec standard cement grout to save $$$... Id say that's their problem though
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 06-18-2012, 08:20 PM   #228
Holy Crap!
ROVACON's Avatar
Trade: General Contracting-Renovations-Carpentry
Rewards Points: 296
I'll be honest, I never check coverage when a membrane is involved.
Too many times has it damaged the membrane in return and most of the time the membrane has been installed 24-48hrs prior to the tile.
Especially if I am using Ultraflex 2 That stuff is like a freakin flytrap!
Brian
ROVACON is offline
The Following User Says Thank You to ROVACON For This Useful Post:
Groutface (06-18-2012)
Old 06-18-2012, 08:34 PM   #229
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
You're silly. WOOT!
Angus
angus242 is offline
Old 06-18-2012, 08:36 PM   #230
Groutface
Groutface's Avatar
Rewards Points: 524
New use for ultra flex 2...... Fly trap......its good stuff....
The Following User Says Thank You to Groutface For This Useful Post:
ROVACON (06-18-2012)
Old 06-18-2012, 08:37 PM   #231
Holy Crap!
ROVACON's Avatar
Rewards Points: 296
You're silly. WOOT!
Only on Mondays......
Brian
ROVACON is offline
angus242 (06-18-2012)
Old 06-18-2012, 08:46 PM   #232
Tech Dawg's Avatar
Good point. I don't pull back membranes either except for once when I first tried laticrete's Sure Set to set a floor membrane. I was investigating how it works since its a full contact mortar and creates water dispursion after enclosed to back butter itself. I lightly smooshed the membrane down by hand and lifted a section to check and it was fully covered. I've been using that thinset for membranes ever since... Works great!
Todd
The Following User Says Thank You to Tech Dawg For This Useful Post:
Old 06-29-2012, 09:44 AM   #233
I'm surprised you men don't check your coverage rates. If your worried about your waterproofing membrane I think you need a new membrane or need to give your membrane more time to cure.
Checking coverage is the only way to know how they are setting. All my top setters do this and so do I.
Not checking coverage rates is like building a shower and not flood testing it - your just hoping it's good but really have no idea.
The TCNA specification guide in the Field and Installation Requirements section on page 32 outlines periodically checking the coverage rates. Your aiming for 95% coverage in the showers, no voids over 2" and no voids in the corners. Pretty hard to guess on this I'm thinking.
JW
Old 06-29-2012, 10:01 AM   #234
Holy Crap!
ROVACON's Avatar
Rewards Points: 296
JW
John-
I totally understand what you are saying and practicing. However, When I install tile, my thinset is combed in the same direction, my tile is burned before laying and uniform pressure and movement is used for each tile.
That being said, checking coverage is fine but you're only checking periodically anyway. So, your coverage is only as good as the last tile that you checked.
I installed a shower not to long ago with Nobel TS (great sh!t) and used ULTRAFLEX 2 as my setting material. 48 hrs later I began wall tile installation. A day and a half later, the homeowner decided she wanted solid slab jambs and not bullnose. I painstakingly removed each tile but inevitably ripped up the membrane in the process (don't worry a little Aqua D took care of that ).
Three and a half days should be long enough for a cure time IMO for the fabric to really be locked into the thinset.
I do practice flood testing, it goes a long way with my inspectors and I do believe in always using a water proofing membrane of some kind.
I simply don't believe that you need to constantly check coverage to be considered a PRO. Sorry that took so long to say!
Thanks.
Brian
ROVACON is offline
Old 06-29-2012, 10:19 AM   #235
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,080
Originally Posted by ROVACON View Post
John-
Thanks.
Like saying you aren't a pro unless you test every wire you run...piss on that.
Inner10 is offline
Old 06-29-2012, 05:11 PM   #236
Evan1968's Avatar
If you were to go back in history and take every president, you'll find that the numerical value of each letter in their name was equally divisible into the year in which they were elected. By my calculations, our next president has to be named Yellnick McWawa.
In other words...thanks Cliff Claven for actually getting out the guide and telling us something we already know.
Craig
Evan1968 is offline
Old 06-29-2012, 05:42 PM   #237
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Bravo!
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 06-29-2012, 06:31 PM   #238
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Angus
angus242 is offline
Old 06-29-2012, 06:38 PM   #239
Groutface
Groutface's Avatar
Rewards Points: 524
Classic Claven
Old 06-29-2012, 06:45 PM   #240
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Are you professionally suggesting that we piss on wires to test them?
Angus
angus242 is offline
clemco easy load system and closed circuit blasting system goosesgarage Sandblasting 9 11-22-2010 11:41 PM
Weep system for thin veneer Stone Masonry 3 07-01-2010 11:15 PM
Inspector wants fire sprinkler system TLE/RL1911 General Discussion 90 06-04-2010 04:35 PM
forced hot-water system daniem1 HVAC 1 03-02-2006 04:37 AM
