Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring > Flooring Picture Post
Old 07-08-2009, 06:53 PM   #1
Trade: Registered (cough) Home Improvement Contractor
Awesome flooring
Visiting a potential customers potential home to give an estimate...there is alot of work to be done just for the CO....College party house, if I end up working there I will take much better pictures.
Alittle water damage.
Hard to tell, there is a 1 foot high blister in the middle of the room, solid as a rock.
And this is where the stripper poll and the couches were...
Alwaysconfusd11 is offline   Reply With Quote
Old 07-08-2009, 06:57 PM   #2
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
rip it out and start all over !
who dat is?
Darwin is offline   Reply With Quote
Old 07-08-2009, 06:59 PM   #3
Going to be a rental unit...rip out and put carpet
Old 07-08-2009, 07:10 PM   #4
Lack Of All Trades
Darwin's Avatar
You're gonna put carpet in the unit? So the tenants can stank stank stank it up?
Then you'll have to get it cleaned everytime you rent it out. Probably on average 3 times a year(taking into consideration that good tenants are hard to find) . That amounts to: $150 x 3 = 450 per year. Might be cheaper in the long run to just redo those floors on the cheap.
who dat is?
Old 07-08-2009, 07:17 PM   #5
1. Not my property.
2. I do not know the actual average, but between the 40 or so rentals I do know of in the area, the average rental is much much longer.
3. Those rentals also all have carpet.
Old 07-08-2009, 07:20 PM   #6
Lack Of All Trades
Darwin's Avatar
1. Not my property.
just pokin' fun..
who dat is?
Old 07-08-2009, 07:22 PM   #7
I agree with you and if it were my unit I would do hardwood and tile....
...but we all know its what the customer wants.
Old 07-08-2009, 07:25 PM   #8
Lack Of All Trades
Darwin's Avatar
I know..THE CHEAPEST ALTERNATIVE ......
who dat is?
Old 07-08-2009, 07:27 PM   #9
Jumping over dollars to pick up pennies
Old 07-08-2009, 08:47 PM   #10
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
I vote to replace the stipper pole and maybe add a few black lights and a fog machine. I think they could get quite a bit more in rent.
WarnerConstInc. is online now   Reply With Quote
Old 07-08-2009, 08:48 PM   #11
That will be in the residents part of the house...I just wish I could have been in the house during one of th parties.
Old 07-08-2009, 08:50 PM   #12
I know it will be, that is why I suggested that it be put back, how much for rent with the pole? I might have to re-locate!!
Old 07-26-2009, 01:45 PM   #13
Trade: Flooring & Remodeling
Repair it
I run into insurance jobs like this all the time . Simply cut out the damaged areas with a worm saw with a new blade . Try not to cut off the male tabs where you wish to save the floor . Remember to tape off with 2" blue tape at areas you do know wish to remove flooring to prevent extra scratches .Use a small sharp chisel to remove the excess wood from the female grove & under male tab . You can find replacement wood at prosourcefloors.com or at their local showroom. Fold the new boards in like an open book . You might have to rip down the last row due to the expanding of the water damaged wood . If its a pier and beam house , suggest an Dbl electrical floor outlet to cover the hole from the stripper pole. Don't forget to test the moisture content of the sub-floor with a good Tramex moisture reader .
Or you could just cut out the hump and lay a cheap laminate floor over the whole thing...
finaltouchfloor is offline   Reply With Quote
Old 09-01-2009, 09:50 PM   #14
Trade: Remodel/Deck
With those kind of tenants, I think I would put down some Trex decking instead
Rustbucket is offline   Reply With Quote
Old 09-17-2009, 11:26 PM   #15
Trade: Painting & Flooring
Not a bad idea. I still don't think it would hold up.
Metro Maintenance & Landscaping
http://www.pdxmetropainting.com
Metro M & L is offline   Reply With Quote
Old 09-28-2009, 08:59 PM   #16
Knowledge Factory
Floordude's Avatar
There is still moisture in the floor!!
How do I know? It is still buckled.
If it had lost the moisture it gain, the boards would be back to the original installed dimensions.
If you don't dry it out, your going to be back chasing the dragon.
http://www.AustinFloorguy.com
Floordude is offline   Reply With Quote
laminate flooring placement nwksremodeler Flooring 7 06-19-2009 09:24 AM
flooring or cabinetry first coupe33 Flooring 41 05-28-2009 12:02 PM
Air waves under new vinyl flooring geospec Flooring 25 05-28-2009 11:28 AM
Cork Flooring Questions.... SBI Flooring 3 12-12-2008 04:18 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
