Trade: painting
Spray Gun Still Spays Little Stream After Detriggering
Its only about a 2 inch line and its ok when brushing after spraying. But when doing aluminum or vinyl, cant have that. I have tried everything..new guard, gasgets, clean filter, lower pressure, loosen back screw?? Maybe needs repacking? Its been used on 7 houses and a sw contractor ($150.00)
Re: Spray Gun Still Spays Little Stream After Detriggering
Sounds like you need to take the gun apart and give it a good cleaning. Get you a gallon of Carburature Cleaner from NAPA and take the front of the gun off and remove the needle valve assembly. Soak everything in the cleaner over night and then clean everything back up with water and a nylon cleaning brush and put the gun back together. Adjust it up and it should work. If not, then get a re-build kit and replace the parts.
Benny Abbott Abbott Consulting and Coating Inspections E-Mail: babbott@abbottcoatinginspections.com Phone: (205-717-0292) |
| The Following User Says Thank You to painter213 For This Useful Post: | Mr. Mike (05-15-2009) |
Store Owner
Trade: Paint Store Owner
Gun starts randomly spitting....no cleaning job will fix it. It needs a new needle and seat. You can just replace the needle, but its not that much cheaper than changing both the needle and seat. Can be done by you so no need for service for around $50 ( usually if a customer buys a kit from me I install it for them in a bout 10 min )
www.northcromwellpaint.com Benjamin Moore Paint, PPG Paint, TWP Stains, Sikkens Wood Finishes, Airless Sales, Service, and Rental |
Trade: contractor
heh I had a similar problem...had to get a penicillin shot.
Trade: Painting Contractor
Rebuild it, like other poster said 50.00 and you should be back into a good spray pattern. You could take it apart and give it a thorough cleaning asnd it might fix your problem.
Sean |
#6 | |
Store Owner
Re: Spray Gun Still Spays Little Stream After DetriggeringQuote:
Side Effects May Vary
Trade: Professional Painting
Rebuilding the newer graco guns is simple, the older ones with the nut in the back were a little harder because if you over tightened them they wouldnt shut off, but even those were pretty easy after you did a couple.
Trade: Painting, Solar PV and Hot Water Systems
Get a new tip for your paint sprayer at home depot.
Clean the Gun. Open it up and clean the filter. That should fix it I had that problem before and I did that and it didn't happen again.... just gotta keep it clean is all. |
#9 | |
Store Owner
Yes, Home Depot, the savior of the building trades. The all carry magic wands in their aprons. Do you know they once brought my dead hamster back to life?
#10 | |
Sean |
Re: Spray Gun Still Spays Little Stream After Detriggering |
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
pull trigger as you tighten the top bolt!
Trade: Painting & Remodeling
Clean it, repack it, and maintain it. Spent two hours this a.m. redoing 3 guns...no sweat.
As soon as any of my guns start to show problems they get pulled and redone. (This year was the first year that I've purchased new guns and thats because I couldnt pass up on the pricing.) I'm a real stickler for clean equipment and my guys know it. If they cant take the time to clean and maintain equipment, I cant afford them no matter how good they are. |
Trade: painting & decorating
Hi have you sprayed accrylic fire retardent paint before?
| eliminating spray gun splattering | saucedo80 | Painting & Finish Work | 11 | 11-02-2010 02:47 PM |
| paint is stippling out of airless spray gun | scottcoleman | General Discussion | 2 | 01-16-2009 05:59 PM |
| Does Behr Ext. Satin spray easily? | renet | Painting & Finish Work | 2 | 11-17-2008 10:31 AM |
| How do you spray a room - new construction? | Zeebo | Painting & Finish Work | 16 | 01-27-2008 11:32 AM |
| Spray King Sprayer for sale | JCardoza | Tools & Equipment | 0 | 11-05-2007 06:54 PM |
