Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Painting & Finish Work > Painting & Finish Work Picture Post
Old 10-06-2008, 07:33 PM   #1
Trade: framer-inside/outside trim- asphault roofing/remoldeling
pre-prime question
procedures to priming after sheet rock sanding.
apparently I'm not a painter so what are these steps?
I'm thinking sweep walls let fall vacuum (spl). prime
ty in advance
passingwindII
rbeck3@ec.rr.co is offline   Reply With Quote
Old 10-06-2008, 07:38 PM   #2
genecarp's Avatar
If your taper is doing that much sanding, there is a problem, we never have to sweep the walls. after the final coat, we prime, if anything shows up after prime, we touch up, spot prime, and away we go....
genecarp is online now   Reply With Quote
Old 10-06-2008, 07:52 PM   #3
great, ty
and how about spraying the primer? just spray?
and any tips on paint, spray and roll is my objective.
ty
passingwindII
Old 10-07-2008, 07:11 AM   #4
NAV
Trade: commercial building restoration
It doesnt hurt to sweep the walls, at leas at eye level, it doesnt take long.
use a 415 to 517 tip to spray and backroll with an 18" roller setup.
NAV is offline   Reply With Quote
Old 10-07-2008, 09:26 AM   #5
Trade: painting and refinishing
light sand on walls after prime and away you go!
Traditions2 is offline   Reply With Quote
Old 10-31-2008, 09:46 AM   #6
Glad I don't laim to be a taper. I will at least do some dusting . Have been known to use a damp rag as tack rag to wipe with. I tack when I am concerned about the dusting from a brush or dry rag causing the dust to become airborn and settling back on th ewall or bb's.
I'm beginning to appreciate the dustless dw mud.
boman47k is offline   Reply With Quote
Old 10-31-2008, 01:26 PM   #7
Workaholic's Avatar
Trade: Painting Contractor
Ditto.
I also like to use a pva primer, especialy when dealing with darker colors.
Sean
Workaholic is offline   Reply With Quote
Old 01-21-2009, 09:22 PM   #8
Trade: painter
thats the way to go. Use a pole sander and it takes 5-10 minutes to do the whole room, about the same time it'd take to sweep the walls.
painter_dan is offline   Reply With Quote
Old 01-21-2009, 09:42 PM   #9
Trade: painter, roofer
Worst case sceanario when your painting over a lot of dust. You end up with a lot lil bumps which will be small and many if sprayed or big and few if rolled. Then again worst case scenarios get a 12 in knife scrape the whole wall then 2nd coat.
GWHRsuperhero is offline   Reply With Quote
Old 01-23-2009, 12:52 AM   #10
BJP
Trade: Painter
Why do you back roll with an 18" roller
BJP is offline   Reply With Quote
Old 03-28-2009, 09:17 PM   #11
Trade: Remodeling and Painting
18 inch roller is more efficient than a 12 inch roller on large walls or ceilings.
Soloplayer is offline   Reply With Quote
Contractor law question for california contractors saucedo80 Painting & Finish Work 7 04-18-2009 12:07 PM
Answer a Question with a Question Nathan Off Topic (Non Trade) 151 10-07-2008 02:07 PM
HVAC Licensing question kdan General Discussion 2 08-25-2008 08:17 AM
