Decking To Be Painted
Old 06-04-2007, 02:39 PM   #1
davidanbess's Avatar
Trade: Painting and Decorating
Hi The deck was painted last year using latex and the floor of said was painted given 2cts of b/m oil semi transparent gloss
1/ Now latex has started flaking in places (not a lot mind you)
What would your primer be and also your topcoat
2/ The floor is also flaking a little as you walk out from the doorwall
would I be able to apply exterior latex over the semi transparent
Ps As previously posted I arrived here in the states only last Feb and to be honest getting used to all the various materials is definately harder than I thought, for instance in the UK everything is still pretty much oil for exterior and emulsion (latex) for interior.
Anyway thanking you again in anticipation for your collective and constructive replies.
D/B
davidanbess is offline
Old 06-04-2007, 04:30 PM   #2
Woz the Painter's Avatar
Re: Decking To Be Painted
D/B
A little confused, you say the deck was painted with latex, then say the floor had BM semi-trans oil? Could you be a little more specific?
Woz the Painter is offline
Old 06-04-2007, 07:09 PM   #3
sorry let me explain I painted the uprights and handrails a white exterior latex and the floor a diff colour,thinking it would be more hard wearing I used an oil paint, now since the general consensos here is to use water based paints inside and outside I wandering how to put right my work from last year.
regards D/B
ps here is a pic
Old 06-04-2007, 07:13 PM   #4
here is the pic
Old 06-04-2007, 07:42 PM   #5
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
That must be one bright yard on a sunny day. If you can, strip the floor and reapply a coat of semi-solid white stain. You are going to need a strong sodium hydroxide based stripper.
PS: your floor should not be flaking if you used a semi trans oil. You must have overapplied it.
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 06-04-2007, 09:22 PM   #6
D.G.L.'s Avatar
Trade: house painting and repairs
what is a semi transparent gloss ??? you got me stumped 20 yrs brush in hand........ semi transparent contains hardly any solid pigment.....thus you can see the wood grain with a slight color.......
was this tranparent put over a paint ?
D.G.L. is offline
Old 06-04-2007, 09:45 PM   #7
Deck Cleaner
I think it glossed because he changed it into a film former by applying a second coat wet on dry.
Ken Fenner
Pressure Washing PA
Old 06-05-2007, 08:27 PM   #8
sorry for the confusion the deck boards were given 2cts of beny/moore
Alkyd semi transparent stain and it is only flaking a little. I just really wanted to change to the water based paint for durability
Regards D/B
Old 06-05-2007, 09:19 PM   #9
Deck Cleaner
Going to a water borne stain will not give you greater durability per se. Going to a latex paint is even worse on a horizontal surface. Your vapor transmission rate will be shot to hell and if you think it is peeling now, come back in two years to a total flaking mess. I sugest you strip off what is on there and stay with a semi-trans penetrating oil.
Ken Fenner
Pressure Washing PA
Old 06-06-2007, 06:31 AM   #10
Thank you for your imput, I will do as you suggest where necessary
Regards D/B
Old 07-05-2007, 08:55 PM   #11
bgboise's Avatar
decks are usually a redwood. i've found they will always push a latex paint right off. semi-trans stain is the best way to go.
bgboise is offline
Old 07-06-2007, 12:24 AM   #12
Paint Pro/Faux Artisan
Da Vinci's Avatar
Trade: Painting Contractor/Faux Finisher
I agree. We do decking and trellis work here in sunny California where summer heat can be tortuous. The only thing we've been able to get to hold up is the oil based semi-transparents. ONE- coat only, 2 coats gives you shiners that never seem to dry hard. You will definitely need to strip the other stuff off to give a good base.
Redwood is too soft for latex out here.
Sorry for the hard lesson, but kudos for willing to make it right.
Bay Area Painting Company
Da Vinci is offline
Old 07-06-2007, 07:11 PM   #13
Hi just to let you know I gave the boards a light wash with a deck scrubber and touched up the high spots which were mainly the grain with the semi transparent and then I applied a full coat to the entire floor it looks a million dollars.
btw thanks for all the replies
Regards D/B
Old 07-06-2007, 07:43 PM   #14
Deck Cleaner
David, I am not trying to knock you but you put a band-aid over a gunshot wound. It may look good, but go back in 6 months and look at it. (if you didn't strip it)
A semi trans has to penetrate the wood and cure there. Did you apply it over what was on there?
Ken Fenner
Pressure Washing PA
Old 07-10-2007, 11:09 PM   #15
Its actually my own deck so we will see how it holds up in the coming months, thanks for your comments and concern p/p
How much decking... ruskent Pool Construction & Enclosures 2 03-08-2007 08:38 AM
Powerwashing composite decking??? dougchips Pressure Washing 3 02-12-2007 12:58 PM
vinyl decking with hot tub nriddock Decks & Fencing 2 06-16-2006 02:10 PM
Tectum Decking gman1966 Roofing 10 04-14-2006 12:13 PM
painting painted paneling cessnapilot Painting & Finish Work 4 03-21-2006 06:21 PM
