Cutting Walls Along Popcorn Ceiling
Old 06-13-2011, 10:51 PM   #1
Life-Long-Learner
mc handyman's Avatar
Trade: Home Repair & Remodeling
Rewards Points: 150
I am extremely confident in my painting skills, knowledge, and abilities but I am constantly getting frustrated as I try to cut the wall along the ceiling, specifically popcorn ceilings.
Along trim work, framing, and other edges I have not one single problem making a clean cut edge but nothing I do can I get a crisp edge along the ceiling. I end up spending more time perfecting and fixing the ceiling line than I do on the rest of the painting on my projects.
What do you guys do? I refuse to use those "edging" tools because I have used them before and frankly I think it is unprofessional to be using such a "tool" (that is unless you guys recommend it) Do you use a straight edge knife or something???
Thanks in advance!
If you are afraid of criticism, you will die doing nothing.
mc handyman is offline
Old 06-13-2011, 10:57 PM   #2
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Cutting Walls Along Popcorn Ceiling
You cannot expect a perfect line with popcorn.
Some of the guys here have suggested before having the ceiling color go on the wall about a 1/2" or so. I have never used this method before but it might be what you are looking for.
CrpntrFrk is offline
Old 06-13-2011, 11:06 PM   #3
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,073
Thanks in advance!
mc, Use your paper machine. Then spray it. Perfect lines every time.
-Paul
Sir Mixalot is offline
The Following 4 Users Say Thank You to Sir Mixalot For This Useful Post:
CrpntrFrk (06-13-2011), Frankawitz (11-13-2011), mc handyman (06-14-2011), RCPainting (06-22-2011)
Old 06-22-2011, 03:57 PM   #4
BarryE's Avatar
Trade: Remodeling & Painting
Rewards Points: 150
Sometimes you just have to fake a straight line, popcorn is usually one of those times. It's the illusion of a straight line that you are looking for.
I normally start by running a 6" knife along the edge. I see a lot of guys using short stop and go strokes trying to cut in a line. You want long steady strokes, if a spot along the ceiling doesn't fill don't stop, continue your line and then go back and fill in. Sash brushes don't work well here they don't hold enough paint. I prefer a 3" wall brush like the Swan or even better a oval wall brush ..think Purdy's is called the Pip
Sometimes to get the line to look straight from the floor, it's necessary that your wall color goes into the ceiling just a frog's hair. When this is needed to get a straight looking line, it's better to go into the ceiling instead of stopping short of the ceiling angle. Looks much better from the floor view.
BarryE is offline
Old 06-30-2011, 08:47 PM   #5
House Painters Reading PA
4thGeneration's Avatar
Rewards Points: 250
Usually this comes from the sheet rock guys not going around the edges of the ceiling when finishing their walls.when in new construction we always just took a sharp edge tool and run it across the ceiling line to get all of that junk out of the line and go with it. No matter what there will be no actual straight lines when following these edges because there is no such thing as straight sheet rock lines or edges to cut through and I explain this to home owners before I start.I give them options that we can make a straight illusion of a line or follow the one that is before us. Make them sign off and go with it.
Colonial Power Washing and Painting by Sutton provides
House Painting Services in Reading PA
for all Interior and Exterior Projects
484-334-1311
4thGeneration is offline
Old 07-19-2011, 12:27 PM   #6
roads's Avatar
Trade: Paint
I'd listen to this guy, he knows what he is talking about, though I think he forgot one thing, when you paint your ceiling first bring your cut line down the wall a few inches so when you cut the wall in you can better manipulate the illusion. The pop corn will blend into the little bit of white you leave on the wall to avoid the ceiling.
roads is offline
Old 07-20-2011, 06:18 PM   #7
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 812
take an old fashioned can opener and drag it down the corner, should give you an easy line to follow.
dave_dj1 is offline
Old 08-24-2011, 10:33 AM   #8
GA Painting's Avatar
Trade: Painting and pressure washing
I also agree, create an optical illusion and make your own line.
GA Painting is offline
Old 10-31-2011, 11:32 PM   #9
Rroberts1431's Avatar
Most ceilings aren't perfect. Depending on the ceiling. Sometimes the texture comes to far down on the wall and sometimes not enough. If looking for perfection. Scrape what you need away with a scraper or something. Then cut in a straight line.
I think getting a very very small amount of paint on the ceiling looks better than coming up short. My opinion.
Rroberts1431 is offline
Old 11-13-2011, 09:40 AM   #10
Frankawitz's Avatar
Rewards Points: 1,196
popcorn is a pain to cut we would take 6" and scrape the wall up to the ceiling removing any texture, then we would paint walls tight to ceiling, then come back in mask off top of walls and spray ceilings. when you pull your tape nice clean lines. Good luck
Frankawitz is offline
Old 11-13-2011, 10:07 AM   #11
Trailer park boy
shanekw1's Avatar
Rewards Points: 369
Use the point on your 5-in-1 and run it along the ceiling where the ceiling meets the wall, this will give a decently straight line to cut.
"Industry without art is brutality"
shanekw1 is offline
Old 11-23-2011, 07:44 PM   #12
Level 27 Contractor
Bastien1337's Avatar
Trade: Renovation
I personally feel that cutting the popcorn ceiling is easier then cutting a regular ceiling, the human eye has a harder time distinguishing the straight line of a popcorn ceiling, so I just go with it
Sebastian
Check out my gallery here http://on.fb.me/I2XylV
Check out my blog here http://sebastianbethke1337.wordpress.com/
Bastien1337 is offline
Old 02-18-2012, 07:47 PM   #13
boman47k's Avatar
Rewards Points: 2,006
When we first sprayed this ceiling, I took a mud knife and went around it scraping up the wall to the ceiling to get a straight line when cleaning the texture overspray off the walls. I hoped this would leave a straight line to cut into. Worked out pretty good. I did not use a wet brush for the cut in. I did some scraping of the brush on the cutin pot. Wiggle and push along, play by ear.
P.S. I mentioned the fact that I cleaned the line up at the ceiling myself to say the quality of the line at the intersection of the wall and the ceiling can can make the cutin so much easier.
boman47k is offline
Cathedral Ceiling with false ceiling stubbs187 Insulation 4 12-25-2010 05:53 PM
Popcorn Texture over Concrete AM1965 Drywall 14 04-15-2010 11:51 AM
Popcorn Ceiling Removal / Laminate Ceiling with 3/8? plazaman Drywall 18 03-06-2009 11:45 AM
Painting popcorn ceiling navco1390 Painting & Finish Work 4 07-06-2006 07:43 PM
Determining Manhours for rolling vs. cutting - your suggestions would be helpful Zeebo Painting & Finish Work 9 06-02-2006 06:12 PM
