Cleaning Formula For Cosmetic Exterior - Cedar Siding
Old 10-30-2008, 06:03 PM   #1
milos's Avatar
Trade: remodeling and framing
can you give me some advice.It is previously painted .Some mildew.Thank you
milos is offline
Old 10-30-2008, 06:43 PM   #2
John the estmtr's Avatar
Trade: Painting: Commercial, High Rise, Custom, Residential
Re: Cleaning Formula For Cosmetic Exterior - Cedar Siding
Deck Brite from Sherwin Williams to remove residual stain. Rinse. Then 3/4 h2o and 1/4 bleech. Rinse again. Agitate both solutions with a bristle brush, apply solutions with a Hudson sprayer, no need to destroy it with a 3k psi pressure washer....
Experience: Formerly an outside sales rep for a paint manufacturer. Was offered a better job as an estimator for a paint contractor company and never looked back. So when I give my .02 cents, well it still doesn't matter...
John the estmtr is offline
Old 10-30-2008, 06:57 PM   #3
Handle It!
MALCO.New.York's Avatar
Do a search. This topic has been cover fairly extensively here.
Google the US Forest Service. They have an excellent "Formula".
Ultimate Wisdom---------
MALCO.New.York is offline
Old 10-31-2008, 12:54 AM   #4
milos's Avatar
But I can not find just cosmetic formula.Always is prepare for paint formulas.The house is not so bad .We painted the house 1 1/2 year ago .Thank you for info.
milos is offline
Old 11-01-2008, 06:34 PM   #5
Matthew Sargent
Msargent's Avatar
Trade: Painting and Drywall
Try bleach tsp and simple green solution. Works for me
Msargent is offline
Old 11-10-2008, 09:06 PM   #6
milos's Avatar
thank you .CAN YOU GIVE ME THE RATIO
milos is offline
Old 11-10-2008, 09:31 PM   #7
A bit abrasive.
WisePainter's Avatar
Painted, or solid color stained?
My advice: Hire a real painter to do it.
WisePainter is offline
Old 11-10-2008, 09:47 PM   #8
Handle It!
That is The US Forestry Service Solution!!! I just can not recall nor find the damn Ratios!
Old 01-11-2009, 05:27 PM   #9
Painting Contractor
Damon T's Avatar
An old post, but maybe this will help. We use Jomax, made by Zinsser. You mix it with bleach, but are using less bleach since the Jomax helps with the cleaning. It does a great job cleaning, especially at removing mildew. It typically wont damage painted surfaces, nor will it discolor them. However always test an area first.
This is for painted surfaces. For unpainted cedar we typically use the wood brighteners designed for this, made up of oxalic acid.
Damon T is offline
Old 01-16-2009, 12:37 AM   #10
sparehair's Avatar
Trade: Painting, flooring
can you safely mix tsp and bleach?
sparehair is offline
Old 01-16-2009, 01:33 AM   #11
Handle It!
Yes. It is Ammonia that you want to keep from Bleach! That and NaOH (Lye).
Roof Cleaning Pictures Wanted !! Roof Cleaning Pressure Washing 5 09-07-2010 09:24 AM
Nailing cedar bevel siding Chris B Carpentry 2 08-25-2008 03:33 PM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 08:16 AM
Watertight integrity of viynl siding? mci2980 Windows, Siding and Doors 71 11-24-2007 04:15 PM
Products for cleaning cedar siding? rangie Painting & Finish Work 2 07-24-2007 04:34 PM
