#21 | |
DavidC
Re: Advice On Awkward Job Set-upQuote:
Good Luck Dave
www.CookContractingLLC.com |
#22 |
Trade: Res Repaint
Re: Advice On Awkward Job Set-up |
#23 |
Al Smith
four 2X4 roof brackets/jacks. A pair on each side of the projection near the gutter for the bottom rung of both ladders, Split the extension ladder in half. Put one half into the brackets on either side. Put a canvas tarp under the ladders for roof protection. if you need to get on top of the sun room for the clestory put ladder brackets on both and a 16 foor decorators plank across.
#24 |
I like Green things
Must be dead by now.
#25 |
who am i to say, but them seems like a very easy setup for you. I know im going to get knock for this one, but you should seem some setups we do!
#26 | |
#27 |
Al Smith
funny that this long dead thread is resurrected. Ive come across a similar job im trying to figure out how to scaffold. I have to strip off the decomposing pine beveled siding and replace with four inch vinyl.
http://www.awsmith.com/images/reese%...pslideshow.php |
#28 | |
KemoSabe
I haven't seen a safer sounding option posted thus far.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
#29 | |
![]() http://www.industrialladder.com/sear...o.x=26&Go.y=13
#30 |
Al Smith
putting the ladder on the roof is the easy part. don't even need a ridge hook. as I always use a pair of heavy 2X4 roof brackets screwed to the roof to support the ladder by the bottom rung. The problem lies in reaching the top 11 foot corner of the cupola and the top of the gable dormer which is six feet away from the lower gutter/facia
#31 | |
KemoSabe
#32 |
Al Smith
Another interesting complication is at the front of the building. See that gap in the crown of the tree to the upper left hand corner which is just outside the left frame of the image? That's clearance cut out of the tree for the high voltage power lines
http://www.awsmith.com/images/reese%...0911091406.jpg |
#33 |
Quick question on ladder rolling roof hooks.....which way should the foot be? "L" 90 on the roof or the end of the "L" (opposite the 90 bend)?
FWIW I prefer the hooks if a 40' will work, if not then I'll do the roof bracket base for the ladder and I strap it down to the 2x with plumber's strap. Fell off a ladder once (feet kicked out on a deck and we slid down the wall, had I fallen to the left it would have been 15' to the ground....so I tend to be over cautious now. |
#34 |
House Painting Denver
Trade: Painting, Painter, Painting Contractor
I would suggest scaffolding if you are going to be replacing boards, sanding, staining etc. That way you have a platform to work off of too... Very nice.
| Professional Salesmen I need your advice. | Grumpy | Marketing & Sales | 46 | 01-08-2011 09:10 AM |
| Advice on demolition work | Dmax Consulting | Construction | 7 | 01-07-2011 01:12 PM |
| Advice wanted for starting a construction firm | P.J. | Construction | 34 | 10-09-2009 02:51 PM |
| Need advice on Greek Revival | mikeremote | Historical Restoration | 3 | 05-12-2009 11:21 PM |
| Advice for starting Career as Operating Engineer | TrendTherapy | Excavation & Site Work | 0 | 02-13-2009 11:07 AM |
