How To Support / Anchor A Free Standing Wall
Old 02-10-2017, 03:40 PM   #1
Jcrawford000's Avatar
Trade: General contractor
Rewards Points: 2
Hey Everyone....
I have a client that wants a 8' x 9' free standing wall built to separate the entry way from the formal dining area. Problem is... The home is on a concrete slab with marble tile floors, so no floor joists to anchor into, and the ceiling is 16' high.
How can I build this wall and give enough strength and support so not to wobble or even fall over. I will try to upload a pic of the design they are wanting but this is my first time posting in this forum.
Any advice appreciated
How to support / anchor a free standing wall-img_3530.png
Jcrawford000 is offline
Old 02-10-2017, 04:59 PM   #2
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,056
Re: How To Support / Anchor A Free Standing Wall
All thread epoxy anchor and Simpson HDU, sheet with plywood.
Philament is offline
The Following User Says Thank You to Philament For This Useful Post:
Jcrawford000 (02-10-2017)
Old 02-10-2017, 05:00 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Bore hole through floor & slab large enough to set 4x4/3x3 square tube.
Go 24" deep or better, enlarge dirt cavity as permitted and set in hydraulic cement.
Steel can be 24"( or more) below top of your wall.
griz is offline
The Following 3 Users Say Thank You to griz For This Useful Post:
Jcrawford000 (02-10-2017), overanalyze (02-10-2017), pizalm (02-10-2017)
Old 02-10-2017, 06:15 PM   #4
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 256
So that is just a picture of a wall you are planning to build? I would use at least 2x6 if not 2x8 for the framing. There are a number of different methods you could use to anchor it. I think I would just use some bigger wedge anchors to bolt down the bottom plate. Use a big washer or even a piece of steel to make sure the nut can't be pulled through the wood if someone really pushes on the wall. You could also use all thread epoxied or set with anchoring cement. Just make sure to use enough and set them in the right locations. Frame it up and then like mentioned sheet the whole thing with 1/2" sheathing. Make sure the sheathing is attached to the bottom plate good, maybe even a double bottom plate so you aren't screwing the sheathing right on the edge. Use some glue also. Then drywall as usual or whatever.
platinumLLC is offline
The Following User Says Thank You to platinumLLC For This Useful Post:
Old 02-10-2017, 09:28 PM   #5
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 3,640
This of course is the best way, or at least point of diminishing returns. I'd think steel just 3 or 4' up would do pretty well.
My gut tells me that wedge anchors and most other methods won't make a very solid wall if it looks something like the example pic.
Golden view is offline
Jcrawford000 (02-12-2017)
Old 02-10-2017, 09:43 PM   #6
Dan_Watson's Avatar
Rewards Points: 2,460
Along with the great tips above, we frame walls similar to this with double top and bottom plates, and then additional end studs full height screwed into the ends. All screws, no nails. Also sheath with ply. All-thread epoxied into the slab and then a big square washer through the first top plate clamps it down nice and tight.
I would second at-least 2x8, but offset smaller steel columns. IMO 4 smaller posts, staggered on both sides on the wall, will be more effective than two larger posts.
Dan_Watson is offline
The Following 2 Users Say Thank You to Dan_Watson For This Useful Post:
Jcrawford000 (02-12-2017), overanalyze (02-10-2017)
Old 02-10-2017, 10:53 PM   #7
rustyjames's Avatar
Rewards Points: 1,428
I like the embedded square tubing on each end idea the most. Maybe overkill but it's not going anywhere.
rustyjames is offline
The Following 2 Users Say Thank You to rustyjames For This Useful Post:
griz (02-10-2017), Jcrawford000 (02-12-2017)
Old 02-10-2017, 11:02 PM   #8
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
My suggestion is to glue every single thing in that wall, and add horizontal blocking periodically to help with racking.
TaylorMadeAB is offline
The Following User Says Thank You to TaylorMadeAB For This Useful Post:
Old 02-10-2017, 11:08 PM   #9
Fire up the BBQ
griz's Avatar
Rewards Points: 18
won't be over kill first time some drunk runs in to it and he falls down instead of the wall.....
griz is offline
A&E Exteriors (02-11-2017), Jcrawford000 (02-12-2017), woodworkbykirk (02-11-2017)
Old 02-10-2017, 11:13 PM   #10
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 338
Steel baby..steel!
overanalyze is online now
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
Jcrawford000 (02-12-2017), KAP (02-11-2017)
Shaft Wall for Rowhouse raycgl Construction 7 07-21-2013 08:16 PM
Free standing Wheelchair ramp by Creative Bath Systems Creative Bath Specialty Trades Picture Post 5 05-30-2012 06:40 PM
Shoring Exterior Load Bearing Wall for Beam insertion larch General Discussion 4 01-27-2012 07:47 PM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
