The bottoms of all the posts are in Simpson post bases ABE ZMax for 6x6s epoxied in with 5/8" ready rod.
At the top where the beams are, I first cut out the ship lap on the gable of the house and installed solid wood framing on both sides for sub nailing. Then I replaced the ship lap with 3/4" PT plywood and re-papered it. Using 10"
TimberLok® Heavy Duty Wood screws by Fasten Master and Simpson A35s I attached the post through the top into the sub nailing so you won't see the fasteners.
Back in Houston, I would have cut in physical beam pockets to slide the beams into, but up here they are very cognizant of potential water intrusion. Everything is done to minimize penetrations. As far as uplift, I will be installing Simpson black decorative T and L strapping. Also, it was decided to delete the front right post and go with the cantilevered look. I should be finished with it this week so I'll get more pix then.
The only real "challenge" was that the existing gable that we are tying into is 5/8" out of plumb over a 4' level. Imagine my surprise when I pre-build all of the components, get everything ready for erection and discover that I failed to do the most primary thing... VERIFY that what you are tying into IS what you assume it to be! I won't be missing that step ever again. I guess I have to get used to remodels being "a bit off" from the new framing I'm used to.
The HO and GC are pleased with how its turning out so its going in the win column.
