Diagonal Brace Between Load Bearing Wall - Remodeling Picture Post - Contractor Talk
Old 07-06-2018, 04:27 PM   #1
sbaker51's Avatar
Trade: Landscaper
Rewards Points: 2
Question
Hey everyone. To remain cost effective, we decided to frame windows in an interior wall to allow more light into both the living and den. The last opening has a diagonal brace (it is a load bearing wall) - see attached images. Is it safe to cut this out, or does it have to remain in place? Thank you in advance!
Diagonal Brace Between Load Bearing Wall-pic-1.jpg   Diagonal Brace Between Load Bearing Wall-pic-2.jpg
sbaker51 is offline
Old 07-06-2018, 05:40 PM   #2
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,278
Re: Diagonal Brace Between Load Bearing Wall
That 1x4 is what is known as a 'let-in' brace. It is there because the structural designer decided that that was the best place to put a brace for shear.
Yes, it should stay there unless you can replace the bracing with something else to make up for the lost shear value.
Andy.
ScipioAfricanus is offline
The Following 4 Users Say Thank You to ScipioAfricanus For This Useful Post:
Caleb1989 (07-08-2018), hdavis (07-06-2018), Rio (07-07-2018), SouthonBeach (07-06-2018)
Old 07-06-2018, 07:21 PM   #3
TimNJ's Avatar
Rewards Points: 3,142
Was that room added on at some point?
TimNJ is offline
The Following 2 Users Say Thank You to TimNJ For This Useful Post:
Rio (07-07-2018), rrk (07-09-2018)
Old 07-08-2018, 05:37 PM   #4
Caleb1989's Avatar
Rewards Points: 176
You could pull off the drywall on one side, shear nail cdx plywood over the whole window wall. I’m no engineer, but I think that would make up for an angle brace.
Caleb1989 is offline
The Following User Says Thank You to Caleb1989 For This Useful Post:
A&E Exteriors (08-13-2018)
Old 07-09-2018, 08:08 AM   #5
Designer/Contractor
Rio's Avatar
Rewards Points: 2,612
That would help but with the number of windows and the short distance between them the aspect ratio is screwed up. The aspect ratio is normally 2:1, 2 units vertical to 1 horizontal as in a 4x8 sheet of ply, when it gets narrower it gets a lot weaker.
Maybe there's part of the wall that has more wall area, maybe go with strapping on top and bottom of the windows........
Rio is offline
Old 07-09-2018, 08:43 AM   #6
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
if it were my place... pull the rock, add a stud between each window and now you have layout for full sheets with window cut outs!!! ..throw up some 3/8" struc 1 and start drywalling
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 07-09-2018, 08:49 AM   #7
rrk's Avatar
Rewards Points: 2,694
A location would help, I have never seen shear walls inside a house
rrk is online now
Old 07-09-2018, 09:01 AM   #8
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,768
Regional thing. They are nearly universal here.
Golden view is offline
Old 07-09-2018, 09:47 AM   #9
rrk's Avatar
That is why a location would help
rrk is online now
Old 08-13-2018, 05:34 AM   #10
Big Shoe's Avatar
Rewards Points: 1,880
Where’s my sawzall............
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is offline
The Following 4 Users Say Thank You to Big Shoe For This Useful Post:
A&E Exteriors (08-13-2018), hdavis (08-13-2018), tang (08-13-2018), Texas Wax (08-13-2018)
Old 08-13-2018, 05:20 PM   #11
META's Avatar
Trade: General and Trades
Rewards Points: 1,428
Diagonal let ins can usually be moved around. Those windows do not appear to be interfering with the structural wall integrity because they are between stud layout.
Likely need to pull the drywall on the opposite end of the wall and use steel strapping on the face of the studs...if your windows are not on that end as well.
META is online now
Old 08-13-2018, 05:47 PM   #12
tang's Avatar
Trade: Remodel contractor
Rewards Points: 299
I'm with Big Shoe. Cut away!
tang is offline
Old 08-13-2018, 05:50 PM   #13
Texas Wax's Avatar
Rewards Points: 1,096
No DON'T DO IT !!!!!!!!!!!!!!!!!
Might be holding the floor up
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 08-13-2018, 06:32 PM   #14
Tom M's Avatar
Rewards Points: 7,698
Technically you should have a solid 4 ft panel on the end the wall in lieu of the diagonal. Full sheathing has trade offs too with percentages of opening in the wall as well as tie downs.
Without seeing more of the house at least pull one side solid block at the mid section and run full sheathing vertical between windows with good nailing on the plates
Tom M is offline
Split Entry, Truss Roof, Is this wall load bearing? jester2630 Remodeling 9 04-22-2014 09:17 PM
removing a possible load bearing wall under truss? rpr Construction 14 01-09-2014 10:56 AM
Opening up load bearing wall FMB Framing 5 02-07-2012 07:08 PM
Modifying a load bearing wall. wall2wall Framing 85 01-09-2009 10:57 PM
removing a none load bearing wall?? samiam Framing 7 09-12-2007 07:33 AM
