#21 |
Professional Instigator
Re: Addtion To My HouseSee the temp Blocks ![]() You pull out the blocks and slide in two 4" pieces of rebar tie them to the rebar coming out the ground. Box it in with plywood and pour the concrete into a small hole in the top of the plywood forms Last edited by rbsremodeling; 07-11-2009 at 01:03 PM. |
#22 | |
Re: Addtion To My HouseQuote:
handle the leads and then get so sloppy on the openings.
#23 | |
![]() We taught them how to do bond beams, pour corners, and tie steel. It was winter time and they learned how work on a house from ground up. Last edited by rbsremodeling; 07-11-2009 at 01:14 PM. |
#24 |
Re: Addtion To My House |
#25 |
Chris can you teach me how to do ICF walls?
#26 | |
Pompass Ass
We are required to overlap our steel 40 bar diameters and tie or weld them together. |
#27 | |
I don't see it either. hmm might need to jack hammer that corner. The steel nor the poured corners are not required, I use to live in hurricane areas so it is a habit. |
#28 |
I'm a Mac
Trade: ICF Construction
Re: Addtion To My HouseSure, start out as a 3 year old building with Duplo's as you get a little older switch to Lego's...visit LegoLand California and play there. That gives you the basics. Anyone can do it, doing it with finesse takes time. But once you get it down to a science and are understand the whole system you will discover that it is by far the best way to build...and profitable.
Chris |
#29 |
We don't usually do the foundation and slab that way.
At first I thought you were doing a monolithic slab/footing, then it looks like you did a footing and stem wall, formed and poured the slab, then continued with the block walls. Why did you do it that way? We would have placed a footing, run the walls on up with a ledge inside, then poured the slab inside of the walls. Oh, nice looking job BTW. |
#30 | |
The footing and slab were one pour |
#31 |
I like Green things
Re: Addtion To My HouseI always thought that was harder to do. For basements we poured the spread footers, set wall forms, poured, stripped forms, poured floor. Crawls the same except hardly ever concrete rat slab. Slabs we trenched footers and poured, set forms and poured slab. |
#32 |
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
awesome! Rory did you double your living space? Nice finishes and colors
#33 |
Yep double he sf footage. Funny thing I did this exact renovation to a house identical to mine about 6 blocks away
#34 |
Same layout and all? I remember in another thread you posting a couple of these picts and I was like.. Hmmm.. That is really cool man. So did you renovate the other side while/after this side was done?
#35 |
Exact same layout. Same architect did both drawings, Cut and paste. We did both at the same time.
#36 |
okay, but did you say that you did renovate the older living space?.. not sure if you answered that or not
#37 |
Yes sorry I did renovate the old space as well.
#38 |
#39 |
Maker of fine kindling
Nice place Rory
Did you live there during construction? If so, go kiss her right now and thank her again. |
#40 | |
Are you kidding?? She Should be thanking Him for fixing the place up so nice! What are you thinking Gus?
| The Following 3 Users Say Thank You to tgeb For This Useful Post: |
| Animal House Electric | Bubbles | Electrical | 15 | 01-22-2009 01:37 AM |
| Company Growing! In house accountant resources? Help! | ds6154 | Business | 1 | 01-11-2009 10:32 AM |
| ADA House | mtm | General Discussion | 6 | 09-01-2008 10:04 AM |
| House Plans... | ruskent | General Discussion | 8 | 02-28-2008 09:36 PM |
| Raining in the House | oldfrt | General Discussion | 9 | 11-07-2007 11:10 PM |
