Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Roofing > Roofing Picture Post
Old 05-14-2004, 07:01 AM   #1
Trade:
Unhappy Roofing Problem
Hello to All,
I have a serious problem. In 1990 I had a new roof installed on my house. I received a 25 year warranty. The roof is now leaking over the garage area in my home. My problem is I can not find the paper work for the job nor the warranty. In addition, I can not remember the company who performed the job. Is there a way I can find out who installed the roof in 1990? Do companies have to registar or something when they install a roof on someone's property? Do the company have accountablility for property installation? Please help with information and advice. Thank you so very much.
Church
Please email me at minpitre@hotmail.com with information. I am in need for advice. Thank you.
churchldy is offline   Reply With Quote
Old 05-14-2004, 08:46 AM   #2
stop botherin' me!
Grumpy's Avatar
Trade: Roofing Siding Gutters Windows
The 25 year warranty is a manufacturer's warranty I assume. A manufacturer's warranty usually says nothing about leaks, it only covers material defects.Ie: Blisters cracking curling etc... I know in my area we give labor warranties typically of 10 years, and this is twice the norm.
If a permit was obtained, contact your local building dept. The roofer should be listed on the permit application.
The problem is even if you find out the roofer, you really have no warranty against leaks. Like I said our labor warranty, which is the leak part of the warranty, only lasts 10 years and that's considered an excellent warranty. The manufacturer will do nothing if the leak is not caused by a defect.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline   Reply With Quote
Old 05-14-2004, 12:48 PM   #3
Trade: Commercial and Residential Roofing
Churchldy,
Grumpy's statement is right on the money. In regards to your question of whether the company has any accountability for property installation (assuming you meant "proper" and are referring to the company that installed your roof) Sure, they do, either by the length of the warranty, or the state law requirements (minimum)
But, if your roof has been leak free for 14 years.....I would venture to say, it was installed properly. More than likely what you are experiencing is some sort of material breakdown, probably around a penetration treatment, or flashing detail. After 14 years, this does happen. It is also possible there has been damage to the roof which of course is not under the control of the contractor or the manufacturer. Have a roofer check the problem out.
Anita is offline   Reply With Quote
Old 05-15-2004, 09:25 AM   #4
stop botherin' me!
Grumpy's Avatar
Another possibility is wind driven rain or animal damage.
Anita is right also. Everything ages. We encourage our customers to inspect their roofs once a year after the warranty period is up, or if they are not comfortable doing so, we will for them for a minimial fee per inspection.
-Grumpy
Old 01-18-2005, 06:35 AM   #5
bwalter
Guest
Trade:
Posts: n/a
Help finding roofer!
Originally Posted by churchldy
Hello to All,
Church
One thing you might do is to call your bank and have them look up and make copies of the checks you wrote in that time period. Banks keep check records on microfilm for many years. I'm not sure if they will give you that service free?
check out this roof job www.microfilmplus.com/house.html
Good luck .. Ben
Old 03-03-2005, 07:26 AM   #6
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
Checks or no checks, If the roof has lsted past the installers warranty, what remediation do you have?
Picking up the slack
www.roseroofing.net
Metal Roof Rehabilitation, Commercial Roofing, Polyurea Roofing Systems, Commercial Spray Foam, Leak Detection and Repair
AaronB. is offline   Reply With Quote
Old 04-09-2005, 12:41 PM   #7
Trade:
Contact a local roofer to inspect your roof for any weather related damage. If its weather related, you may be able to have your insurance fork over the bill.
Otherwise, look to fix with an easy solutions recommended by the roof inspector/company.
BrosBuilding is offline   Reply With Quote
Old 12-04-2005, 09:27 PM   #8
Trade: canadian roofer
Is the leak Up against the wall, might be step flasing or maybe the orginal installers say that it was a garage, and didn't bother, with an ice and water shield, nor would i but 15 years later stuff happens just be thankfull it's your garage...
canadian roofer is offline   Reply With Quote
Old 12-06-2005, 09:59 PM   #9
Journeyman
ElmForest's Avatar
Seven replies and seven months later and no response from the homeowner? Undoubtably you guys just didn't give her? the answer she was looking for. Did anybody actually email her?
ElmForest is offline   Reply With Quote
Old 12-06-2005, 11:07 PM   #10
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
A year and seven months...thats 2004
Jim P.
jproffer is offline   Reply With Quote
Old 12-06-2005, 11:13 PM   #11
Journeyman
ElmForest's Avatar
Looks like someone needs glasses
Owens corning a solid strip of tar nolo Roofing 26 01-29-2008 01:25 AM
Approval/denial of roofing materials - questions jmasters Roofing 29 11-16-2007 08:09 PM
Roofing License stevel27 Roofing 10 03-28-2007 05:19 PM
High End Metal Roofing Rhino Roofing Roofing 18 03-04-2007 09:55 PM
Well problem paintr56 Plumbing 10 02-09-2007 09:20 AM
