#21 |
Trade: carpentry
Re: Roof By A Hack
Robert,
If you didn't already, you should cap the ridge. I see lots of exposed nails there which will leak at some point. One bundle of 3 tabs the same color as what you have there now will do it. I'm pretty sure the application instructions are on most bundles. |
#22 | |
Trade: Custom deck builder
Re: Roof By A HackQuote:
#23 | |
Bah Humbug!
#24 |
tile mason
Re: Roof By A Hack
Hacks get the job done. (period)
Some old guys, or sometimes "experienced" 25 yr old foremans will laugh at 'hacks' that overlap shingles or who use Henry 208 roof cement or who cant cut 45s in drip or who cut themselves when they use their red and greens on copper. To whom it may concern, roofs that dont leak and last are good roofs. Hacks that come down off roofs in one piece are safe workers And the super duper awesome roofers with all this knowledge and specifications and experience and all will be the first ones to point the finger at one of their foreign helpers who held them up cus they aren't strong enough to carry their 40ft ladders From the pics it looks watertight good job the overlap kind of sucks cus it shows bumps if you wanted eye candy, you'd cleat down double lock copper it's shingles guys not too bad for a deck builder "with perfect practice comes perfection" hey, you got to hack a few times to get started it's the fact that you got started that counts keep up the good work with time comes greatness - a hack |
#25 |
Certified Crazy!
Trade: Insurance Restoration Roofing
Re: Roof By A Hack
@ Matt
First high wind storm is going to blow those shingles right off the deck. So specs are important Matt. The adhesive on the underside of the shingle is "NOT" designed to adhear to the granules. Oh I see, your a tile and paint guy so you wouldn't know that. @ Robert, Nice try but there is a reason each bundle has installation insturctions on the wrapper. = ) |
#26 |
Trade: Roofing Contractor
Re: Roof By A Hack
Since RidgeWalker woke up this old thread, I will make a comment nobody else mentioned. Probably because most are not as old as me.
Prior to architectural/dimensional shingle being pre-made like these, the old-fashioned way to create that affect, was to take common 3-tabs and overlap them just as Robert did with the pre-made architectural shingles. There were no significant adverse problems related to those applications, granted, they were far and few between. Also, regarding wind blow offs. The "old-fashioned" asphalt 3-tab shingles did not even have an adhesive sealant strip embedded on the shingle and they seemed to have lasted for years. The most important factor for wind resistance and shingle blow offs is the correct amount and placement of the nails, precisely where they are supposed to be nailed, not about where they need to be, but precisely. Good to see you back, RidgeWalker, and I see Grumpy checked in today after being gone since the end of March too. (Is there something that we should know about the two of you?) Ed |
#27 |
Trade: roofing
Re: Roof By A Hack
It LOOKS LIKE A 2 / 12 PITCH TO ME, MAYBE ITS THE CAMERA ANGLE.
#28 | |
Trade: google
Can you post a link to these videos? I searched online and couldn't find any. |
#29 |
Re: Roof By A Hack
I've overlapped many of them. Did my own house that way. Elk, GAF, Timberline all said it wouldn't hurt anything. I did a couple of 3/12's with 6" sidelaps. I did make sure it was only 1 layer thick on the 'bottom' shingle. I'd tear off the top piece if necessary, and completely cover any asphalt showing.
http://www.rooferscoffeeshop.com/ima...Low-pitch2.JPG
Frank Slate Roof Repairs, Richmond, Va. |
#30 |
Expert Roofer
Re: Roof By A Hack
there`s plenty of us that carry the 40' ladder just fine solo,w/out the lollipop kids
#31 |
Being an A-hole
Re: Roof By A Hack |
#32 |
Trade: Exterior Remodeling Sales
Re: Roof By A Hack
Here's what I found while measuring the roof next door.
I still prefer Timbertex...
#33 |
Trailer park boy
Re: Roof By A Hack![]() ![]() ![]() ![]() ![]() ![]() that chimney is the best
#34 |
Expert Roofer
Re: Roof By A Hack
ditto that
#35 |
Being an A-hole
Re: Roof By A Hack
holy flashing batman.
THis isnt the first time I saw shingles for caps. Is that a 5" over hang? They didnt offset the shingles to spec either. Last edited by Candlewood; 11-06-2008 at 01:36 AM. |
#36 |
HOT... Smells like Money!
Trade: commercial roofing
Re: Roof By A Hack
Candlwood,
You spent WAAAY too much time figuring out what's wrong with that roof. |
#37 |
Being an A-hole
Re: Roof By A Hack
All that was from a quick glance. I am sure there is more that is wrong. But I cant see it from my house.
#38 |
#39 |
Trade: Roofing
Re: Roof By A Hack
Well you know what they say...if it lasts' and doesn't leak, must be a good roof
, regardless of the I&W flashing kit .
'I'm living on the edge!' |
#40 | |
Trade: Roofing, Framing, Finish Carpentry
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Help tying in this roof to addition | jaymay75 | Framing | 0 | 06-18-2006 10:54 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
