Pan Forming
Old 03-05-2011, 09:34 AM   #1
tinner666's Avatar
Rewards Points: 1,000
Pan Forming
Anybody else put their pan former on the roof? Just a few pix of one I started this week. Only got one panel in due to not working a full day. The pictures are in no particular order, nor did I preview them.Pan Forming-panforming-copper.jpg
Pan Forming-panforming-copper-4-.jpg   Pan Forming-panforming-copper-5-.jpg   Pan Forming-panforming-copper-6-.jpg
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 03-05-2011, 09:39 AM   #2
tinner666's Avatar
Re: Pan Forming
Last pic. I start all my metal roofs with an anchor panel located on a penetration. It eliminates corners, soldering, and potential leak areas that plague other roofers. I've been using these pan formers for 20+ years.
Old 03-05-2011, 09:53 AM   #3
tinner666's Avatar
Re: Pan Forming
Here's an important detail. In picture # 3, you can see, if you look closely, two chalk lines. A 3" swatch has already been cut off for 73". I'm about to cut along the near line to remove 5" form the second portion of the pan. I'll use the 'upper' line to bend a 4" leg to go along the dormer wall. There will be a 2" leg for the rest of the way. When folded below the dormer corner, it will fold over the inner panel in front of the dormer.
The cleats are in reverse of where they will eventually be. Both adjoining panels will be the male 1-1/2" leg and as the double lock seam is formed, they will be locked into the 1-1/2" seam.
Old 03-05-2011, 09:57 AM   #4
tinner666's Avatar
Re: Pan Forming
Though not shown, the outer leg of my anchor panel is flush with the rafter tails. There will be no seam below the valley. The finished panel is 11" wide. Most of the others will be 16-1/2" wide.
I also form my steel panels roofs this way, though it takes longer.
The break in the roof is box folded, not cut. No caulk, no solder.
It's only 40 degrees. The cleats are spcaed off the panels about 1/8" -3/16" so they can expand freely when the temps hit 98 around here. There won't be any space there then. This alone can add 20+ years to the life of a roof because there will not be any oilcanning or pinching of the panels. This is VERY important no matter what metal is used. The panels can last as long as a flat piece of metal lying on a bench, or in the yard.
Old 03-05-2011, 11:33 AM   #5
dennis's Avatar
Trade: Roofing
Rewards Points: 150
Re: Pan Forming
Nice work Frank.
We do most of our bending in the shop. Therefore relegated to max. 10' panels unless renting a former or purchasing from a fabricator.
I myself would feel better putting flat seam on that lower section, but I'm sure the 1 1/2 folded seam is just as water tight.
dennis is offline
Old 03-05-2011, 11:59 AM   #6
tinner666's Avatar
Re: Pan Forming
It's not as flat as it looks Dennis. About 3/12. I tore the tin roof off becasue the owner got tired of painting it. I had installed it about 20 years ago. No leaks or other issues before. I'm looking, but can't pix of the original tin I installed there.
Old 03-05-2011, 12:02 PM   #7
tinner666's Avatar
Re: Pan Forming
Panels on this roof will be 23'.
Old 03-05-2011, 12:12 PM   #8
copper magnet
seeyou's Avatar
Trade: custom metal fabrication
Rewards Points: 512
Re: Pan Forming
Boy, this thread brings back some memories. It's been probably 20 years since I laid one like that. We do all our forming in the shop now, as well.
I've never done copper in longer than 10' lengths, but I've laid a lot of terne like that. Keep the pics coming.
seeyou is offline
Old 03-05-2011, 12:24 PM   #9
tinner666's Avatar
Re: Pan Forming
Some of the nails showed rust on the heads, but they probably got wet before installation. No trace of rust on the pans, or in the seams. As you can see, I like planks for underlay.
Pan Forming-bottom-my-old-tin.jpg   Pan Forming-bottom-my-old-tin-6-.jpg   Pan Forming-bottom-my-old-tin-3-.jpg
Old 03-05-2011, 12:25 PM   #10
tinner666's Avatar
Re: Pan Forming
Later maybe. Got to run now. Carry on without me guys!.
Old 03-09-2011, 11:33 AM   #11
s.kelly's Avatar
Trade: electrician
Rewards Points: 150
Re: Pan Forming
Thanks for posting pics, love to see more.
I have an old place on church hill with a terne roof, love the old stuff.
You working in northside? See lots of stucco in the pics.
s.kelly is offline
Old 03-09-2011, 12:30 PM   #12
tinner666's Avatar
Re: Pan Forming
Northside and WestEnd. Too many tire kickers in ChurchHill. I have a few in Jackson Ward, and one I did in about 1500 blk. of Brook.
Old 03-09-2011, 12:31 PM   #13
tinner666's Avatar
Re: Pan Forming
I forgot. Lakeside, Blvd, and Byrd Park area too,
Old 03-09-2011, 12:40 PM   #14
tinner666's Avatar
Re: Pan Forming
It all came together behind the fascia and drip edge, with the lock strip even with the DE.
Old 03-09-2011, 12:42 PM   #15
tinner666's Avatar
Re: Pan Forming
Crappy solder job, Sievert wouldn't get above 'Low' setting, it was cool and windy. Appears to be a good bond though since I pretinned the strip and the panel.
Old 03-09-2011, 12:48 PM   #16
tinner666's Avatar
Re: Pan Forming
Here it is with the valley in. The red line is about 1/2" past the lock strip so I know where the panels are supposed to end.
Pan Forming-copper-valley-detail-2-.jpg   Pan Forming-copper-valley-detail-5-.jpg   Pan Forming-copper-valley-detail-4-.jpg
The Following 2 Users Say Thank You to tinner666 For This Useful Post:
s.kelly (03-10-2011), seeyou (04-03-2011)
Old 04-03-2011, 05:45 PM   #17
Don't Eat Yellow Snow!
English Roofer's Avatar
Trade: Pro Slater and Roofer
Rewards Points: 254
Re: Pan Forming
Nice Work Frank!
Cheers
' I can resist anything but temptation' Oscar Wilde
www.drroofing.co.uk
English Roofer is offline
Old 04-03-2011, 05:55 PM   #18
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Pan Forming
yes thanks tinner for shedding more light on the curved transition
Tom Struble is offline
Old 04-04-2011, 05:41 PM   #19
tinner666's Avatar
Re: Pan Forming
It's still coming along. Work one day, take 2-3 off due to rainy weather.
Pan Forming-hand-formed-copper-roof-panels-2-.jpg   Pan Forming-hand-formed-copper-roof-panels-3-.jpg   Pan Forming-hand-formed-copper-roof-panels-4-.jpg
The Following 3 Users Say Thank You to tinner666 For This Useful Post:
Framer53 (04-04-2011), seeyou (04-04-2011), Tom Struble (04-04-2011)
Old 04-20-2013, 10:36 PM   #20
http://www.matteoguttersy
kam13's Avatar
Trade: Roofing ,Sheetmetal ,Gutters http://www.matteogutt
Re: Pan Forming
great workmanship .....
kam13 is offline
Tags
copper panel forming , copper roofing
Forming mmsuth Construction 19 10-12-2011 03:40 PM
forming brick ledge PaulPrice Concrete & Paving 13 01-30-2011 09:01 PM
What tools does everyone carry for forming mw31 Concrete & Paving 7 12-27-2010 10:12 AM
Forming a cap slab BSCi Construction 4 02-12-2010 02:40 PM
Tidy forming EPD Construction Picture Post 6 02-09-2010 10:47 PM
