Trade: Sundecks
ISO Tips For Walking Steep Roof (asphalt)
I have to walk roofs for inspection and estimates. Looking for tips on shoes or attachments to wear on steeper pitch 8/12 and up. The older the roof the slicker it gets when granules start coming off. 30-40 feet in air and sliding no fun for the heart.
#2 | |
Trade: Framing
Re: ISO Tips For Walking Steep Roof (asphalt)Quote:
I have a roof that is 24/12, want to walk it to give me an estimate? You need to find a way to estimate without climbing onto existing roofs. You are taking a risk going onto a roof without a signed contract. I had back in the seventies a salesman working under me who di this. After the next rainstorm, the roof leaked and we were blamed. Upshot was, we paid for a new roof with very little compensation. |
Trade: siding
just a matter of time before you go for a ride
![]() they have those cougar paws roofing shoes,but still,you need fall protection can't you use binoculars or that new fangled satellite imaging?
Tom |
Trade: Sundecks
Satellite imageing costs about $100.00 a shot, not cost effective estimating.
We walk the roof for accurate measuring and visual. We sell alot of roofing over our competion for that very reason. Photos, and detailed inspections. There are many things to find and point out someone who measures from ground can't do. We follow a "when in doubt don't walk it "or if uncomfortable policy. |
Back in the day, roofing 8,s and greater we would sit on Thick Foam pads that we would get from local upholstery shops. These foam pads would stick like glue to the roof, never damage it, and was comfortable on your knees. Maybe you can make some kind of Boots that have thick foam soles, GMOD
| The Following User Says Thank You to genecarp For This Useful Post: | Tom M (03-14-2010) |
#6 | |
Trade: Framing
Trade: siding
Tom Last edited by Tom Struble; 03-14-2010 at 02:10 PM. |
Dproc as you get older you'll start inspecting from the ladder. I used to climb up every job and to be honest many people will like that you didnt estimate thier house from the truck. But you dont have to scale every roof to assess what you estimate. You can see enough on a steep roof without taking the risk.
#9 | |
I agree with the general consensus dproc, don't get up there unless you have to. I gave an estimate a while back on a roof that had been leaking for a while. H/O had hired some hack to fix it and recovered the roof without fixing the leak. The new shingles fooled me. I walked to the ridge to see how much would have to be re-sheathed and almost fell through the rotten plywood.
WICKED WOODCHUCKER
Trade: RESIDENTIAL CONTRUCTION, BUILDING & PROPERT MAINT.
I dont do roofing anymore, but when i did, i very rarely got on the roof for estimate. My estimate would be for the obvious. Strip and lay. Including all materials needed and labor. At the bottom of my quote I would have a price per sheet of plywood and or board if replacing is needed. I would explain this to home owner and never had a problem. getting on roof for estimate is dangerous and risky. I had a mason buddy that did a chimney inspection and was blamed for damaging the shingles in the valley that caused the leak. Ended up costing him a couple grand. so be careful up there!
Re: ISO Tips For Walking Steep Roof (asphalt)![]() |
Roofer
I step foot on most roofs I estimate, but, I seldom walk any of them.
Set your ladder up in a few different points such as on a rake or ridge, never a valley. Walking the ridge will give you the view you need for pictures in most cases and that is the least likely spot to cause problems/leaks. Holding a rake to walk up and down is ok if an 8/12 or less and the shingles aren't falling apart, I use an couch cushion when doing that, it stops sliding and limits granule disturbance. https://www.t-mobilepictures.com/mya...013868000.jpeg
Check out the wheel Jon put on the ridge hook. Good stuff
Trade: steep roof and siding
Big brass ones and sneakers, scetchers work great . i measue the perimeter, then take digital photes, at the office i can zoom and count the rows.
if i get the job the photos do alot for project planning |
#16 | |
Has anyone tried those cougarpaws? They don't look flexible enough.
Trade: siding
Re: ISO Tips For Walking Steep Roof (asphalt)thats how they come,Jon didn't invent the wheel
Tom |
#18 |
WTF mine dont have a wheel never did. I gotta throw one on
#19 |
Save yourself the aggravation...http://www.amazon.com/Qual-Craft-248...1275412&sr=8-1
| The Following 2 Users Say Thank You to JonM For This Useful Post: | Tom M (08-08-2010), Tom Struble (08-08-2010) |
#20 |
Trade: Roofing
I like to walk all the roofs I bid on (Not smart, I know). Cougar Paws do work good and have a replaceable sole, they are heavy and don't flex very good. There is a shoe manufacturer "Rockport" is the name. If you get a pair of those with a crepe sole you get the same or better traction as Cougar Paws while being lighter,more flexible and cheaper.
| The Following User Says Thank You to TerryG For This Useful Post: | katoman (08-20-2010) |
| Safe Roof Cleaner looking To Network With Roof Contractor. | 4thGeneration | Roofing | 4 | 09-25-2009 11:43 PM |
| steep metal roof , help! | jdframer | Roofing | 23 | 03-12-2009 07:45 PM |
| What Is The List Of Every Line Item Possible For Roof Replacemts From Insurance Cos.? | Ed the Roofer | Roofing | 15 | 08-31-2008 04:19 AM |
| roof valley | Fix-it | Carpentry | 3 | 11-12-2007 07:41 PM |
