I Call Them Strip Vents
Old 08-18-2008, 08:51 PM   #1
Roofsafe's Avatar
Trade: Residential roofing
There is always enough roof to bring a home to code per ventilation.
http://www.contractortalk.com/pictur...&pictureid=171
Roofsafe is offline
Old 08-18-2008, 08:55 PM   #2
Re: I Call Them Strip Vents
Beautiful backyard!
Are you some where west of Durango?
neolitic is offline
Old 08-18-2008, 09:00 PM   #3
Roofsafe's Avatar
North of Durango, center of state just east of the Utah border.
Roofsafe is offline
Old 08-18-2008, 09:29 PM   #4
Spent a long night in Dove Creek once.
Are you near Grand Junction?
neolitic is offline
Old 08-18-2008, 10:51 PM   #5
Roofsafe's Avatar
Yes, I'm in Junction.
Roofsafe is offline
Old 08-18-2008, 11:07 PM   #6
Cool neighborhood, I love Black Canyon!
neolitic is offline
Old 08-19-2008, 09:01 AM   #7
Roofsafe's Avatar
This is one I did in Montrose.
http://www.contractortalk.com/pictur...&pictureid=170
Roofsafe is offline
Old 08-19-2008, 09:04 AM   #8
What brand are those?
neolitic is offline
Old 08-19-2008, 09:25 AM   #9
Roofsafe's Avatar
The shingles are Tamko, the vents are SVII, modified for this use .
Roofsafe is offline
Old 08-20-2008, 06:25 PM   #10
Being an A-hole
Candlewood's Avatar
Damn you got a view at work.
Those vents ever leak ?
Candlewood is offline
Old 08-20-2008, 10:27 PM   #11
Roofsafe's Avatar
I've been doing these for more than nine years and have not had any leaks, had a lot of comments from HO's about how much more efficient thier heating and cooling is, also about how much lower the same bills are. I will see if I can find a pic of what the one did this last winter and post it this evening.
Roofsafe is offline
Old 08-20-2008, 10:54 PM   #12
Roofsafe's Avatar
I found a picture that shows how well these vents work in winter.
http://www.contractortalk.com/pictur...&pictureid=282
Roofsafe is offline
Old 08-22-2008, 01:03 AM   #13
Just do it right
adanacdan's Avatar
Trade: Roofing and Exteriors
Are you sure the lower strips are not screwing up the draw from the soffits and acting as a intake????
adanacdan is offline
Old 08-22-2008, 07:31 PM   #14
Roofsafe's Avatar
Never had that problem, I have all my customers do the right number of vents in the soffet so they will be equal or have the numbers in the ridge a little higher. By monitoring the insulators and making sure they don't close off the bays above the top plate over the walls you can insure the air flow, you don't keep an eye on the insulators they will plug it up every time.
If you don't have good air flow you don't have good ventilation.
I have another method I use to gain air flow when there isn't any soffet to tap from, I'll post some pics when I can find them.
Roofsafe is offline
Old 08-22-2008, 10:05 PM   #15
Roofsafe's Avatar
This is what I use when there isn't any soffet or not enough soffet.
http://www.contractortalk.com/pictur...&pictureid=300
Roofsafe is offline
Old 08-23-2008, 08:57 PM   #16
Just do it right
adanacdan's Avatar
Check out DCI Roof Vents. They have one for soffit venting you dont see as much.
Old 08-23-2008, 10:47 PM   #17
Roofsafe's Avatar
I have seen the smart vent and I don't like the way it's made, what I'am doing is better because it doesn't have a filter to plug up in time. I have seen and removed filtered vents that were plugged up on many occasions during tearoffs. Why is a filter used in the first place? don't we replace them when they fill up? How often do you replace a roof filter? Even when I use SVII I take the filter out before I apply it on the ridge or as you see in these pics on the lower roof.
This method is one I use when there is little or no soffet to vent, placed over heated space creats enough heat to open it after a snow and allows the attic to vent properly and by doing so keeps condensation from forming in the attic and keeps the attic temperature the same as outside, by keeping the snow from melting fast enough to creat ice dams, it allows the snow on the north side of a roof to disapate in the air. Thats the only way I know how to explain what I have seen with this method.
Roofsafe is offline
Old 08-23-2008, 11:01 PM   #18
Roofsafe's Avatar
Here is a picture of what I'm saying about the snow.
http://www.contractortalk.com/pictur...&pictureid=303
Roofsafe is offline
Why we say call a Plumber. uaplumber Plumbing 49 08-14-2008 11:57 PM
No return call on bid kevbo Marketing & Sales 28 07-07-2008 10:04 AM
Contractors need not call! smellslike$tome Plumbing 35 06-16-2008 07:49 AM
Sevice call minimum charge? Chris G General Discussion 19 10-20-2006 07:11 AM
Pay Per Call Ads dougchips Marketing & Sales 6 10-15-2006 07:48 PM
