Fridays Riddle Of The Day
The topics of conversation always amaze me in the mornings before everybody gets into work mode. NASCAR, fishing, hunting, music and cooter are normal everyday occurrences on the ride to work. Yesterday this was presented and was a hot topic all day long. Even got the H/O's input. Here it is:
A rifle mounted level 6 ft off the ground fires a shot across a level field. At the same time the bullet leaves the barrel another bullet is dropped the same distance (6') straight down to the ground. Which bullet hits the ground first? |
ampman
Trade: providing pathways for electrons and protons
Re: Fridays Riddle Of The Day
they hit at the same time
an army of sheep lead by a lion will defeat an army of lions lead by a sheep |
Doofenshmirtz Evil Inc.
Wouldn't you need to know the velocity of the bullet being shot?
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber |
#4 | |
And I do electrical, too!
Re: Fridays Riddle Of The DayQuote:
The bullets will fall at the same rate as governed by the laws of Newtonian physics. Only if the fired round can approach the escape velocity of the Earth (roughly 17,500 MPH) could there be a difference in the rate of fall between the two.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
#5 | |
Unless the velocity is 17,500 mph.
Re: Fridays Riddle Of The Day |
#7 | |
Escape velocity is @ 25,00 mph.
egotistical prick
Trade: Wood Inlay
Wrong, wrong, wrong. You're all fired.
32'/sec/sec is velocity of a falling object, in a vacuum, if I recall.
Humidity, air current and heat would effect the speed at which the 2 objects would fall. And neither is in a vacuum. I say the dropped projectile hits the ground first. |
LRG WoodCrafting
I would think that the dropped bullet would hit first. But only by a very short time. Because the bullet is going through the air at a high speed of velocity the thickness of the air will make it seem like a denser atmosphere. Therefore it will fall at a slightly slower rate
Trade: contractor
Same time...if air friction is neglected and numerous ballistics anomalies are ignored.
LRG WoodCrafting
Jeff
Trade: master turd burglar
Sounds like a mythbuster's episode to me.....
The dropped bullet does. The rifle isn't really level, but it is tangent to the curvature of the earth. By the time the bullet gets out there 500' or whatever, as small of a distance that it is, there is more space under the shot bullet than the dropped bullet.
#15 | |
LRG WoodCrafting
Grand Rapids Remodeling
Re: Fridays Riddle Of The DayLast edited by Paulie; 11-16-2009 at 09:52 AM. |
LRG WoodCrafting
Then the dropped bullet would hit first.
#18 |
Eater of sins.
Trade: Designer/Drafter Extrordinaire
It drops at the same rate regardless of velocity. A bullet is a sinning projectile and does not act as an air foil imparting lift (up or down). Even 500 yrds. is not enough for the curvature of the earth to be a factor. At that distance the curvature is significantly less that even a piece of rice paper. The questions properly assumes a dead level field.
Andy.
www.draftinginoc.com |
#19 |
Freud would have a field day with that little slip!
![]() Here's the Straight Dope on the matter. Cecil is my hero. They will hit the ground at the same time. Case closed.
#20 | |
LRG WoodCrafting
500 yards is about 2.25" of drop. A significant distance.
| Old riddle | Shamrock | Off Topic (Non Trade) | 323 | 02-01-2008 11:11 AM |
| very unusual carpentry riddle, making fancy trimmed out yard signs, need advice | jordanski | Carpentry | 8 | 04-14-2007 01:30 AM |
| A REAL riddle! | AAPaint | Off Topic (Non Trade) | 122 | 09-08-2006 05:41 AM |
| Riddle | Murphy | Off Topic (Non Trade) | 4 | 09-06-2006 09:46 PM |
| Riddle me this: | IHI | General Discussion | 10 | 03-15-2006 10:02 PM |
