Trade: handyman
Wallpaper Removal Question
Good day everryone. I was asked to remove some wallpaper from a ladies kitchen. I went there and banged on the wall, it is definately a sheetrock wall not the old hard plaster walls I am used to in the east. My question is if I saturate the wallpaper with hot water to try and remove it won't that cause the paper on the sheetrock underneath to bubble and become damaged? I am not even sure how to bid such a job since I cannot predict what will happen until I actually start peeling the wallpaper. I tried to peel a little piece off to see how easy or stubborn it might be and it is stubborn. Any suggestions on how to approach this?
...jammin
Trade: Rock Disciple
Re: Wallpaper Removal Question
Sure try a spot
If it was put on properly (over primer or paint) it should come off with spray bottle squirts of water and some scraping I'll use a steamer sometimes The only reason removal should lift the sheetrock paper is if it was put up directly on the sheetrock, a big no-no, but possible Then you'll have to play it by ear Try a few spots and see if it is possible to salvage most of the drywall and skim coat the damaged (which may not be...desirable... if it rips up most of the sheetrock paper) |
| wallpaper removal | lornmastro | Painting & Finish Work | 28 | 11-25-2008 08:55 PM |
| Wallpaper removal and Gardz. | gideond | Painting & Finish Work | 18 | 12-11-2007 10:34 PM |
| Wallpaper Removal | Red Canary | Painting & Finish Work | 33 | 03-21-2007 03:24 PM |
| pricing wallpaper removal | lornmastro | Painting & Finish Work | 23 | 09-21-2006 09:40 PM |
| Wallpaper Removal | zcrazypainter | Wallpaper | 4 | 07-23-2006 07:18 PM |
