Wallpaper Removal - Wallpaper - Contractor Talk
Wallpaper Removal
Old 02-03-2013, 08:46 PM   #1
perk's Avatar
Rewards Points: 27
Wallpaper Removal
What is the best method to remove wallpaper ?
perk is offline
Old 02-03-2013, 08:47 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Re: Wallpaper Removal
New drywall!
Chris
Chris Johnson is offline
The Following User Says Thank You to Chris Johnson For This Useful Post:
griz (02-03-2013)
Old 02-03-2013, 08:55 PM   #3
perk's Avatar
Rewards Points: 27
The kitchen is only 10 x 10 a very small area . Contract already signed.
perk is offline
Old 02-03-2013, 09:00 PM   #4
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,136
vinigar and downy and hot water
Anderson is offline
The Following User Says Thank You to Anderson For This Useful Post:
perk (02-04-2013)
Old 02-03-2013, 09:01 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 3,206
So you bid the job to remove the WP and now don't know how to do it?
Why does it have to be removed?
griz is offline
Old 02-03-2013, 09:04 PM   #6
tjbnwi's Avatar
Rewards Points: 4,908
I use Donwy and warm water. Best I've ever used.
Never tried it with vinegar.
tjbnwi is offline
perk (02-04-2013)
Old 02-03-2013, 09:10 PM   #7
perk's Avatar
Rewards Points: 27
I usually score the walls and use DIFF before I joined contractor talk.
The customer wants it removed.
perk is offline
Old 02-03-2013, 09:19 PM   #8
perk's Avatar
Rewards Points: 27
Removing wallpaper is a pain in the butt which is why I am asking for a quick method . Do I need to score if I am using dounty?
perk is offline
Old 02-03-2013, 09:27 PM   #9
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,152
Rent a steamer.
overanalyze is online now
griz (02-03-2013)
Old 02-03-2013, 09:41 PM   #10
perk's Avatar
Rewards Points: 27
Removing wallpaper is not rocket science , I am just looking for helpful tips I estimated 10 hours to remove . Once again as I stated it is a small room.
perk is offline
Old 02-03-2013, 09:48 PM   #11
Always Learning
10 hours should be fine. You might have some wall repair to do. Get the steamer and peel away. Just think of the knowledge you will bring to the next one.
perk (02-03-2013)
Old 02-03-2013, 11:40 PM   #12
Chopsaw Chick's Avatar
Rewards Points: 589
Sometimes you get lucky and can remove the face of the wall paper in sheets, leaving some paper and adhesive. Then, hit it with a pump sprayer with plain water and wipe off with a towel. (This usually only works if the wall was painted before it was papered.) Anyway, it's worth a try before you score it. I've done entire rooms in about an hour or two with this method.
Chopsaw Chick is offline
The Following User Says Thank You to Chopsaw Chick For This Useful Post:
perk (02-04-2013)
Old 02-04-2013, 12:02 AM   #13
tjbnwi's Avatar
Not if it is paper. If it is vinyl try to peel the face sheet. A good wash down is all it takes.
tjbnwi is offline
perk (02-04-2013)
Old 02-04-2013, 11:02 PM   #14
JTemple's Avatar
Trade: Painter / Paper Hanger / Wood Refinishing
Rewards Points: 186
My favored method: TSP, warm water and sponge. Give the TSP solution time to work & keep it damp. Wear gloves! TSP will cause eczema over time. When the TSP has softened the paste it should be a cinch to strip.
Any good paint or hardware store carries TSP.
JTemple is offline
The Following User Says Thank You to JTemple For This Useful Post:
perk (02-04-2013)
Old 02-05-2013, 11:22 PM   #15
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Rewards Points: 7,510
Hands down the best wallpaper removal solution out there:
Safe and Simple
ProWallGuy is offline
Old 02-05-2013, 11:36 PM   #16
JTemple's Avatar
Rewards Points: 186
Generally speaking, the face sheet of the vinyl tears away quite easily. What I hate is those 4-6 layered jobs, or worse, painted over!
JTemple is offline
Old 02-05-2013, 11:43 PM   #17
JTemple's Avatar
Rewards Points: 186
Prowallguy: I notice you put "paper hanging" first, does that mean you prefer paper over paint. Me, I only do paper hanging because it comes with the territory, I prefer painting and wood refinishing.
JTemple is offline
Old 02-05-2013, 11:49 PM   #18
ProWallGuy's Avatar
Paperhanging is my specialty, and I prefer it.
Old 02-05-2013, 11:50 PM   #19
tjbnwi's Avatar
Try Downy, you will be surprised how well it works.
I hate when you have to repaint and it pops the paper you did not know was there, happened to me a few weeks ago.
Last edited by tjbnwi; 02-06-2013 at 03:36 PM. Reason: changed "got" to "have" the grammar sucked
tjbnwi is offline
Old 02-05-2013, 11:50 PM   #20
Always Learning
And your damn good at it! From your portfolio..Yoda you are!
wallpaper removal lornmastro Painting & Finish Work 32 09-17-2012 08:00 PM
Wallpaper removal vs new drywall QRI Wallpaper 17 09-06-2012 06:13 PM
Wallpaper Removal skorper Wallpaper 11 01-11-2012 09:18 PM
Wallpaper Removal Red Canary Painting & Finish Work 33 03-21-2007 02:24 PM
pricing wallpaper removal lornmastro Painting & Finish Work 23 09-21-2006 08:40 PM
