Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Painting & Finish Work > Wallpaper
Old 01-25-2006, 11:31 PM   #1
Trade: Painter/Ben Moore retailer
Wall liner for covering wood paneling?
Hello! Can anyone recommend a good wall liner to cover wood paneling before painting? Should I prime the walls before the wall liner goes on ? And how well does the liner work? And how well does it take paint? Any info will help me decide if i want to use the wall liner!! Thanks in advance!! Jeff
benjmo is offline   Reply With Quote
Old 01-25-2006, 11:49 PM   #2
MODERATOR
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Wash/scuff sand the walls, and prime with an oil/alkyd primer. XIM would work well also. I use Cavalier Wall Liner exclusively. I linked you to the 26" type, it also comes in 52" bolts. If you are handy at hanging, you can doublecut it as you go, and have minimal floating to be done at the seams. The seams will mostl likely need a little skim coating, then prime it with an acrylic primer. Then paint. Call Cavalier, ask for Ed, and tell him Tim in StL sent ya.
For a more permanent fix, check out Flexi-Wall products.
ProWallGuy is offline   Reply With Quote
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 10:27 PM
In ground pool liner mgmmike Pool Construction & Enclosures 9 06-12-2007 08:30 PM
wood paneling question guys bigbrew Painting & Finish Work 11 01-14-2007 10:26 AM
ideas for wood stud wall attachment to steel "I" beam? durham Construction 9 05-10-2006 05:45 PM
Low (12" or so) brick garden wall questions bindersbee Masonry 8 04-27-2006 07:31 PM
