Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Painting & Finish Work > Wallpaper
Old 10-13-2006, 11:13 AM   #1
Terrence's Avatar
Trade: painting and carpentry
Unstuck edges are creating fear
I don't really touch wallpaper except to remove it.
Non-business situation. Friend of the family.
Has wallpaper, and the edges are unstuck.
I'm thinking to try to paste it back down won't
work because it has been like this for a long
time, and will be stubborn (but I haven't tried yet).
Is there any special product formulated for this situation?
Any help or guidance would be appreciated.
Thanks.
Terrence is offline   Reply With Quote
Old 10-13-2006, 11:33 AM   #2
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
I've used this stuff before, it worked OK.
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline   Reply With Quote
Old 10-13-2006, 11:54 AM   #3
Terrence's Avatar
Ha!
I knew it!
A million thank you's!
That must be the everlasting gobstopper of wallpaper!
Old 10-13-2006, 10:28 PM   #4
pro
hangit's Avatar
Trade: wallpaper & fabric installation
instead of the above i would recommend a pre-mixed clear paste. you can get it in gallon sizes.
it's really going to depend on the type of paper and if the seams will lay down as when originally hung.
depending on type of paper, i would brush some paste on the back of the paper and the wall, and then let it sit from 1-10 minutes to tack up. if it's just the paper came loose from the wall, it should lay down no prob. if it's the paper came loose, and also curled over, alot more fussin and cussin is involved; and the paper may not lay down and the seams be tight like original. if it's some kind of vinyl paper and they did curl, you could try a heat gun to soften the vinyl so it will lay down. very carefully!
good luck- hangit
hangit is offline   Reply With Quote
Old 10-13-2006, 11:48 PM   #5
Terrence's Avatar
Thanks hangit.
Yes the edges are curled a bit which is why
I was concerned about it not working. I don't
want to buy some product and have it not work,
and then go buy another...
Creating History gcajnr21 Business 50 07-22-2007 07:36 AM
Concrete Countertop edges budackerman Masonry 9 04-04-2007 02:56 PM
XP creating My pics, my movies, etc.. Mike Finley Technology 1 08-26-2006 02:27 AM
Cutting in curved drywall edges aoc Painting & Finish Work 4 02-20-2006 07:55 AM
I need some tips on creating a skip trowel texture saucedo80 Drywall 2 01-26-2006 01:50 PM
