Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Painting & Finish Work > Wallpaper
Old 11-19-2006, 11:05 PM   #1
Priming over wallpaper?
I keep hearing that you should use a oil based primer over wallpaper cause water base could rewet the glue and cause it wrinkle or lose adhesion.
Is this true?
Also wouldn't a shellac based primer do better since the denatured alcohol evaporate faster than oil or water?
metomeya is offline   Reply With Quote
Old 11-20-2006, 12:09 AM   #2
MODERATOR
ProWallGuy's Avatar
Trade: Paperhanger/Painter
I just plain wouldn't prime over it at all.
ProWallGuy is offline   Reply With Quote
Old 11-20-2006, 08:23 AM   #3
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
Just remove the paper
http://www.wallpaperinstaller.com/wa...stripping.html
chris n is offline   Reply With Quote
Old 11-20-2006, 08:25 AM   #4
chris n's Avatar
Tim that is a lot of posting,I am thinking you have been here awhile!
Old 11-20-2006, 08:38 AM   #5
copusbuilder's Avatar
Trade: Builder/Remodeler- Master Electrician
Is this true?
My painters have primed over paper for years with no ill effect. Of course we try to remove but if it becomes ridiculous we will prime ,float ,prime,texture and paint.
copusbuilder is offline   Reply With Quote
Old 11-20-2006, 12:18 PM   #6
But what kind of primer did they use? Water? Oil?
Stripping just seems like it would be such a pain.
Old 11-20-2006, 03:52 PM   #7
Trade: Painter
I've only painted over wallpaper once, as they insisted, and it bubbled up bad when I checked back on it. Was with latex primer.
Removing wallpaper isn't all that bad. Never did much of it until the past 6 months. It's as simple as soaking it & scraping off.
JNLP is offline   Reply With Quote
Old 11-20-2006, 05:51 PM   #8
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
I've had good success using one of those hand held rollers that puts little holes in the wallpaper then I spray warm soapy water on it. Sometimes just the warm soapy water will do the trick
98% of us will die at some point in our lives
ron schenker is offline   Reply With Quote
Old 11-22-2006, 08:21 AM   #9
Always been oil. Sometimes you just do more damned damage removing the paper.
Old 11-23-2006, 02:06 AM   #10
Catch what you'll eat.
MattCoops's Avatar
Trade: Tile & Paint
if paper is a pain to get off
why not texture over and paint
theres a pic of some stucco we did over bath wallpaper in our gallery on our website: http://www.cupantileandpaint.com/gallery.html
Matt; tile contractor in Charlotte, NC
704-605-0907
Tweeting @MattCupan | read my articles
MattCoops is offline   Reply With Quote
Old 11-23-2006, 02:19 AM   #11
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
I'm not one that's down with priming or painting over wallpaper at all. Removal is the key.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline   Reply With Quote
Old 11-23-2006, 11:36 AM   #12
Trade: painting
Painting over wallpaper decreases the house's value..
jack75 is offline   Reply With Quote
Old 11-23-2006, 05:37 PM   #13
not if they don't know
Old 11-23-2006, 05:47 PM   #14
Remove it if possible, other wise, oil primer is safe, I have herd good things about a product called guards, i think its a clear coat, water clean up.
again always try to strip it first, best way to go imo
Dave Mac is offline   Reply With Quote
Old 11-23-2006, 08:46 PM   #15
Teetorbilt's Avatar
Whatever you do, eventually the paper will let go at seams or bubble. THEN try and get it off!
Stripping paper isn't that big of a deal. Do the job right the first time.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 03-18-2007, 10:33 PM   #16
Trade: painting
the product is gardz, is from zinsser, is very good, once yo remove the wallpaper, sand the walls properly, put one coat of gardz, and paint, and no bubles problems for the glue, no pain removing the glue, even if you have to skim coat, you can do the same, i did it several times and worked great
Burpaz Painting is offline   Reply With Quote
Old 03-27-2007, 04:11 PM   #17
Trade: painting & decorating
Zinsser do a latex wallboard and wall paper primer.Does a great job and easy clean up.
mushogi is offline   Reply With Quote
Pricing out hanging wallpaper gary lee Wallpaper 51 10-28-2009 06:16 PM
wallpaper removal lornmastro Painting & Finish Work 28 11-25-2008 08:55 PM
Painting over Wallpaper RussellF Wallpaper 8 09-28-2006 08:45 PM
wallpaper help!!!!!!! manders44070 Painting & Finish Work 3 03-04-2006 01:31 PM
wallpaper removal question rocco Wallpaper 3 01-30-2006 03:19 PM
